Question about Durabrand HT-3915 System
Same prob i also have the same problem my dvd is connected via scart to my tv i have nothing on my tv to connect the system to i have red and white on my dvd and also video so will this system work
  • ukbill Jun 23, 2008
    i took the home theatre back to asda'a there are not many tv's left that take a 5.1 surround sound like these anymore so what asda is selling is absolete take it back
  • Anonymous Nov 11, 2008
    i have no sound on my tv
I have just bought a DURABRAND SA51AR home theatre system, to go with my DURABRAND 2127N tv. and DURABRAND CG5660-M freeview set top box. i have connected all my output leads obviously the speaker ones. but my input i have only one red yellow white jack on my tv and three sets of red and white jack leads with home theatre system. cant get no sound no matter how many times iv swapped the input leads ... any idea s whats going wrong :oS :(
Posted on Jun 22, 2008
How to connect Sky digibox & DVD recorder to Samsung UE46ES6300 TV
Buy 2 hdmi leads and use one to connect sky TV decoder to the hdmi 1 socket on the back of the TV and if your DVd recorder has an hdmi socket attach it to hdmi 2 or leave it on the scart socket
as you don't name your dvd recorder the connections available are unknown
hdmi is the best followed by component which requires a 3 cable lead 3 video (video is red green blue plugs ) audio is red and white which is a 2 wire lead which all are needed to get video and audio to your TV
scart is the lowest quality along with composite video
Jul 04, 2017 | Televison & Video
Connecting Alba DVD to Toshiba TV
If the TV has the red, white and yellow sockets on it you can use an adapter. It's a scart plug on one end (for the DVD player) and 3 little round sockets on the other, usually red, white and yellow, sometimes red, black and yellow, like this:Amazon.
Then you need an audio/video lead with red, white and yellow plugs on both ends like this:Amazon
Or one of these:Amazon
You could also use a multi socket scart adapter to add more scarts to your TV:Amazon
Jan 23, 2012 | Toshiba Televison & Video
I am trying to hook a surround sound up to tv. Can't get sound out of surround sound when watching tv but can when playing dvd
if you have a pair of phono connections (red and white) on the rear marked audio out, connect them to the aux in on the surround system and select the aux output on the surround to get the sound from the tv.
failing that connect to scart 2 as this should give audio out via the scart cable and select tv on the suround to get sound.
Feb 07, 2010 | Hitachi 43FDX01B TV
Hooking up wii and dvd to tv. i have Direct TV, a DVD player and need to hook up a Wii console. i have the direct tv DVR connected to the DVD player by coaxial cable and the yellow/red/white cables...
does your tv have scart sockets?
if so you can buy this adapter that on one side is the scart socket and the other is the yellow red white sockets
something like this
http://cgi.ebay.co.uk/Switched-SCART-Adapter-Red-Black-Yellow-RCA-Socket_W0QQitemZ260520047480QQcmdZViewItemQQptZUK_Computing_CablesConnectors_RL?hash=item3ca8347378
Dec 30, 2009 | Nintendo Wii Console
Connecting the dvd player via a scart cable
If you select component in on the tv, this should give you a picture,using the current set up. As for audio, depending on the tv, have you used audio in on the tv, or audio out?
It sound obvious but I (even after 5 years+ of installing tv/vcr/dvd) still get caught out with input and out put.
I am unfamiliar with Sansui dvd, if it has a scart connection on the back then yes you can connect to a spare scart on the tv. If it has the single yellow phono for video and the red/white phonos for sound, you can buy a scart to phono lead and use that, not to confuse with the component(blue/green/purple) connections. You cuold also connect the yellow/red/white phono to the same on the tv front/side or rear if available.
Aug 27, 2009 | Televison & Video
UMC 19in TV with built-in DVD player - model L19/7TCD
Try connecting earphones or headphones to the 3.5mm Headphone socket on the TV and check this works correctly, i.e hear TV when watching TV, hear DVD when watching a DVD etc.
If all is OK, purchase a 3.5mm Jack to L/R Audio/Phono cable. Connect the 3.5mm jack in to the headphone socket on the TV and connect the red/white phone ends to the 5.1 surround system.
It should solve it. SCART out is not always live in all sources so is not a reliable way to connect.
May 22, 2009 | Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Not sure how to connect surround system to tv
Hi
Look on the rear of the tv and there should be an audio out connection coloured red and white and this will be a phono connection ( 2 small holes one red and one white) using a phono lead connect this to the same connections on the surround system only this time this will be an audio in connection select the tv channel on the surround system and ensure the tv is on and off you go. Try this and see how you go.
Dec 28, 2008 | Panasonic Televison & Video
Connecting to tv with directtv
The usual way to connect a dvd is via the scart socket as dvd players seldom have an rf output (aerial type output) if you tv does not have a scart there may be phono plugs usually marked red,white,yellow the yellow is video(picture) the other two red/white are audio left and right.
Sep 23, 2008 | TruTech TT320
Question regarding audio connections Akai 30" LCD TV
a switch box is needed the s video shares the red/white audio with the yellow rca that is being used already
May 07, 2008 | Televison & Video
Connected wii consule to bush ws6671 tv
Hi.
If you are connecting via scart lead use scart 1 on the rear of tv set & switch off any other devices connected to tv set.
If you are connecting via phono sockets red, white, yellow,
You will need to select the input on the remote see if remote has AV button you will need to depress this buyyon several times as it will go AV1, AV2, AV3, etc.
http://dysonmanuals.inc.io/
Chris.
Nov 21, 2007 | Televison & Video
Durabrand HT-3915 System Logo
258 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
