Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
Lx 30 pump seal
Pump seal gone bad
need diagram to install new seal
any help would be appreciated
    Scholar:
  • 68 Answers
We have a Flojet pump 4300-143 which is leaking water out of the slots of the bearing cover (no10 on the parts list). Would you know what is causing this and which parts we would need?
Sounds like the seal has gone bad.most hardware stores carry seal kits and some even install them for a fee.Replace the seal and that should solve your problem.
Hope this helps.
Bob
Mar 27, 2015 | Flojet Pump: 4300-143 12 Volt, 4.9 Gpm,...
I have a antifreeze leak on a 2003 ford sports trac
http://www.autozone.com/autozone/repairinfo/repairguide/repairGuideContent.jsp?pageId=0996b43f802e4058#hd1-1-1 Hi Donna,here's a link to the water pump diagram,is the mating surface that the gasket goes on clean and not badly scraped up from removing gasket,the pump itself is aluminum and could be warped and not sealing good causing it to leak,maybe you need a new water pump,hose on that side isn't leaking?
Oct 12, 2012 | Ford Vehicle Parts & Accessories
My pump motor BN35SS went out and the new motor was overheating. They sent me a new motor that an electrician installed today, but now the new motor does run, but the pump does not run. What do I do...
sounds like a bad impeller. these are a fragile pump and are hard to rebuild, you can take the impeller off and see if it has numbers or on it ? get all of the data OFF YOU PUMP AND MOTOR and do a online search for parts (impeller) good thing the part is cheap, under 20.. you might end up breaking the old one getting it off.. if you cant get it off, search your area for your local pool pump motor repair guy with free testing. make sure you use a new shaft seal on that pump SEAL# 200 .. good luck . i feel for ya .. jay the pool pump guy FLORIDA
Jun 09, 2011 | Hayward Power Flo Lx
Water pump leaking from sseap hole
replace water pump,bearing is bad
Jan 06, 2011 | 2003 Pontiac Montana
Seal leaks on my power flo lx hayward pool pump
The seal can be replaced with either a 2131 or 200 seal from any pool store in your area. Most can offer tips on how to replace the part if you need guidance. The seal should be under $20 and could be as little as about $5.
Aug 21, 2010 | Hayward Pool Products Hayward Power Flo LX...
Diagram for for power steering pump high side
what year? what engine?
Installation
  1. NOTE: If a new power steering pump is to be installed, the unions that are supplied fitted to the pump should be removed and saved for future use.
    Using the special tool, install a new O-ring seal.
    1. Push the new O-ring seal onto the special tool.
    1. Locate the tool over the union and ease the O-ring seal onto the union.
Oct 07, 2009 | Mercury Cougar Cars & Trucks
Power steering line leak for 93' taurus lx at pump
did the hose get cracked or crimped when it was replaced may need new hose
Oct 06, 2008 | 1993 Ford Taurus
Hobart lx 30 pump seal
may have a leak on water pump. Where could it be coming from.
Apr 30, 2008 | Dishwashers
can you provide a serial number please?
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
116 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
