TRYING TO LOCATE POWER SUPPY BOARD FOR AKAI LCT3701AD Part number E7801-P02003
  • Anonymous Jan 04, 2009
    the sound is gone also bad piture
  • Anonymous Mar 10, 2009
    I need the power supply for scott same as Akai E7801-P02003 or schmatic .The unit has bunt surface mount devices
    President:
  • 2,267 Answers
It does not seem to be many of these service parts around.
The only way to get them working again is to fix them to the component level.
I could fix it that assembly for you.
Let me know.
Posted on Apr 30, 2008
BLUE ARC WHEN TURNING ON AND OFF NEAR POWER SUPPY CORD
going to have to quickly look inside a turn on to see where and what==do not keep doing this.
Aug 26, 2012 | Akai Televison & Video
What is the value of a resistor, location is RY801S. It is on the convergence board with a flyback. Akai projection TV model# PT4250A, thanks for listening!
I have a 50" Samsung DLP Rear-Projection HDTV that has the RY801S location number on my Power Board. The Power schematic shows a resistor with value 8.2M@1/2W
Aug 09, 2010 | Akai PT4250A 42" HDTV
The sound is perfect but no picture although occassionally when switching on the picture appears for a second or so. again on occasion a amall glow will appear centre bottom of screen
Call Zenith Exchange Moduel 1-800-632-6637,Replace the power suppy board the one that has FBT flyback transfomer on it ,It will have Board number on it.I have used this company in the Past they are a good company when it comes to replacing board then to try and fix it yourself.
Oct 05, 2009 | Zenith IQC50H95W 50" Rear Projection...
The TV worked fine until I moved it to my new place of resident. When you plug the init in the wall, the one power LED doesn't come on. Unit worked fine until it was moved and it was handled with care. The...
we both know the power led, means i have power, so trace the power, get a meter and test the TV. See if the inside solder connections are getting power, by the way make sure you know the schematics if the board isn't labeled you can fry it.
Aug 25, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Part Number for AKAI PDP4206EA
Here are some links for most of the boards for this Akai model # PDP4206EA from a major parts distributor:
Akai PDP4206EA Replacement Part ATSC Digital / HD Tuner Board
Akai PDP4206EA Replacement Part Main Board Assembly
Akai PDP4206EA Replacement Part NTSC Analog Tuner Board
Please note: The X-SUS and Y-SUS boards and power supply board are no longer available and the video board is part of the main board assembly. Hope this information helps.
Feb 04, 2009 | Samsung HLR5067WX 50" Rear Projection HDTV
Akai replacement parts
You are not likely to find the board easily, but you should be able to replace the convergence ICs relatively easily. Look at the board. Try resoldering the pins on the STK ICs. If that fails to resolve your problem, replace the ICs. There may be some pico fuses located close by or low valued resistors that may be open. Check for those as well.
Keep us posted.
Dan
Jul 23, 2008 | Akai PT5598HD 55" Rear Projection...
Trying to put a mother board together need help
you need the correct board for your model Samsung has alot of replacement boards that are all simillar but you need the exact one for your model number TV
Jun 21, 2008 | Samsung PCJ522R 52" Rear Projection...
Vizio on the fritz
yes it it is the sub part. It is the IC's that pop the way to prove this is to measure the voltage to this board Vs, VE, Vsus, and Va these voltages are listed on the panel. if any are low unplug the the connector from the power suppy reapply power and check the voltages again. if they return then it is the board that was unpluged. if not replug the connector and unplug the connector that goes to the Y main board and check again. be sure to remove power each time you unplug and replug the connectors.
Mar 16, 2008 | Televison & Video
Televison & Video Logo
121 people viewed this question
Top Televison & Video Experts
Electro Med Services...
