Cannot get player to come on after charging and also did reset button
  • LittleThunde Aug 18, 2008
    My player is Puillips GoGear SA5285. It will not power on. I charged the battery and set the reset button still nothing. It will not even uplaod on my computer. I have only had it for 6 weeks. I would like to know what's wrong LittleThunder128@comcast.net
How do u take song off the pss110 i have taken them out but they still stay on
Posted on Jun 03, 2008
Says Do not disconnect on screen and is frozen there
If the Player is frozen while connected to the Computer, then reset the Player by pressing the RESET button without disconnecting from the Computer. Once the Walkman player is reset, then remove it from the Computer. If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object.
Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed.
After charging the Walkman Player, you can use it. If the issue persists, FORMAT the Player to resolve the issue.
To format the player, select the FORMAT option from the Common Settings menu of the Player.
Thanks for contacting FixYa.
May 07, 2011 | Sony NWZ-E436F MP3 Player
Hi, i own a sony walkman mp3 player of B series that is NWZ-B135F once i inserted my mp3 player into my friends pc later my player has stopped working (the player does'nt switch on) please help me please...
Perform the following steps to resolve the issue.
1. Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed.
2. Make sure that you are pressing the POWER button to turn the player on. Previous Walkman models that did not have a power button would turn on by pressing any button. This model must have the power button pressed to turn it on.
3. Ensure that the HOLD function is not activated.
NOTE: For some models, when you use the portable player for the first time, if you have not used it for a long time, or the battery is depleted, it may take up to 5 minutes for it to be recognized or start charging. On models with a display, the display will remain blank. If it the portable player is not recognized or does not begin to charge after waiting 5 minutes, continue with this procedure to reset the unit.
4. If the portable player is still not responding, reset it by pressing the RESET button with a small pin or similar object. Reset button is located near the Strap hole.
NOTE: When the RESET button is pressed, although the unit will retain the music data and clock settings, all other stored data and settings may be deleted. If the unit starts up after the reset, access the Settings menu and initialize the unit using the Format (initialize) function.
5. If there was no change after the player was reset, connect it to the computer and reset it again, leaving it connected.
Thanks for using FixYa.
Apr 07, 2011 | Sony Audio Players & Recorders
Sony Walkman NWZ-B103F it wont open..
check the unit after completing each step:
Confirm that the portable player is connected to a working USB port and that it is charging. If necessary, connect it to a different port. When connected properly, the battery icon will be animated or it will indicate the charge status such as FULL when charging is completed. Make sure that you are pressing the POWER button to turn the player on. Previous Walkman® models that did not have a power button would turn on by pressing any button. This model must have the power button pressed to turn it on.
Check the Sony Support Web site to see if there are any available firmware updates for your model. Updates can be found on the Sony Support Web Site.
If possible, instead of connecting the USB cable to the computer, connect it to a USB AC adapter (if available) and try to charge it.
Mar 25, 2011 | Sony Walkman NWZ-B103F MP3 Player
My mp3 wont charge
This issue may be resolved by resetting it, try this.
Resetting the device:
1. Press and hold the Power/Menu button for approximately 20 seconds.
2. Release the Power/Menu button.
3. Press the Power/Menu button again to turn on the player.
Jan 02, 2010 | SanDisk Sansa m240 MP3 Player
Wont Turn ON
(1) Hit the reset button for 5 seconds.
(2) Hit the reset button, slide down the on/off slide, and have it plugged into the computer at the same time. Hold for 5 seconds.
(3) Hit the reset button again.
(4) Charge it for at least 10 hours in the port in the BACK of your computer.
(5) After 10 hours, unplug the player and press the + volume button. While still holding it, plug the player back in. Keep holding it for 5-50 seconds. (most likely nothing will pop up).
(6) Let the player sit UNPLUGGED for a good 3 hours.
(7) Plug the player back in (it should light up now). Let it charge the usual time it takes to charge for an empty battery, about 6 hours.
Sep 14, 2009 | Creative Labs ZEN V Plus MP3 Player
Mp3 player won't power on or charge. Was working fine.
the reset button should be on the back of it, you will probably need something like a paper clip to press the reset button
Apr 22, 2009 | Audio Players & Recorders
I cannot get my player to charge.
If the hold/lock is accidentally engaged, the computer will not recognize the player, and the player will not charge - so check that first.
If it is unlocked, then try another USB port on your computer.
If that still fails:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Mar 02, 2009 | Philips SA3025/37 Flash MP3 Player
Fully charge sony walkman NWZ-E436F does not turn on power at all
well u might have gone wrong u should charge ur walkman for abt 3 hrs first use untill full appears and it is recommended that even if u dont plan to use u r walkman u should atlest charge the battery once a while for battery mentainance try to reset ur update the player firmware.or even then if it dont comes send it to sony or have a converstion with sony support
Jan 31, 2009 | Sony Walkman NWZ-S616F MP3 Player
Won't charge and computer will no longer recognise
try pushing the reset button in the back of the player
Jan 09, 2008 | RCA OPAL M4001 MP3 Player
37 people viewed this question
 Grubhead
Grubhead
