How do you make the computer NOT print a banner page before every print on a Gestetner 1805?
  • Anonymous Dec 04, 2008
    Separator page
Look in Control panel/Printers/gestetner/properties, then in the Advanced tab make sure that the "Separator page" feature isn't enabled.
Check if the copier/printer doesn't have that feature enabled in the copier menu.
Also check in the application from where you are printing, that it doesn't have a "Separator page" or "Brief page" print feature.
Posted on Apr 30, 2008
Every time I use my Gestetner to copy, copies come out with lines near the bottom of page.
first you take one print out from your computer see weather the same lines is thir or not if you find the that the print out is good you have to cleane the opticus (Eg. exposer glass reflector 1st mirror 2nd mirror 3rd mirror) - thanks
Mar 12, 2011 | Gestetner DSm615 Digital Imaging System
I have gestetner 645 i installed in windows xp machine with network.now inside the computer priner is on ready condition and i am able to ping printer. but when i print some document so its not display any...
check you have the correct port set up in the printer properties.. the default is usually parrallel or usb if connected with network cable open the printers faxes page on your computer and right click on your printer open the ports tab and check if it is set to TCIP you will have to enter the ip address here. you can get this by going to the copier press the 123 button at top left then press for printer and print the config page..hope this helps A
May 29, 2010 | Gestetner DSm645 Digital Imaging System
Printing a spreadsheet
You should tell us your "Operating System, Spreadsheet Program and Printer" for us to give you a difinitive answer. Whithout this info I will attempt to give you a general answer.
In your spreadsheet program, go to "File" and select "Page Setup" and set your paper size and set your margines and Portrait/landscape option. Your spreadsheet display should show you the paper limits for printing each page. Adjust the columns to the paper size. Highlight all the columns and rows you want to print. Find the menu option to set print area and click it. Now the computer will send the paged information to the printer and print as many pages as needed to cover the print area.
May 31, 2009 | Apple Office Equipment & Supplies
How to set the printer to print banners on continuous paper?
Depending on your printer, you may have to use a 3rd party software that tells your printer to print continuously. If your printer does not support printing full banners without a break in pages you might have to check into getting a printer specially designed for this. Many consumer printers are not meant for custom print jobs, they just use standard paper sizes. If you have your manual, I would refer to that first, but if nothing is mentioned in the manual chances are good that your printer does not support continuous printing.
Dec 31, 2008 | HP OfficeJet G55 All-In-One InkJet Printer
Banner page printing
Go to the webserver in the hp 3800 via the ip-address. There you can switch this feature on.
Jul 08, 2008 | HP Color LaserJet 3500 Printer
Printing issue..please help
That sounds like a banner sheet, in your menus, Specifically a print menu you will find a section with reports, it should be caled banner sheet.
They may have another name for it. But disable that. Also go ont the driver on your computer and look to turn the banner sheet off.
Some call it a print acrivity sheet also.
make sure those pages are turned off on both the printer and on the print driver on the computer.
Feb 24, 2008 | Brother MFC 210C All-In-One InkJet Printer
Printing problem
ISSUE: A blank page prints after every print job using an HP LaserJet series printer. SOLUTION: A separator page may be turned on in the printer driver, within the application, or on the network. Try printing from several applications. If a page prints out in only one application, that application may have a summary page selected to print out. If a page prints out from different applications, a separator page may be turned on in Windows or on the network. Use the following sections to turn off separator pages. Windows 95/98/Me Follow these steps to turn off the separator page in Windows 95/98/Me:
  1. Select Start .
  2. Select Settings .
  3. Select Printers .
  4. Highlight the appropriate HP LaserJet printer icon.
  5. Select File .
  6. Select Properties .
  7. In the section labeled Separator Page, select None .
  8. Click Apply .
  9. Click OK .
Windows NT 4.0/2000 Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  5. Select File .
  7. In the Advanced tab, select the Separator Page button.
  8. Delete the location for the separator page.
  9. Select OK .
Windows XP Follow these steps to turn off the separator page in Windows NT4.0/2000
  1. Select Start .
  3. Select Printers and Faxes .
  5. Right-click on the highlighted printer icon and select Properties from the Advanced tab.
  6. In the Advanced tab, select the Separator Page button.
  7. Delete the location for the separator page.
  8. Select OK .
Software or applications See documentation for the specific application that is printing a separator page. The following steps are an example of how to turn off the summary page in Microsoft(R) Word 97:
  1. Open Word 97 .
  2. Select File .
  3. Select Print .
  4. Select Options .
  5. Deselect Document Properties in the Include with Document section.
  6. Select OK .
Novell environments Banner pages can be sent to the printer in several different ways in a Novell environment. The following instructions detail several ways to disable the banner page. NOTE: Banner pages can also be sent from the HP Jetdirect device itself. This page can be enabled and disabled through a telnet session to the HP Jetdirect device. The telnet banner will only print in an lpd/unix ® environment. Novell's Capture Command To disable a banner page using a Novell DOS capture command at a system prompt, type the following commands: capture L=x Q=queuename NFF NB NT TI=x where:
  • L = x -- The value of x would be 1, 2 or 3 depending on the lpt port being used.
  • Q = queuename - The value of the queuename would be the Novell queue setup for this printer.
  • NFF -- No form feed.
  • NB -- No Banner.
  • NT -- No Tabs
  • TI = x -- The value of x would be the timeout amount in seconds. NOTE: If the client workstation is restarted, and if a capture command is part of a login script that is being used, these settings will be reset.
Printer Properties The banner page for Novell networks can also be enabled or disabled in the Printer Properties using the following steps:
  1. To open the Printers Folder ; click Start , Settings, and Printers .
  2. Right-click the appropriate HP LaserJet printer icon and select Properties .
  3. Select the Printer Settings , or Capture Settings tab. The banner page can be enabled or disabled here.
NetWare Clients Follow these steps to disable the banner page for Novell NetWare clients:
  1. Right-click Network Neighborhood and select Properties .
  2. Select the Configuration tab in the Network window.
  3. Highlight Novell NetWare Client and select Properties .
  4. Select the Default Capture tab. The banner can be enabled or disabled here.
Feb 23, 2008 | HP LaserJet 1010 Printer
Banner printing
got to be a setup problem. in your printer program there is a page for margins, page breaks. set all for zero or disable page breaks. as far as vista goes, personally I never liked it. I am running firefox and have been for the past three years. It doesn't have all the problem back doors like windows internet explorer. rarely do I ever get patches for the program - it just don't need them.AND firefox is completely compatible with 99% of all running programs.
Sep 11, 2007 | HP Photosmart 2610 All-In-One InkJet...
Banner Printing
Hi Thank you so much for the best information wth banner design. i got my banner design method on here http://www.thewebpole.com/ @ from the domain name processing, with the free services of hosting, and mosr services like, * Photo Album
* Quick Blogcast
* Hosting with site builder
* Personalized Email Account
* Starter Web Page
* "For Sale" Page
* Parked Page w/ Domain
* Domain Forwarding & Masking
* 100-Pack Email Forwarding
* Total DNS Control
* Change of Registration
* Status Alerts
* Domain Locking
Jun 18, 2007 | HP Deskjet 6940dt InkJet Photo Printer
Deskjet HP 6940
this might be a software problem also. please specify which software you are using to print these banners. Thanks
Jun 12, 2007 | HP Deskjet 6940dt InkJet Photo Printer
124 people viewed this question
jasbo
jasbo
