Is there a way to set up Samsung SCX-4720F (MFP) to save all incoming faxes onto a computer instead of printing
    Genius:
  • 3,587 Answers
Sure..it's in the settings on your print manager s/w..usually it's listed as an option for Save as a file..and then you select the type of file..
Posted on Apr 30, 2008
My all incoming fax is going to machine memory, my machine is samsung SCX-4521F, please advise me how can i solve the same & i wanted to take incoming fax in directly computer, kindly tell me setting...
my all incoming fax is going to machine memory, my machine is samsung SCX-4521F, please advise me how can i solve the same & i wanted to take incoming fax in directly computer, kindly tell me setting of the same. Thanks
Jul 09, 2011 | Samsung SCX 4521F All-In-One Laser Printer
Samsung SCX 4521F: Incoming faxes 'receiving' but fail to print
Has the main board been changed??if yes the liu board(modem) board needs replacing.
Jul 18, 2009 | Samsung SCX 4521F All-In-One Laser Printer
I have Samsung fax & copy machine, SCX 5312F,
Press "Menu / Exit", then "System Data" on the one-touch dial keypad. The display shows the first system data option "Cassette Paper" on the upper line of the LCD display. Scroll through the options by pressing ^ until you reach the option "Message Conf." Then press < or > to select your choice. Options are: ON, OFF or ERR (prints only when a transmission is not successful). When the desired selection is displayed as indicated by the blinking cursor on the lower line of the LCD display, press "Mode / Enter" to save the selection. Press 'Menu / Exit" to exit the menu or "Stop / Clear" to return to standby mode.
Source: Samsung Laser Facsimile User Guide - Digital Laser MFP - SCX-5312F, pages 6.2, 6.4 and 6.5
Jun 12, 2009 | Konica Minolta bizhub C250 All-In-One...
Fax not receiving
if there are "empty toner"
the printer not print received fax until cartridge replacement.
May 21, 2009 | Samsung SCX-4828FN All-In-One Laser...
When i receive fax,my samsung 4216f didn't print it just save it in momery
receiving incoming fax in the memory, displaying "memory received" but never print out.
I wonder if there is a way to retrieve fax from memory and print out manually?
Feb 22, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Samsung SCX-4720F reads "SCANNER LOCKED" and won't copy or scan.
the lock is underneath the scanner where the printed paper gets delivered. when you reach in to get a printout you more than likley have pushed it into the lock position. Once you unlock that blue button by pulling towards you, switch off the printer and again switch on the printer.
Jan 06, 2009 | Samsung SCX-4720FN All-In-One Laser...
Need a printer driver for Samsung SCX-4720 for apple mac
OK, this answer might actually help you!
We just had the same issue with the same printer on 10.6.
Make sure all your OS updates are installed and then go to add a new printer in System Preferences (Printer and Fax section) and hit the "+" button.
If your printer is plugged in and turned on you should see it as a USB printer in the window that pops up.
Select (click on it) that printer one time and then click on the auto select driver drop down and choose to select a driver. Choose the following driver "Samsung ML-6100 - Gutenprint v5.2.3" and hit add. This driver fixed all of our problems.
No thanks to the USELESS Tech Support of Samsung. I despise companies that don't give a **** about supporting older products! Sorry, I'm in a bad mood!
Oct 16, 2008 | Samsung SCX-4720F All-In-One Laser Printer
I need a manual for my printer now
You can get the manual from http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=06010300&prd_mdl_cd=&prd_mdl_name=SCX-4720F
Jun 28, 2008 | Samsung SCX-4720F All-In-One Laser Printer
Not recieving only in memory
My good friend:
The only reason why your unit stops printin faxes is because the toner cartridge is nearly empty. Th e unit will then try to conserve the remaining toner for printing and copying. Follow this steps to program the unit to print all faxes, even with toner low:
When the toner cartridge is nearly empty, the machine shows
the “[Toner Empty]” message and continues printing except
incoming faxes. In this case, incoming faxes are saved in
memory.
However, you can set the machine to print incoming faxes, even
though print quality is not optimal.
1 Press Menu until “Machine Setup” appears on the display.
2 Press the scroll button ( or ) until “Ignore Toner”
appears on the bottom line and press Enter.
3 Press the Scroll button ( or ) to select “On” or “Off”.
Select “On” to ignore the [Toner Empty] message.
Select “Off” to stop printing incoming faxes when the
message appears. This is the default setting.
4 Press Enter to save the selection.
5 To return to Standby mode, press Stop/Clear.
Be blessed
Jun 15, 2008 | Samsung SCX 4521F All-In-One Laser Printer
66 people viewed this question
jasbo
jasbo
