Question about Quartet gbc ShredMaster 950S Strip-Cut Shredder
Plactic drive gears
The two gears are striped that drive the cutting wheels, have no manual where can i find replacement parts
denis
  • Anonymous Nov 09, 2008
    Have a Staples shredder and the plastic drive gears also sheared teeth. Would like to find someone to fix it or get the parts to fix it myself.
    I have a Staples shredder with striped plastic gears. Looking for replacement gears
  • 58 Answers
This is how a got my hard to fine gear!
Contact Michael Business Machines for your local dealer 1-800-223-2508
Good luck, Tom
Posted on Mar 27, 2009
How do I fix my front wheel drive system on my 2004 ATV 400 Sportsman Late model? After extensive work and parts replacement my all wheel drive is not working.
Just a suggestion but you should consider soldering all your electrical connections to insure they are weather and vibration proof. Additionally, I added a small 3 amp circuit breaker, but a 1.5 to 2 Amp automotive fuse and fuse holder will do nicely.
Process:
1- Disassemble the 'Instrument/Light' cluster cover.
2- Remove the 'Radiator access' panel.
>>>Perform This Test BEFORE Proceeding and make SURE all power is OFF!<<<
3-On the drivers LEFT side of the radiator access area, locate two (2) connectors, each with SOLID GREY wires and BROWN wires with a WHITE Stripe on top and smaller diameter Solid Grey and Brown wires with a White stripe leading down.
--a) Disconnect both connectors by pulling the top and bottom sections away from each other. (DO NOT pull the WIRES, use the connector body to pull).
--b) Test EACH of the two (2) connectors with the SMALL DIAMETER wires leading down. (see Hub Coil Connectors pix)
--c) Using an OHM meter, measure the resistance across the two pins (one connector at a time) for each connector. Depending on the accuracy and sensitivity of the meter, each connector should read between 25 and 28 OHMS. NOTE: If EITHER of the two (2) Hub Coils reads ZERO (0) or less than 25 or Greater than 28 OHMS STOP!!! The Hub Coil itself OR the wires OR the connectors may be defective or in need of repair!
--d) Using an OHM meter, on EACH of the two connectors, measure the resistance between one pin of each connector and GROUND (any bare metal point on the ATV frame). NOTE: If EITHER of the two (2) connectors resistance to GROUND reads anything GREATER/ABOVE than ZERO ( 0 ) OHMS STOP!!! The Hub Coil itself OR the wires OR the connectors may be defective or in need of repair!
>>>If the test in 'c)' or 'd)' FAIL STOP, DO NOT proceed!! The Hub Coil itself OR the wires OR the connectors may be defective and MUST be repaired before ANYTHING else is done!<<<
4-(For my model) On the right handlebar, check the lamp in the AWD switch to make sure it is not burned out or missing. Replace lamp if necessary. (Not essential to the AWD operation, just nice to have to confirm voltage is being applied to the front wheel Hub Coils)
5-In the 'Radiator Access' area, locate the Red/White stripe wires providing (switched) full time + (battery plus) voltage (accessory power) via a ¼" female connector. "Accessory Leads" - in the wiring diagram.
6-Using a volt meter (or continuity light), CONFIRM that the terminal is OFF (NO voltage) when the ignition switch and the 'Engine STOP/START switch (on the left handlebar) are both OFF, and has + (positive) battery voltage, when the ignition switch and 'Engine STOP/START switch are both ON, with the engine NOT running.
Jan 15, 2015 | Polaris 2004 Sportsman 400
Ht 131 shaft keeps slipping out of cutting head
make sure the gear hed is engaged on both the outer shaft and drive shaft at both engine and cutting head end. Check the square drive section that is in the plactic moulding hasnt been pushed too far into the shaft meaning its not engaging properly.
Apr 15, 2014 | Stihl Garden
Kia sportage transmission
MANUAL well their is only one in my eyes and that is EP90 front or rear wheel drive type manual gearbox although some older cars from the 50s specified engine oil like the morris /austin ranges even the old ford consuls could have this before the gears started to have syncromesh and helical cut gears ,showing my age here i think ?cars with no syncomesh ?? rod brakes and worm and wheel diff units .
May 26, 2013 | Cars & Trucks
I have a 2004 chevy malibu with 200 some thousand miles. as I was backing out over my drive today my steering wheel started to knock and the wheels won't turn. It finally did turn after about one and a...
you might have a bad worm gear ,its a gear for tighting the action of the steering wheel,i would have your tech look at it ,but most cases are to replace steering box.
Jul 25, 2011 | 2004 Chevrolet Malibu
Drive wheel for wire feeder starts slow as if it is stuck at the begining, even if there is no pressure on the drive wheel.
check the feed gear that pulls the wire off the roll there are lots of little teeth on this gear if there striped off the wheel slips also if the welding wire is rusty it will jam in the neck tube
Aug 11, 2010 | Lincoln Welding Tools
Sounds like the sterring wheel is striped
Sorry I don't have a solution but have a similar problem. I replaced the steering pinion gear in hopes that would resolve the problem, but it didn't. The steering pinion gear is located at the bottom of the steering shaft and turns the steering gear. Looks like the steering gear needs to be replaced as well. The nuts securing the steering gear are accessible in the same area as the pinion steering gear. I am going to order a replacement steering gear and attempt to replace it.
Jul 09, 2010 | Cub Cadet Street Sign- tractor lawn riding...
12" craftsman table saw 0 to 45 deg adjustment gears striped
Sears has a site for parts and owner manuals at www.ManageMyHome.com.
It could be something is just loose and out of adjustment so that the teeth were able to slip on the gear. But I've never had a look at one of those to say for sure...oil always helps these things move easier...
Apr 19, 2009 | Saws
Shear pin ??
You most likely have several teeth broken off the drive gear that drives the cutting block. Not too difficult to replace but you need some special tools. A deep well socket (I think it's about a 3/8") to remove the cutting block and replace the broken gear. The gear should be available from a Fellowes dealer, or they might sell it to you direct if there is no dealer near you.
Let me know if this helps.
Aloha,
Bill Monroe
Oct 15, 2007 | Fellowes 220C-2 Shredder
Quartet gbc ShredMaster 950S Strip-Cut Shredder Logo
437 people viewed this question
Top Quartet gbc Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Quartet gbc Office Equipment and Supply Expert? Answer questions, earn points and help others
