Question about Janome Memory Craft 9000 Computerized Sewing Machine
How to raise feed dogs? - Janome Memory Craft 9000 Computerized Sewing Machine
  • 1 more comment
  • jesster348 Nov 08, 2008
    i manually raised the feed dogs as indicated, but it seems that they won't stay high enough to feed the fabric through. the raise/lower switch definitely does not work and they did seem to lock in place after i manually turned the handwheel, but just aren't up high enough still to properly move the fabric through. any other suggestions?
  • gtaylor7 Jan 13, 2009
    feed dogs will not stay up when manually turning wheel one revolution. they will move up a little bit yet they are still below the table. now what?
  • Anonymous Jan 20, 2009
    I have the same issue with the feed dogs on my machine....can the lever that is suppose to raise the feed dogs just worn out?
    Also, the manual I do have suggests that the thread control be set at 'auto'. How does one change the machine from manual to auto. I see the indicator, but don't know how to re-set to 'auto'. I would appreciate any information you could give me on this.
    Thank you in advance.
  • Janome Master
  • 1,388 Answers
Remove the needleplate and clear out any lint or felt deposits from between the teeth of the feeddogs, give the entire bobbin case area a good clean if it needs it too !!.
If that did not solve the troubles, there is a switch to raise/lower feeddogs, once reset to up position, one full revolution of the handwheel is needed for them to engage and raise.
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on May 26, 2008
I lowered the feed dogs on my Juki TL-2010Q to free motion quilt and they won't raise. I cleaned under the throat plate. Help?
Have you tried sewing with it since you "raised" the feed dogs? The feed dogs will not raise until you begin to stitch.
Mar 12, 2017 | Juki Sewing Machines
Can't get plate screw loose. My feed dogs won't come back up
Difficult to respond without knowing the make & model.
Removing the needle plate generally will not allow you to raise the feed dogs. There is a lever, knob, or something on the machine that should raise the feed dogs. Frequently, access to the actual feed dogs is through the door to the bobbin mechanism.
Nov 13, 2016 | Sewing Machines
Feed dogs will not raise up to feed the material. I checked and the position on the back is in raised position
if the feed dogs are in the raised position then the feed dogs need to be checked to see if they need a adjustment or need to be replaced
Apr 07, 2016 | Sewing Machines
Janome 3050 feed dogs wont come back up
Dropping the Feed Dog
The feed dog can be lowered with the drop-feed lever for sewing on buttons etc.
  • Shift the drop-feed lever to the right to lower the feed dog.
  • Shift the lever to the left to raise the feed dog, it will return to the up position when the machine is started.
NOTE:The feed dog should be in the up position for regular sewing. Turn the handwheel toward you to check if the feed dog comes up after setting the lever in the up position
JANOME DC 3050 User Manual Page 9
May 24, 2015 | Janome Sewing Machines
Janome/New HomeHF 2022 How do I raise and lower feed dogs
With the straight stitch set to zero the feed dogs should be down. To use a different number will make the feed dogs rise above the plate.
Oct 23, 2014 | Sewing Machines
How do i raise the feed dogs on my singer 30215 machine
Slide of the the little table with the accessories in.There is a feed dog adjustment lever at the back of the machine. sliding the lever to the 2 filled in arrows pointing down, will lower them and the 2 filled in arrows pointing up will raise them. The feed dogs will not rise up if you do not turn the hand wheel manually, even if the lever is slid to the right.You must make a complete turn of the wheel to raise the feed dogs.
Best wishes.
Jun 29, 2014 | Euro-Pro Shark 9110 Sewing Machine
Can't raise the feed dog on Quantum XL 1000
If I remember correctly you have to raise the feed dog then turn the fly wheel 1 revolution to lock them in place
Feb 07, 2013 | Singer Quantum XL-1000 Computerized Sewing...
Singer Sewing Machine model #2638 Does not feed fabric
Here is a link to page 22 of the manual. It shows you where to flip the lever to raise the feed dogs. If your feed dogs are not grabbing fabric your feed dogs are lowered.
https://www.manualslib.com/manual/1050311/Singer-2638.html?page=23#manual
Sep 20, 2012 | Sewing Machines
Feed dogs will not raise, I have lifted the presser foot, pushed the feed dog lever to the raised positon and turned the handwheel till i heard the click. They still will not snap into place in the raissed...
Hello
First, lift the presser foot; next, push the feed dog lever to the raised position; finally, turn the handwheel towards you until you hear the feed dogs snap into place
If it doesn't, you will have to run a maintenance check on your feed dogs,
Unplug the machine and examine the feed dogs. The newer machines have metal feed dogs, but older models may have rubber ones, which often need replacing. Examine the feed dogs and check for damage.
Remove the throat plate, which is the covering over the feed dogs, and clean it with a soft cloth. Use a small soft brush to clean the feed dogs. Make sure to remove all lint and thread from the grooves of the teeth. Some machines have an adjustment that lowers the feed dogs for specific sewing procedures. They should be in the raised position for better viewing during the cleaning process.
Clean the area around the feed dogs with a soft brush. Compressed air is a good choice to use in the small tight areas.
Wipe down all areas with a clean, lint free cloth before replacing the throat plate.
Prepare to clean the feed dogs and all other areas that lint may accumulate on, after every project. Your sewing machine will last longer and need fewer repairs if kept clean and lint free.
Always unplug the sewing machine before any type of maintenance or cleaning.
Never use a sharp tool when cleaning the feed dogs as this may cause damage to the sewing machine.
Apr 16, 2011 | Singer 7436 - INGENUITY
Feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Janome Memory Craft 9000 Computerized Sewing Machine Logo
227 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
