Question about Canon PIXMA iP1600 Printer
Outting in ink
I was changing the ink in my printer and the long black and brown cord is hanging out now. i dont know what it was attached to. it isnt completely dissconnected though. it forms a large loop from behind the ink installers. is it broken or did i mistakenly pull it out too far.
  • 2,144 Answers
The part you're describing is the drive belt for the print head carriage. If it was pulled loose, you probably also damaged a clear plastic strip called an encoder strip. I would strongly recommend getting it properly serviced -- they can then check for proper functionality at the same time.
Posted on Apr 30, 2008
I need to use color ink not black and i dont know how to switch from black ink to color ink help please
Right click on your printer and properties change your printing option to single color black.
Jul 20, 2011 | Lexmark P4350 All-In-One InkJet Printer
My Canon Image Prograf iPF700 keeps running out of color ink even through all setings are on Black and White (Monochrome). Any suggestions, getting sick of paying for ink im not using.
I you see in the preferences of the printer you have 2 kinds of monocrome( check de advanced option) one uses the all the colors to print in black if you use the second monocrome when you print its not black its more like brown. but this way you dont use de colors inks
Apr 19, 2010 | Canon iPF700 InkJet Printer
How do you change the ink from black to color i dont wont it to print black but i dont know how to change it
first go start menu,then click settings click printer and faxes.
second go to you default printer right click printer preferences.then go to
find out ink colour or black you will see on have a sample small image inside when you choice print out with colour or black their image will automatic change for you.
try this because i no sure with brand and model printer you have....
Aug 15, 2009 | Lexmark C533DN InkJet Printer
The belt or cord that moves the ink cartridges is hanging out
You need to remove the top cover to see where it goes, there's a spring loaded pulley on one side and a motor pulley on the far other side.
Aug 10, 2009 | OEM Systems PIXMA iP1800 Photo Printer
Epson 1400 won't print blacks
Hi
Many problems regarding Ink with Epson relate to using cheap ink consumables. I recommend you buy original Epson black ink catridge. I know its more expensive but you should see the black ink clear.
Be sure to run head alignment and clean printer option first with the current black ink then replace with the new original Epson ink catridge
Thanks
Andy
Jun 14, 2009 | Epson Stylus 1400 InkJet Photo Printer
The black is printing dark redish brown
Dear friend, your Black Ink Cartridge is Empty thats why your printer is using the Colour Cartridge to produce the Black Colour. This is the reason you are having Dark Reddish Brown colour instead of Black.
Apr 08, 2009 | HP Deskjet 6940 InkJet Printer
My printer does not print black & White documents
You just have to clean the printer head or change it.
Happend to me and solved it:
Open the top the way you use to change an ink cartrige...Unplug the power cord.. the ink tray will stay accessible.
Save your ink in some plastic wrap.
Just where you pull the ink cartriges is the head. Lift the little arm on right top of the assembly and pull toward you the black plastic kind of container..(for ink cartriges)..
that is where the head is attached. DO NOT FORCE anything..it should come easily.
At first place in warm clear water..use rubber gloves..often change water. When it looks quite clean..it is not. Unscrew the two littles screws holding the flat ribbon tip where the ink should go out..Beware...lift it gently..
underneat there is a small rubber part..just lift the end covering the black ink exit...Now pour all this in warm water mixed with Windex for some time and change the water till it comes quite clear. Now blow air from a compressed air can in the black ink canal..you will be surprise to see the amount of plugged ink coming out from there.Rince, dry with compressed air,screw back parts,place everything back and try an head alingment test to see your Black here again..
Apr 06, 2009 | Canon PIXMA MP780 All-In-One InkJet...
My Kodak 5300 won't print color
MAYBE YOU ADDED A BLACK INK CARTRIDGE RATHER THAN THE COLOR ONE ? OR MAYBE YOU HAVE THE COLOR CARTRIDGE PLUGGED INTO THE BLACK INK ONE ? DONT KNOW IF THIS WILL HELP BUT THOSE WOULD BE THE FIRST FEW THINGS I WOULD CHECK. I ALWAYS SEEM TO MISS THE OBVIOUS WHEN SOMETHING ISNT WORKING FOR ME
Jan 09, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Please i need help
TRY UNPLUGING PRINTER FROM POWER THEN RESTART
OR IF AVAILABLE TRY DIFFERENT BLACK CARTRIDGE
OR WITH CLEAN DRY CLOTH WIPE CONTACTS INSIDE CARTRIDGE HOLDER
CHECK LOCKING CLIP IS LOCKING DOWN PROPERLY RISKY BUT IF PROBLEM IS THAT CARTRIDGE IS NOT SITTING CORRECTLY IN HOLDER TRY THIN BIT OF CARD ON TOP OF CARTRIDGE THEN CLIP DOWN DONT BREAK IT BE VERY VERY GENTLE.
Jul 14, 2008 | Lexmark P6350 All-In-One InkJet Printer
Canon i560s printer - color problems
I changed the black ink in my printer, now it will not print everything in black!, I changed it back to the old ink, but still not printing black ink, what do I do?
Mar 23, 2008 | Canon BubbleJet i560 InkJet Printer
Canon PIXMA iP1600 Printer Logo
56 people viewed this question
old marine
old marine
