Question about Bosch 24 in. SHU43 Built-in Dishwasher
SHU43 Bosch Built-in dishwasher
Our dishwasher is approximately 5 years old and we are having trouble with two things. 1. When we start the dishwasher, we get a bad smell from the garbage disposal. It's especially bad when we haven't run it for a couple of days. 2. When the cycle is finished, the "sanitized" light is supposed to be on, but it isn't. A contractor removed and re-installed our dishwasher when we had new countertops installed about 3 years ago, but didn't start noticing the smell until about 1 year ago. Any clues or suggestions would be appreciated. Thanks!
  • 68 Answers
It sounds like your dishwasher does not have an air gap. Newer dishwashers come with an air gap installed, but they can be taken out. A quick fix for this is to:
Check the drain line under the kitchen sink. The drain line is supposed to run from the bottom of the cabinet, and run as high in the cabinet as you can get, (up to the bottom of the counter top) then connect the drain. This is called an air gap, and helps keep a little water in the drain line, which will prevent sewer gases from entering your dishwasher, and garbage disposal.
Please rate this solution.
Posted on Sep 02, 2008
Most problems with smells in Bosch Dishwashers come from failure to have the 20" rise in the drain line between the dishwasher and the drain as the installation manual requires.
My factory installer failed to do this. After looking at the installation manual, which shows a 20" rise, I used electrical ties to hold the drain line 20 inches above the floor. The smell which was causing us to run the rinse cycle every day to get rid of the smell has not been back in five days.
Posted on Aug 20, 2008
  • 552 Answers
Try running citric acid (3 tablespoons) through.
You can get it from a drug store.
Or, run 1/2 cup vinegar through.
Do this in both the dish washer and the disposal.
After doing this try running some water into the disposal and then see if the next time you run the dishwasher if it still smells.
You could be having a problem with water not staying in the drain trap under your sink that is why if you run water and fill the trap, then you will find out if it was the dry trap that caused the smell from sewer gases backing up into the house trough the garbage disposal.
Posted on Apr 30, 2008
My Bosch Dishwasher model #SHU43C06UC/17 in 5 years old and has been working great and all of a sudden last week it stopped working. When you try to start a new load it will start the timer, but the...
Welcome to FixYa.
I would first run a diagnostic to see what error is presented and in turn will direct which way to focus the repair.
Try this and then let me know what you find aa a result...
This diagnostic posted below should guide you, let me know if it isn't clear or you don't understand something.
Sep 23, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
My dishwasher is not draining
have you checked your float valve and float relay switch
Oct 09, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch dishwasher dispencer will not close
Sounds like the actual dispencer mechanisum is worn or faulty either the latch or the catch you can usualy buy the whole unit to replace this, all this does is keeps the tablet in during the initial pre wash then adds the tablet during the wash after 5 mins open the door and drop the tablet in it will still work the same and save cost
Nov 21, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
No hot water
After you replaced the control did it heat?? If so replace it again.
May 27, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24in SHU43, 3 years old
Un plug it for about an hour and  try it again.Its probably built a static problem on your circuit board.
May 25, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher SHU43C02UC
Unplug from mains for 5-10mins. Are you having any power difficultys? sometimes this can crash the controller.
if none of the above possible that its the controller
Jan 03, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch 24 in. SHU43 Built-in Dishwasher Logo
619 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
