Question about Tomtom One XL GPS Receiver
No gps signal - Tomtom One XL GPS Receiver
  • 9 more comments
  • Anonymous May 11, 2008
    waiting for a valid gps signal
  • Anonymous May 22, 2008
    same problem
  • Anonymous Sep 24, 2008
    lost gps signal
  • Anonymous Oct 26, 2008
    just bought tomtom xl, keeps saying "Looking for a Valid GPS signal" try updating thru TOMTOMHOME for gpsquickfix, says tomtom is uptodate !!, still trying to figure whatz up with it ?
  • dfriedrich Oct 29, 2008
    I travel the same road to and from work - going west in the morning I have a full signal with 9 - 11 satellites - going east in the afternoon I have from 6 -8 and it drops them for 95% of the trip. Plus last night I was sitting still and it showed me going 17 mph.
  • Anonymous Nov 02, 2008
    same problem. It happened after adding a new favorite, I got some error- and no signal since.
  • weiwei Dec 02, 2008
    My unit no signal. I've tried update through TOMTOM HOME, still did not work.
  • drakeca05 Dec 28, 2008
    Having the same problem with a new One XL just purchased, even in the Baltimore/DC area this weekend...whats up?
  • Angel_hall_5 Jan 10, 2009
    Waiting fro a valid GPS signal
  • higgy_123 Feb 06, 2009
    tomtom xl waiting for a valid gps signal for long long time whats up?
  • Anonymous Feb 06, 2009
    gvfhghjgjh
No gps signal
Posted on Nov 17, 2008
Is there a place where i can take my tomtom 920 go to get it fix the tomtom is saying waiting for gps signal and i try everthing quick gps fix dowload reset hold the botton for 15 ninutes nothing and i call tomtom and they say that the only way they will fix it if i san then a recit and i dont have it
Posted on Apr 06, 2009
I dont have gps. the arrow stock in one position and not moving. i really do not know what to do?
Posted on Jan 20, 2009
Waiting for a valid gps signal tomtom xl
Posted on Nov 09, 2008
Why doesn't the GPS pick up a current GPS signal?
You may need to do it outdoors; a building may interrupt enough satellite signal that it (the GPS) won't lock to it (the signal).
If it always says "GPS SIGNAL NOT DETECTED" when it's outdoors, I don't think you're going to get it to ever work. It may have been dropped & the internal antenna damaged.
Jul 26, 2014 | InVion GPS
Gps singal lost
Often, when your GPS is in a "covered" area ... e.g. inside a building, in a tunnel, under a bridge, amongst / under tall buildings, etc... when there is no open space (directly) between your GPS and the satellites, your GPS will loose its satellite signals. If you're in such locations, try to find some "open space" and wait a bit for the signals to be picked up again.
Another common reason why the GPS doesn't get signals, or doesn't get the signals quickly, is because the "latest" satellite positions (locations) have not been updated in your GPS. If/when you connect your GPS to your computer (e.g. using HOME ) and download the GPS satellite (QuickFix) location information, your GPS will have the most recent locations of the satellites in your vicinity/region. With this information, your GPS can pick up the signals more quickly ... instead of having to search/scan around to find the signals ... which can take a bit more time. While your GPS is searching for the satellite signals, it shows the "signal lost" or "no GPS signal" message.
Jan 16, 2014 | Tomtom GPS
Does not pick up satellite signals
The gps device is not receiving signal simply because the strength to receive signal is weak. What you have to do is to reset the gps device by holding the power button for about 15 seconds or there about, then you release it when the gps restarts. It will acquire signal after resetting the device.If it does not acquire satellite signal. You can also try to use the gps in an open space where the gps will be facing the sky, if it does not, then you replace the antenna of the gps device.
Hope this information helped.
Jan 01, 2011 | Magellan GPS 320 GPS Receiver
NO GPS SIGNAL
hi go online and update automatic. it wil receive new info about satts an wil function like before. do this couple of times a year. good luck
Feb 04, 2010 | Tomtom ONE GPS Receiver
No longer receives GPS signal
Does this unit have an input for an external antenna? If you get/borrow another antenna you could see if it starts working. That might isolate the problem to the antenna.
Jan 23, 2010 | Lowrance iWAY 250C GPS Receiver
Can't get a GPS signal for last 24 hrs
I had a similar problem and did solve it with the soft reset (pressing reset button). I have a One XL and there is a small reset button that you push with a paper clip. On the XL 330 you press and hold the on/off button for 15 seconds and the unit should reset.
My symptoms: Would not find a GPS signal. When I looked at the GPS Satellite status (press on the GPS signal strength bars, again on the GPS/battery status) you can see it locking on up to 8 satellites but would still not show a gps signal lock. Normally it only takes 4 satellites to get a gps lock. My other sympton was that when I attached the GPS unit to the computer and operated it with TomTom Home, it worked fine and locked on to the gps signal quickly (even inside my home). But it would never (at least for 30 minute trips) lock on to a gps signal. After doing a reset it began working normally and locked on to a gps signal after finding 4 or more satellite signals.
Aug 06, 2009 | Tomtom XL 330 Car GPS Receiver
Waiting for valid gps signal
The GPS needs at least 3 satellite signals to operate.You are probably in a bad reception area. Move around a bit and try again until you see a signal array of 3 or more!
Jun 30, 2009 | Tomtom One XL GPS Receiver
Tom tom one wont detect gps signal
my tomtom wont get a signal and is saying are you in a building?
Jun 18, 2009 | Tomtom ONE GPS Receiver
Navigo sy885 not receiving gps signal
I had this with mine. remove the back of the gps and simply unplug the antenna re plug and try system. Worked with mine. Chris
Nov 04, 2008 | Tomtom Navigator 5 1H50.082 GPS Receiver
Tomtom One XL GPS Receiver Logo
1,118 people viewed this question
Top Tomtom GPS Experts
LP
Martin Murray
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
