Question about Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro 97 Programing Problem
I currently have attempted to load my Public Safety Talk Group ID using the owners manual instructiions.However after I load the DEC ID Number & hit scan. I get the All channels are locked out.
Any help you can be would be greatly be appreciated in advance.
Bob Goodwin
  • 2 more comments
  • Robert Goodwin May 05, 2008
    have attempted to load the Talk Group Channel ID's per the manuals instructions.I make shure the Lock-out for the Channel is not locked out when I loaded the Talk Group Id's. When I hit Scan it states all channels are locked out evern though I haven't' locked them out.
    I have no problem with the raw frequencies example after being entered & them scanning.I just can't lock out the Public Utilities;Public Works; Traffic Enginering Etc out.I just want to listen to the Public Safety Talk ID's.
    Any help you can be would be greatly be appreciared in advance.
    Robert S Goodwin
    yaknowbob@cox.net
  • Robert Goodwin May 06, 2008
    Thanks for trying. This didn't resolve my problem.When I loaded the Talk 5 Digit ID's
    & I have made sure that the Lock Out is not on on any of the Talk Group ID's ; I hit Scan & it Reverts to the Radio Frequencies for the Channels( Example 856.21250 ) & It doesn't scan the Talk Group ID's.(Example:
    55568.
    Also I show no channels Locked Out (LO) at all during scan review.
    Bob Goodwin
  • Anonymous Jan 26, 2009
    i have the same problem nothing else on the scanner is a problem except for trunking and ive had it for a year now ive even went to fire stations and they couldnt help me either
  • Anonymous Feb 23, 2009
    I have the same problem. Can't get the trunking to work.
    Brigadier General:
  • 3,614 Answers
Try to remove the battery within 72hours.. to reset the current settings.
Posted on Jun 08, 2008
    President:
  • 2,712 Answers
Hello Bob,
Download Win97 from HERE or HERE.
To read more details about Win97, please click HERE.
THIS white paper on LCR programming on your Pro97 may also prove useful.
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
Posted on May 05, 2008
  • Swilin Sampson
    Swilin Sampson May 05, 2008
    Locking out Talkgroups
    The scanner allows you to lock out individual talkgroups while you are
    scanning. This useful if you do not want to hear radio traffic
    on that channel. While you're listening to a transmission press the
    L/OUT button to lockout that channel, you can unlock it again later by
    following the steps below.
    You can also lock out talkgroups without hearing radio traffic
    on them first. You might want to do this if you are in Duluth and only
    want to listen to Duluth Police and not any of the other city police
    departments that are in the same scan list. To do this PGM, enter 000,
    press PGM again, and then press the orange T button. On line one of the
    display, to the right of "ID Bank 0-" is the scan list you are
    currently looking at. Press the T button until the scan
    list containing channels you want to lock out is displayed.
    On the right-side of line 2 on the display you will see "lo" or "LO".
    "lo" indicates the talkgroup/channel is not locked out, "LO" indicates
    that it *is* locked out. To change the lockout state of a channel press
    the L/OUT button.
    Press the up arrow button to look at all of the talkgroups/channels in
    the current scan list. After you've checked all of the entries in the
    list you can press T to go to the next scan list or press SCAN to start
    scanning again.
    Unlocking Talkgroups
    If you have stopped hearing any radio traffic on channels that
    are normally quite busy you might have accidently locked the channel
    out.
    To see what channels you have locked out (and to unlock them)
    press PGM, enter 000, press PGM again, and then press the orange T
    button. On line one of the display, to the right of "ID Bank 0-" is the
    scan list you are currently looking at. Press the T button until the
    scan
    list you want to check is displayed.
    the L/OUT button.
    list you can press T to check the next scan list or press SCAN to start
    scanning again.
  • Swilin Sampson
    PS...found the above info about TalkGroups from the net with regards to a particular county. Just disregard the place names and read in context.
    Cheers!
    Genius:
  • 3,422 Answers
Please don't forget to rate or accept my solution as fixya once this fixes your problem.
1) Turn off the scanner and then turn it on again.
2) When 'Multi-system Trunking Scanner' appears, press PGM.
3) Press 1.
This will reload the pre-programmed frequencies erased by the re-init. Press scan and it'll be as new as outta the box!
  • Priya darshan May 05, 2008
    This is another one you can try.
    press the scan button then press the numbers 12345 and 6, see if this
    changes the numbers at the top (showing which banks you want to scan
    through)
    if this doesnt seem to change, press the manual button
    multiple times and see what kind of channels you hvae programmed in. if
    they're all 000.000000 or such, or all have l/o at the bottom, i
    believe it's the S/S button (says lockout over it)
    press this after choosing a manual channel that you want to be able to scan through.
  • 3,037 Answers
Clearing all locked-out frequencies in a search bank
1. Press SRCH.
2. Select the search bank in which you want to clear all
locked-out frequencies.
3. Press FUNC then press L/OUT. Lockout list appears.
4. Press FUNC then 6. Clear entire list ? Press 1 to clear all, any other key aborts appears. Press 1 to clear all locked-out
frequencies. List cleared. appears for about 2 seconds.
Press any key other than 1 to cancel clear.
Let me know how this goes and if you need any further help.
thanks
Posted on May 04, 2008
  • 1 more comment
  • Benjamin Patri
    Benjamin Patri May 05, 2008
    have you tried resetting it by removing the batteries at all?
  • Benjamin Patri
    Benjamin Patri May 21, 2008
    Locking Out Talk Group IDs
    Note: You can only lock out talk group IDs when the scanner is in the
    closed mode (see "Open and Closed Modes" below).
    1. Press PGM.
    2. Press TRUNK.
    3. Press FUNC, /\ or \/ to move the desired bank.
    4. Press /\ or \/ to select the ID memory.
    5. Press L/OUT to lock out the ID. L appears.
    6. To remove the lock out from a trunking ID, manually select the ID
    memory, and press L/OUT until L disappears.
    Reviewing Locked-Out Talk Group IDs
    Note: You cannot clear all lockouts from a talk group at the same time.
    1. Press PGM then TRUNK.
    2. Press FUNC then L/OUT. The locked out ID appears. If the ID memory
    bank has no locked out ID, you hear the low beep tone.
    3. Press FUNC then /\ or \/ to select a search bank. Or, just press /\ or
    \/ to search for any lockout IDs in a bank.
    Clearing Talk Group IDs
    1. Press PGM, then TRUNK.
    2. Press FUNC, /\ or \/ to select ID memory.
    check out this link
    http://support.radioshack.com/support_el...
    3. Press FUNC then CL.
  • Benjamin Patri
    Mode Open Closed
    PL and DPL Accepts any PL and DPL. Accepts only the PL or DPL
    stored in the channel.
    MOT/ED/LTR Stops on any transmission. Only stops on transmission
    If the ID is stored, displays if the ID is stored.
    the text tag. Otherwise dis- Displays the text tag.
    plays the talk group ID.
    Changing the Open/Closed Mode
    1. Press MANUAL.
    2. Press FUNC then /\ or \/ to select the channel storage bank.
    3. Press FUNC then 2. Bank OPEN or Bank CLOSED appears. After that
    message disappears, the 10th digit on the top line of the display
    changes from (+) to (-) or vice versa.
    4. Repeat Steps 2-3 for each bank.
    Genius:
  • 1,665 Answers
//www.tand using your new product
www.radioshackhttp://www.thiecom.de/ftp/realistic/pro97.pdf.com
Please read this user’s guide before installing,
setting up and using your new product
www.radioshack.com
Posted on May 21, 2008
Radio shack pro 405 scanner
Here is your downloadable owners manual with complete instructions.
Radio Shack 20 405 User Manual
Jun 05, 2014 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro 97 - Talk Group Problem & All Channels Locked out_ Re-Posted
restore the factory defaults .turn off n then on agn after 5 mins.this may help.wish u success bye.
Jun 07, 2008 | Radio Shack Pro-97 Handheld Scanner
I can't figure out how to program my Radio Shack Pro-97 scanner!
If you can't program the unit using the instructions in the owner's manual, there's no way anyone can post a workable answer for you here. I suggest that you join a Yahoo users' group for the PRO-97. That way you can pose a problem to a group of users, plus get one-on-one assistance in programming your scanner.
Bill B.
Listening in since the 6y0's.
Oct 10, 2010 | Radio Shack Pro-97 Handheld Scanner
I have a pro 97 scanner and need a pc cable to program it. where can i get a cable. or is there a cable built for a gre scanner that will also work with the pro 97. mike s. email mastokka@hickorytech.net
You need either the Radio Shack PC interface cable 20-047 or the GRECOM USB cable. Both are, unfortunately, out of production and not available through any outlet that I could find. You might want to check with Radio Shack stores in your area, though, as one or more of them might still have the cable in stock. Another possible source is the PRO-97 owners group on Yahoo.com.
Bill B
Aug 19, 2010 | Radio Shack Pro-97 Handheld Scanner
How to program a radio shack pro 163 police scanner
The 163 is a trunking scanner, so programming instructions are long and detailed, and they vary for each type of trunking system. Programming instructions are best explained in the factory operating manual. If you don't already have it, you can download/print the manual here:
http://www.scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/PRO-163-164-OWNERS%20MANUAL_2000164_PM_EN.pdf
You may also want to join a users group for the 163. Check Yahoo or just Google PRO-163.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
The site also has information that explains the workings of trunking systems, links to users groups, and a lot of other useful scanning information.
Bill B
Jul 04, 2010 | Radio Shack Pro-97 Handheld Scanner
Need instructions on programing Radio Shack Pro 94
Radio Shack has a website will ALL their manuals... Click HERE and you'll find the pro94 on the list and it will give you a full manual.
Have a blast!
May 25, 2009 | Radio Shack Pro-94 Scanner
Pro-97, only want to listen to EMS
Not being completely familar with the radio system you use... i would presume that your dispatch uses a subaudio tone to "turn off" the squelch on the radio you use as an emt.... if you know that tone make sure it is turned on for the scanner on the frequency that you are using. i presume the id numbers are specific to areas of the city.
Robert
Sep 12, 2008 | Radio Shack Pro-97 Handheld Scanner
Pro- 97 scanner
Here is a link to a site that has a large volume of info and knowledgeable people on scanning, Post your question there and you'll probably get more info than you really need,,,seriously, they use these things everyday and I'm sure they can steer you in the right direction. Good luck with it,,, Mechanic
http://www.radioreference.com/forums/forumdisplay.php?f=6
Jan 15, 2008 | Radio Shack Pro-97 Handheld Scanner
Radio Shack Pro-97 Handheld Scanner Logo
679 people viewed this question
Top Radio Shack Radio Communications Experts
Robert McClure
John
John
Greg Cann
Greg Cann
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
