My monitor 'popped' a while ago so i sent it back to the manufactorers to get it fixed they sent it back to me within 2 weeks, its come back and ever since its came back the monitor decides to turn itself off, the light at the side stays green but the actual screen itself goes off so i turn it off from the side and turn it back on and it cums on but only for a ridicolously short amount of time, ive noticed if i leave the monitor off for a while it tends to stay on a little longer (a couple of minutes) before it goes out again! its been doing this for ages and its proper doing my head in haha! Help please
They wont give me one though as apparently the warrant has ran out =/
Posted on Apr 30, 2008
    Genius:
  • 3,587 Answers
Well...sounds like if it's under warranty, they owe you a new device
1996 dodge caravan 2.4 code p1294
on dodge motors
fitted a lot of parts and still no better
the fault code clears and comes back as a intermittent problem
could be electrical voltage drop off or heat related failure
i wonder if your 02 sensor ,the catalytic converter
or other related sensors
are causing the fault to come back
if needed .....fit a new air filter...
how the test is determined
P1294-TARGET IDLE NOT REACHED 3.3L/3.8L
When Monitored and Set Condition:
When Monitored: With the engine idling and the transmission in drive, if automatic.
There must not be a MAP sensor trouble code or a Throttle Position Sensor trouble code.
Set Condition: The engine idle is not within 200 rpm above or 100 rpm below the target
idle for 40 seconds. One trip fault.
POSSIBLE CAUSES
INTERMITTENT CONDITION
IAC MOTOR PASSAGES
VACUUM LEAKS
AIR INDUCTION SYSTEM
THROTTLE BODY AND THROTTLE LINKAGE
TEST ACTION APPLICABILITY
Mar 01, 2017 | Cars & Trucks
6 months ago, replaced head gaskets. 1 week later, service engine soon light came on. Tech said it was an oxygen sensor. Cleared code. 3 weeks ago, got oil change, replaced headlights and replaced...
CHECK TURN SIGNAL FUSE.IT COULD BE BLOWED OR YOU HAVE FAULTY TURN SIGNAL SWITCH.BECAUSE BACK LIGHTS AND TAIL LIGHTS SHARE SAME CIRCUIT WITH TURN SIGNAL SWITCH.
Jun 26, 2011 | 1999 Chevrolet Venture
My Hannspree HF199H monitor developed a distinct reddish hue a few weeks ago, I returned it to Hannspree, who sent it back saying it was fixed, but problem remains. Haven't found a website with Mac driver...
Have YOU tried attaching this monitor to another pc, or laptop to check if it is faulty, it may be a fault on your computer.
If it is still faulty on other machines, get back in touch with the manufaturer.
Jul 26, 2010 | Hannspree 22" widescreen LCD Flat Panel HD...
Was having problems with my vx922 lcd display.
Sounds like my problem that I fixed by sending back for repair.
I read that these VX922 monitors are affected by dodgy capacitors on the power board.
I had the monitor for over 2 years. Viewsonic picked it up, yep u guessed it... changed 2 caps on the powerboard sent it back all within 2 days, under warranty. I got my awesome monitor back. Its all good!
Dec 22, 2008 | ViewSonic VX922 19" Monitor Flat Panel
Config screen keeps popping up
A friend of mine had the exact same same problem. I think I fixed it, because it has been 2 hours, without the menu popping up. You need to open the monitor:
- Place it face-down on a flat surface
- Remove the cover of the hinge by gripping it with both hands and gently squeezing and pulling.
- Undo the 4 screws and remove the stand (base)
- Undo the four screws tha hold the cover down (4 corners)
- Use a flat screwdriver to seperate the 2 halves (I used 2, a small one to lift the back, a bigger one for leverage)
You will see a small PCB, fastened by 3 screws, at the bottom (where your menu+on/off buttons are) with a ribbon connection to the screen. Next:
- Unscrew the PCB, and gently lift it out.
- Clean the microswitches and the ribbon cable connection.
- Reassemble the monitor.
To clean microswitches and the connection, I used Kontakt Video 90 spray. There must be sprays on the market where you are. It's basically an alcohol-based cleaning spray. Good for cleaning video/tape/floppy heads, CD/DVD lenses, memory modules, etc.
Dec 07, 2008 | Acer AL1912 19" LCD Monitor
Strange delay.
I'm having the exact same strange delay problem as you.
I fixed my delay when I too took my machine to your girlfriends. LOL!
No seriously.... you solved your delay problem yourself when you UNPLUGGED the power cord from the back of the monitor.
My guess is that when you unplug the power cord, the monitor resets itself. It's only a temporary fix, but, IT WORKS.
1. Turn the monitor OFF
2. Unplug the power cord from the back of the monitor
3. Wait 10-15 seconds or so
4. Plug the power cord back in
5. Turn your monitor ON........DELAY ELIMINATED.
The delay returns eventually, but, I just unplug-n-replug and I'm good to go again.
Apr 07, 2008 | Gateway FPD2275W LCD Monitor
Autofocus problem-Kodak EasyShare C875
I can not get the camara to focas AT ALL!
Mar 01, 2008 | Kodak EasyShare C875 Digital Camera
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
Benq monitor powers off immediately
Try sending monitor back as most Benq monitors come with at least a two years silver warranty. Benq are very helpful and their repairers are quick and polite. You will find their no.s on their website www.benq.com my monitor was experiencing the same and for $10 postage and a one week wait is repaired and working fine.
Apr 07, 2007 | BenQ FP71G 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
