Question about Frigidaire GLTF2940ES Front Load Washer
Turns itself on
While having morning coffee, I heard the washing mechine turn itself on. I turned it off and it came back on several minutes later. I left it unplugged for a half an hour and it hasn't come back on, but I am concerned that it will when I am not home.
  • Stevengb May 11, 2009
    Replaced main contro board. Thanks.
    Genius:
  • 1,073 Answers
If it does this again then you will need to replace the cpu unit or main control board
Posted on Apr 30, 2008
"TV, turns it's self on"
Yeah Go Into Your Options Menu And Find The Wake Up See If Its Set To Turn Itself Off. I Use This When I Go On Vacation So People Will Hear The T.v On And Off At Intervals.
Jan 05, 2009 | Televison & Video
Hamilton Beach BrewStation 47224 Coffee maker
My coffeemaker makes the coffee just fine every morning, and we leave it on for 2-3 hours and then it turns off automatically , but later it leaks back to the water reservoir and then out the bottom all over my cabinet. What is wrong?
Oct 14, 2008 | Hamilton Beach BrewStation 47224 Coffee...
Bean Grinder
Hard to say when i´m not have the machine in front of me, i think it can be the printed circuit card.
Aug 11, 2008 | Saeco Royal Professional Espresso Machine
Projector stays on for 3 minutes then turns itself off
Hi Chipped Rice
The loud buzzing noise you heard was the colourwheel that gave in.
Now what happens is , the machine will turn on and go through the whole cycle and as soon as the colourwheel is supposed to start doing it's stuff the Projector will switch off because there is no response from the coulourwheel itself.
You will have to replace the colourwheel unfortunately as it cannot be fixed.
Thanks for using Fixya !
May 27, 2008 | InFocus ScreenPlay 4805 Multimedia...
RCA Colortrak plus. Model# F32672SB Serial # 807560570 Chassis # CTC187CJ3 Manufacture Date Feb 1998 Service # F32672SBFM3 4/21/08- TV worked fine last night. This morning worked for about an hour. ...
It's probably a cracked solder joint in the power supply / horizonal drive stages. As the unit heats up the joint is seperating and breaking connection. It could also be a component failing when it gets hot. Usually the voltage regulator or Horizonal Output Transistor (both mount to heat sinks).
If you know how to solder and want to tinker, unplug the set for a couple days (to let the power capacitors discharge) and resolder and crystalized it cracked joints on the board(s) where the power stages, and flyback transformer are located.
If you decide to operate the set with the back off, please be careful. The high voltage on a TV can be 30,000+ volts.
Hope that helps,
Geno
Apr 21, 2008 | Televison & Video
Turns off randomly
mine does also does yours click at random times and the screen goes out in small places for a split second?
Apr 02, 2008 | JVC AV-32020 32" TV
TV Turns off and on
How long since the last time the bulb was replaced? It sounds like the bulb is overheating and triggering a safety shutdown.
It's probably in need of nothing more than a good cleaning (open it up, clean off the boards with a can of air) and *may* be time to replace the bulb.
Nov 13, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Frigidaire GLTF2940ES Front Load Washer Logo
119 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
