Three pages printing, the firs one is completed, the second one show only one line and the third page is completed
What printer do you have and from what program are you trying to print from?
Posted on Apr 30, 2008
Every third line is printed showing only the bottom half of the line of letters; what is the problem and how can I fix it?
Print a test page. If it's perfect, then the printer driver is corrupt. Uninstall the driver first before reinstalling the driver. If the test page shows the same problem, then put in new ink cartridges.
Sep 02, 2016 | HP Office Equipment & Supplies
Tip
How to get the page count on a Brother HL-6050
To obtain a page count (also called a meter reading) from a Brother HL-6050 printer, follow the steps below. (This procedure also applies to the HL-6050D and the HL-6050DN models.)
A. When the machine is on and ready to print, press any of the following keys to bring up the menu: Set, Back, +, or -.
B. The first menu heading that appears is Information; press Set to select it.
C. Use the + or - keys to scroll through the Information menu until you see Maintenance.
D. Press Set to select it.
E. The first option that you'll see is Page Counter; press Set to view the count.
The number of pages printed so far will appear on the screen. Once you've seen or recorded this number, keep pressing the Back button until you're back at the Ready screen.
If you would rather have a printout with the page count on it, you can get that instead by simply pressing the Set button three times from the Ready screen. The first time you press it you'll bring up the menus, the second time you'll select the Information menu, and the third time you'll select Print Settings. When you choose Print Settings, three pages of information will print out, showing supply usage, jam counters, and machine settings. On the second page, about halfway down the page under the <Device Status> heading, you'll see the page count. Beneath the page count, you can also find the number of pages printed from each paper tray, as well as the page count broken down by paper size (for example, letter-size paper, legal-size paper, or envelopes).
on Sep 16, 2010 | Brother HL 6050 Laser Printer
I am getting horizontal lines on the printed page. the quality of the print if fine for the exception of the three horizontal lines. The first line is about one inch from the top of the page, the second...
Regularly spaced horizontal lines suggest that there is a defect on the drum in the printer. I would suggest changing the drum to see if that will fix the problem.
Oct 08, 2010 | IBM Network Printer 17 Laser
When i am giving a single page printout it will printout another copy of blankpage
Please open the document, There is probably a second page added to your word document.
Open the file, go to page 2, press backspace.
When you select print option, now check how many pages its showing for printout.
If its showing one page then your file is perfect now.
Nov 03, 2009 | HP Inkjet 1200dn Printer
Hi have a lexmark x2530. printer does not print word doc pages. will only print alignment page.
Please follow the steps given below:
1. Please Load a plain paper.
2. Press and hold the "Scan" button for three seconds.
3. An alignment page prints.
4. Place the alignment page onto the scanner glass.
5. Press the "Scan" button.
6. Once scanning is complete, the cartridge has been aligned for optimal print quality. Alignment must be complete before continuing with any print jobs.
May 06, 2009 | Office Equipment & Supplies
Changed black cartridge. Machine works fine, but
To align the cartridge from the control panel:
Apr 19, 2009 | HP OfficeJet 6110 All-In-One InkJet...
How do you adjust paper feed on a panasonic kx-fl511fax/copier
One of two things is happening ok maybe three. If the machine thinks the size of the paper is not what u are using this could happen. Try:
http://pdf.textfiles.com/manuals/FAXMACHINES/Panasonic%20KX-FL511%20Laser%20Fax%20Machine.pdf
For any adjustment you could make.
The second is the paper is getting picked up a little late. The machine knows it did not print the entire page and finishes the job. Try cleaning the pick op roller.
The third is the page being sent to you is to long. This would likely be from one location only. There machine could be slipping when scanning and "extending" the page it is trying to send.
Hope this helps
Mar 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Will not Print
Try a hardware check of the printer first. To check the hardware of the printer, do the following:
  1. Switch off the printer.
  2. Load one sheet of paper into the paper feeder.
  3. Press the Power button and the Paper Feed button at the same time and hold them both down for three seconds. Then release the Power button only.
  4. When the printer begins to print, release the Paper Feed button. A page will be printed. The page should contain some text at the top and a series of horizontal color lines (cyan, magenta and yellow) below the text, with a thick black line below the colored lines. All the lines should be solid.
  5. When the test is complete, switch off the printer. NOTE: If you do not switch off the printer, it will continue to print.
Sep 24, 2008 | Lexmark X1270 All-In-One InkJet Printer
Prints one page on many pages
I think the problem is now fixed: I reinstalled the HP printer drivers, and made sure to choose HP DeskJet 845c in the printer setup before I printed a document.
Aug 11, 2008 | HP DeskJet 845c Printer
41 people viewed this question
k24674
jasbo
jasbo
