Intel Server M/B (SE7501BR2) using SRCZCR Raid5
configured with 3 drives (ST318453LW) DUAL Xeon 2400 1G
RAM. Setup hangs at "Installing Devices" 34 Minutes
remaining. I have grabbed every update Intel has to
offer. I tried the driver on the CD for the ZCR, the one
posted on INTEL site, and the one on the 2003 CD. All
the same. I went backwards and tried my .NET RC1 - It
didn't have the SRCZCR native on the CD and it complained
about the digital sig on the floppy - but it DID
install. .NET RC1 cannot upgrade so it was a dead end.
I have a second box (Single CPU - only two disks)
Running on the on-board RAID1 (w/o the ZeroChannelRaid)
that loads just fine. My gut tells me it is the device
driver on the CD - even when I do the F6 thing to load
driver from floppy for the "DOS" section of the install,
when W2K3 loads the device driver during the "WINDOWS"
portion it still is using it's built-in driver from the
CD.
Rating: 0%, 0 votes
Have you rebooted several times to see if it hangs at the same place?
After the first hang and reboot back, do a shift-f10 to open a cmp prompt.
Look at the bottem of the setupapi.log and setupact.log, the last 10-15
lines or so to see what device was attempted to be detected. Post back the
information it you would. Both log files are in the \windows folder.
Also see if a pnplog.txt file exists in the \windows folder. ( This file
only exists after hangs during gui mode setup after a reboot. If created
it should list a device that is having a problem)
Thanks,
Darrell Gorter[MSFT]
This posting is provided "AS IS" with no warranties, and confers no rights
| Content-Class: urn:content-classes:message
| Sender: "Andy" <a @c-m-a.om>
| Subject: W2k3 Setup hangs INTEL SRCZCR
| Date: Wed, 6 Aug 2003 13:48:16 -0700
| Lines: 18
| Message-ID: <a27801c35c5c$0f4f55b0$a0012 @phx.gbl>
| MIME-Version: 1.0
| Content-Type: text/plain;
| charset="iso-8859-1"
| Content-Transfer-Encoding: 7bit
| X-Newsreader: Microsoft CDO for Windows 2000
| X-MimeOLE: Produced By Microsoft MimeOLE V5.50.4910.0300
| Thread-Index: AcNcXA9Px+apsvyiQKmqHGImWb1chw==
| Newsgroups: microsoft.public.windows.server.setup
| Path: cpmsftngxa06.phx.gbl
| Xref: cpmsftngxa06.phx.gbl microsoft.public.windows.server.setup:2382
| NNTP-Posting-Host: TK2MSFTNGXA08 10.40.1.160
| X-Tomcat-NG: microsoft.public.windows.server.setup
| CD.
Was this solution helpful? Show your Appreciation by rating it:
Rating: 0%, 0 votes
Moved SRCZCR to second (almost identical) box (Single
Xeon 2400 only 2 disks) ran up a Raid1 array, Win2k3
hangs at the same point....
Rating: 0%, 0 votes
#-019 Searching for hardware ID(s): scsi\processorioctl_-
_device__________1.00,scsi\processorioctl_-
_device__________,scsi\processorioctl_-_,scsi\ioctl_-
_device__________1,ioctl_-_device__________1
#-018 Searching for compatible ID(s):
scsi\processor,scsi\raw
#-199 Executing "C:\WINDOWS\system32\setup.exe" with
command line: setup -newsetup
#I022 Found "SCSI\ProcessorIOCTL_-_Device__________" in
C:\WINDOWS\inf\scsidev.inf; Device: "Intel Controller
Management Device"; Driver: "Intel Controller Management
Device"; Provider: "Microsoft"; Mfg: "Intel"; Section
#I023 Actual install section: [NODRV]. Rank: 0x00000001.
Driver date: 10/01/2002. Version: 5.2.3790.0.
#-166 Device install function: DIF_SELECTBESTCOMPATDRV.
#I063 Selected driver installs from section [NODRV]
in "c:\windows\inf\scsidev.inf".
#I320 Class GUID of device remains: {4D36E97D-E325-11CE-
BFC1-08002BE10318}.
#I060 Set selected driver.
#I058 Selected best compatible driver.
#-124 Doing copy-only install
of "SCSI\PROCESSOR&VEN_IOCTL_-&PROD_DEVICE&REV_1.00
\6&2FD16D26&0&100".
#-166 Device install function: DIF_REGISTER_COINSTALLERS.
#I056 Coinstallers registered.
#-166 Device install function: DIF_INSTALLINTERFACES.
#-011 Installing section [NODRV.Interfaces]
from "c:\windows\inf\scsidev.inf".
#I054 Interfaces installed.
#-166 Device install function: DIF_INSTALLDEVICE.
#I123 Doing full install of "SCSI\PROCESSOR&VEN_IOCTL_-
&PROD_DEVICE&REV_1.00\6&2FD16D26&0&100".
#I121 Device install of "SCSI\PROCESSOR&VEN_IOCTL_-
&PROD_DEVICE&REV_1.00\6&2FD16D26&0&100" finished
successfully.
[2003/08/08 09:45:12 364.1]
#-290 Processing REGISTERDLLS section [CryptoDlls].
Module: "%11%\rsaenh.dll", flags: 0x0001, timeout: 60s.
#W374 Digital signature verification was skipped for a
file being registered ("C:\WINDOWS\system32\rsaenh.dll").
Module: "%11%\dssenh.dll", flags: 0x0001, timeout: 60s.
file being registered ("C:\WINDOWS\system32\dssenh.dll").
Module: "%11%\initpki.dll", flags: 0x0001, timeout: 600s.
\initpki.dll").
From SETUPACT.LOG...
1. Host - Drive #00 HA #0 SCSI Disk Device -
\Device\0000002e
HardwareId:
SCSI\DiskHost_-__Drive_#00__HA_#01.00
SCSI\DiskHost_-__
SCSI\Host_-__Drive_#00__HA_#01
GenDiskSCSI\DiskHost_-__Drive_#00__HA_#01.00
2. RAID Controller - \Device\NTPNP_P
Post a New problem for Intel SRCZCR SCSI Controller
Email this problem
Can you Help with these Storage Controllers problems?
Help me to install WinXP in a...
I have a problem with my USB...
