Question about Gaggia Classic Espresso Machine
Power doesn't come on anymore
After i made a cup with my beloved Gaggia Classic, I went to clean it out and turn it off, but the power light ("0-1") was not on (even though the switch was in the "on" position), and no water went through either place when attempted.  Since then I can't get it to turn on at all.  Is there a fuse somewhere?
  • 1 more comment
  • VA Coffee Lo May 13, 2008
    My Synchrony mysteriously stopped powering up. I have ensured that the plug is in correctly and tight and I have confirmed that the outlet is good. There has been no power surge as all the other appliances and computer ate all ok. Is there are a reset button or reset sequence?
  • Anonymous Jun 02, 2008
    unit will not turn on even after switch was replaced
  • dlp1518 Jun 06, 2008
    I had steamed the milk and was switching from steam to getting water from wand to the brew mode. I think I did this all too quickly, and the switch seemed to "pop" and entire machine went dead. Checked outlets, fuses, etc several times. Is this just a switch replacement problem or more major?
  • 3 Answers
Ok i have done alot of  looking up on the net and found that it is the thermal fuse and you can not reset it you have to replace it. I found someone on ebay selling two at a time. the seller name is capacitor12  look uder his name and find the microtemp he should come up. now you are going to have to find the right tempetuer and it is 184c that is the one you need. i bought one and worked great as i had the same problem with mine. so here is the link for ebay.
http://cgi.ebay.com/Thermal-Cut-off-fuses-Microtemp-U-Pick-Temperature_W0QQitemZ190301710929QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item190301710929
Posted on Apr 22, 2009
I determined that the thermal fuse in the Gaggia Classic that I am repairing had tripped and it is not re-settable. The fuse has the following stamped on it: MICROTEMP SKMAHD G4A00 184C I believe that is what is the culprit for all of us when the "power doesn't come on." Now, what is the rating of this fuse and where can I get a replacement? The fuse is the small resistor-like, diode-like part in a clear tube mounted against the boiler, and it must be physically cut out of the line to replace it!
Posted on Jul 13, 2008
  • 515 Answers
Try to reset the thermostat fuse located on the boiler, you have to take the top off then you will see the thermostat on the boiler.
Gaggia Classic won't turn on, power switch does not light up
Does the red light on the left switch light up when you turn it on?
Mar 10, 2017 | Gaggia Classic Espresso Machine
How do I backwash my gaggia classic espresso machine?
Do mean backwash like Cleaning out?Normally we use the Vingar Cleans it out.Depends on size of maker,you can run one cup of vingar/1-cup of water to clean system out,then run only water on next step fill your pot run it again.Do this couple times.Hope this answer your question.
Aug 08, 2010 | Gaggia Classic Espresso Machine
Gaggia won't prime
Put a cup under the steam wand and then open the steam valve while turning the pump on. Once you have pumped a few ounces of water out of the steam wand you can close the valve and it will start pushing water through the grouphead.
Michael Ventura Laguna Beach
Oct 11, 2009 | Gaggia Classic Espresso Machine
Brand new Gaggia classic, no water coming through the brew head
take out screen and screen holder,and unscrew piece in head,clean with wire and try,i think its your head plugged out.
Aug 22, 2009 | Gaggia Classic Espresso Machine
Hi i have a gaggia classic there is steam coming but not
Check out this diagram it will give you a start on the machine. I think the problem is the valve above the 2 diffuser screws behind the shower screen.
Aug 20, 2009 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Cleaning the "showerhead" on a gaggia expresso machine
Take it off, and heat up a pan of boiling hot water and add 1 cup of vinegar to two cups of boiling water. Once the water starts to boil, shut off the stove, and put the head in the pan, cover the pan and let it sit for about 30 minutes to 1 hour. Afterwards wash it really well then you will be good to go. The head does twist off
May 16, 2009 | Gaggia Classic Espresso Machine
Ok gagga classic no heat from the machine
1) Hey, played too much Quake 3 and have "full stop", "colon" or "Shift" keys broken?
2) Does the cold water come out, or no water at all?
3) You haven't told where you live, but wanna an address of repair point. So, you must be a millionaire, and no matter if someone supplies you with Sydney, Tokyo, Paris, Buenos Aires address?
Apr 07, 2009 | Gaggia Classic Espresso Machine
Gaggia espresso machine won't percolate
Does the steam outlet give water when coffee swith is engaged. If so when you get a flow going, shut the steam valve and water should eventually pout in the cup. If no water pours thru the steam pipe, it's pump failure or blocked wand. If no water at shower depending on last result same problems. Search web for solution i.e. google "jammed espresso machine"
Aug 30, 2007 | Gaggia Classic Brushed Stainless Steel...
Gaggia Classic Espresso Machine Logo
1,231 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Henry  Thomas
Henry Thomas
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
