Question about Vga GeForce4 Ti4200 64MB DVIout AGP Card Graphic Card
Ati radeon agp card
I install a used ati radeon agp 9700 pro on a used abit a17 mobo w/ no vga on board.the card cooling fan is spinning,but no display on monitor,it goes on standby,monitor is good
please help
  • 62 Answers
Hi Rafael83,
There may be afew things that may be wrong. One, the video card may be bad, two the motherboard may be bad, or three your power supply may not have enough wattage to power your video card. Or it coud be all of the above.
Agent Xiong
Posted on May 01, 2008
Motherboard doesn't recognize new video card.
do you have an nvidia motherboard? this may be the cause of it.
Dec 09, 2009 | Sapphire ATI RADEON X1600Pro 512MB...
When i installed the drivers for my visiontek radeon 2400 pro hd agp card my pc will not post no beeps or anything it just has no input on the moniter i dont think its a hardware failure because it was...
remove the video card altogether. did you check compatibility of this card with your system? had the same problem with a gateway i removed the card and used the on board video
Nov 01, 2009 | ATI RADEON HD 2400 PRO Graphic Card
VIA CPU to AGP Problem with 3Gb and Vista
Chances are good that your third 1gig memory module is faulty. Windows blue screen of death at startup is a typical symptom of faulty RAM memory.
Try replacing the third 1gig DIMM with another of the same type.
Let me know if this works or not.
Apr 22, 2009 | Abit IP35P Motherboard
Comparable cards to the ATI All In Wonder 9700 Pro 128 MB
Hello there. The Radeon 9700 Pro was a high end graphics card in its time. Today the latest Radeon cards are 3870X2, 3870 and 3850 models. The 3850, while mid-high end range, would be a substantial upgrade from the Radeon 9700 Pro.
If you are planning to upgrade your system, make sure you choose the correct type of card (AGP/PCI-E) and that your current system has a good enough power supply to power a new upgrade.
Hope this helps.
Apr 13, 2008 | ATI All-in-Wonder 2006 PCI Express ,...
Connect a vga card on a used a17 mobo
Hi Rafae183, yes, you're board, Abit Al7/Al7-G supports AGP8x/4x speeds & voltage of 0.8v/1.5volts only.
Below is the Abit link for you're board. Listed on the right of the page is product Inf. & support Inf. Suggest you add this to you're favorites.
Suggested any one of these AGP8x speed video cards.
Remember to check for voltage. You're video card must run at 1.5volts only. Warranty's are important too.
Have more questions, feel free to ask.
Best of luck to you!
How to vote you're expert.
Enter site.
Sign in to your FixYa account.
Locate My Profile on our FixYa's homepage.
Under My Problem locate your problem and click on it.
Under the solution given by the expert, choose.
Apr 12, 2008 | Abit A17 Guru Motherboard
Intel P$ 1.8 mhz on a D845HV/D845WN board
Before removing your current card swap video outputs on the PC. If currently connected to the VGA output switch to the HDMI connector AT the video card. Use the HDMI to VGA adapter that came with the video card. Check & see if the display loads Pc starts. Taking the information directly from your motherboard manual pg. 25, your AGP video can only run at, AGP supporting 1.5 V 4X AGP cards. The 9600pro runs at 8x & it is not backwards compatible. (able to run at either 8x or 4x). You could run the Sappire ATI Radeon 256MB 9550 DDR AGP 4x/8x 1.5volt card.
Here is one site:
When you do get the video card be sure to set your bios AGP to the correct size as listed in your manual pg. 109 subsection 4.4.7
I hope this helped.
Feb 20, 2008 | Intel Motherboard
Radeon 9700 Pro Family
Remove your card. Clean the AGP slot & the video card. Reinstall the card. Still having trouble. Download the latest driver, below: Befor you install the latest driver package. Update windows. You will need .Netframwork ver. 2.0. Uninstall your current driver through Control Panel, ADD/Remove programs.
If the uninstall fails download and run ATI's uninstall utility:
Driver package:
Dec 25, 2007 | ATI RADEON 9700 PRO (128 MB) Graphic Card
Swap 9800 Pro for 9700 Pro
You must uninstall the current driver and reinstall the driver for the 9800 Pro first:
Power supply recommended is 300watt for each, so that is not a factor. It would have to be a driver conflict.
Oct 30, 2007 | ATI RADEON 9800 PRO (256 MB) Graphic Card
Computers & Internet Logo
Top Vga Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
John Hong
John Hong
Are you a Vga Computer and Internet Expert? Answer questions, earn points and help others
