I want to program my remote control to work with my direct t.v.
  • 552 Answers
Look in the user manual for your remote.
You should find a table with brands and types of devices.
Your direct tv should be listed as such.
There will be a number code for the direct tv that you will need to program the remote with.
The manual should also tell you what buttons to press in order to program.
Otherwise, have only the direct tv receiver ON.
point your remote at it and press the tv button and then the power button on the remote and hold it down while pressing the cursor up and down buttons. (not channel up and down. The up and down are the ones to select other things on the remote with.
When you have the right code the tv will shut off.
After it has shut off stop pushing buttons and then press the power button on the remote.
Your direct tv should now be programmed to turn on and off with the remote.
Note: be sure when you turn various devices on or off, have it selected for that devices you are trying to turn on or off.
Posted on Apr 30, 2008
My remote was working fine until i moved. I have Direct Tv and the remote from Direct Tv works on guide. I bought a new remote from Magnavox but it doesn't work my tv. what should I try? '
You have to program the remote control to synchronize with TV. If you wish to get moredetails; codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 17, 2013 | Televison & Video
Tip
Why Am I Unable To Program The RCA Remote Control To Operate My Components
Why am I unable to program the RCA remote control to operate a component? Why am I unable to program the RCA remote control to operate a component? If you are unable to program the remote control to operate a component, review the following information:
Compatibility
If none of the programming procedures work, the universal remote control may not be compatible with your components, based on the type of infrared technology and the age of the components. Some RCA universal remote controls will only work with components manufactured after 1990.
Distance
If you are testing the remote control after you have entered a code, you may be too far away from the component or you may not have the remote control aimed directly at the component. Because the remote control uses infrared (IR) technology to communicate with components, there must be an unobstructed path between the remote control and the IR sensor on the component.
Code Entry Methods
If the Direct Code Entry method was used to enter the codes for your brand and the unit is still not functioning properly, try one of the automatic code search methods instead. During automatic code search, the remote searches for the correct code to program.
Modes
For the remote control to know which component you wish to operate, you must put the remote control in the correct mode by pressing the corresponding component button.
Combo Units
To program the remote control to operate combo units, such as TV/VCR’s, TV/DVD’s, or TV/VCR/DVD’s, use the combo codes in the Code List to program the individual corresponding component buttons. Once programmed successfully, the TV button controls the TV functions on your unit, and the DVD or VCR button controls the DVD or VCR functions, respectively. The codes in the combo section should be tried first, using the Direct Code Entry method on the TV and DVD or VCR buttons. If this is unsuccessful, use one of the Code Search methods to program your combo unit.
Batteries
Make sure the batteries are new and properly installed.
on Jun 19, 2009 | RCA DIRECTV Satellite Remote Control
Directv Remote RC23 Will not work VIZIO VVV26L
I believe the remote has to be re-programed. Press menu,system setup, remote control, program remote, TV, scroll down to vizio, then follow programming directions. Hope that helps.
Jan 05, 2011 | Directv RC23 Remote Control
DIRECTV Universal Remote Remote Control: need direct tv codes for magnavox tv. codes listed...
Try
http://www.remotes.com/
Thanks
Frank
Live-Tech
1-888-361-8511
http://www.mylive-tech.com.
May 17, 2010 | Universal Remote Control DIRECTV Universal...
I need to program 2 direct tv remotes to operate tv's as well as the direct tv box
here is a link with the code sets for this remote: direct TV remote codes
here is a link to programing guides: Programing a remote
choose your remote type and follow the instructions to program it.
Thanks and I hope I helped. Send a message if you have any questions.
Mar 17, 2010 | RCA DIRECTV Satellite Remote Control
Direct TV remote does not control TV on/off or volume.
I have the same setup like you. Direct TV and Emerson LCD TV. The Direct TV remote stores a limited amount of codes and none worked on my TV. Sadly it's not something you can update. They seem to only stick with the popular codes. Welcome to the "head of the curve" like me. lol
Jan 04, 2009 | Televison & Video
How do i program my remote
I went to the Comcast website and there they have directions to program their remote. The only problem is there are several remotes listed and it is difficult to pick out the one you have so it is a bit of trail and error until you find the right directions.
Feb 07, 2008 | RCA D770 Remote Control
Olevia 232t remote code
Go to Best Buy and buy the DirectTV Universal Remote Control Model RC64 ($20). It will control both the Satellite Receiver and the Olevia TV (Everything on the Olevia except the A-B-C-D Guide buttons). The Remote Control User Guide lists the control codes, four for the Olevia. The codes are:
Satellite Receiver: 00392
Olevia 235-T12: 11610 (last of the four codes listed for Olevia)
Enjoy!
Nick from Ft Myers
Dec 21, 2007 | Directed 434MHZ Remote Control
Need code to program toshiba tv with Direct tv remote
someone esle found this.. and it worked for me
Program AV1 with 20695, program TV with 10765, then switch to AV1, press select/mute, enter 933, and press select
This will allow volume and mute controls while in DTV mode and allow power on and off while in TV mode. This worked for me on the RC32 remote control.
Oct 01, 2007 | One For All URC-3021 Remote Control
Televison & Video Logo
89 people viewed this question
Top Televison & Video Experts
