NS-DXA1 converter box: The unit works fine until I try to use the timer record function of the VCR. The tape runs through but nothing is on it. thank you
  • 1 more comment
  • 28paws boat May 01, 2008
    VCR is Sony SLV-360P. TV os RCA model F35100ST Purchases in 1991. I am not sure what you mean by a composite connection, but the set is connected to an anntenna.
    The instant record button wirks but not yhe timer
    The TV is on channel 3.
    The VCR is connected between the converter and the TV
    Master:
  • 788 Answers
What cable type/connection type are you using to connect the converter to the VCR? Are you using the composite (RCA) connection to a video input on your VCR or the RF to antenna input on your VCR?
If you are connecting via composite then you need to record on the video input and not a specific channel, then set the converter box to the channel you want to record.
If you are connecting via RF then you need to program your VCR to record channel 3, then set the converter box to the channel you want to record.
You can only record one channel at a time, if you change channels your recording will change to that channel.
Posted on Apr 30, 2008
  • 1 more comment
  • Dean Joly
    Dean Joly Apr 30, 2008
    If you provide the model/brand of your VCR and even the model/brand of your TV I can assist in connecting everything together properly and how to program the VCR.
  • Dean Joly
    Dean Joly May 01, 2008
    Do you have to put the TV on channel 3 to watch from your converter or do you put the TV on video? Is the VCR connected between the converter and the TV?
  • Dean Joly
    I made this diagram to help you ensure you are all hooked up right:
    From what I am understanding though you just need to make sure the VCR is also recording channel 3.
    Guru:
  • 1,894 Answers
U say that the record button alone not works??
am i right>?
Getting frustrated. Cannot record on VCR with new converter box!!
Click here to find more instructions on how to connect the Insignia Converter Box. Using any of the connections from the link above will only allow you to watch the channel that you're recording from. Make sure the VCR and TV are tune to channel 3 or 4.
Let me know if you require further assistance.
Aug 12, 2009 | Televison & Video
RCR Universal Remote Code for Insigna HD Converter Box NS-DXA1
Try 189 or 244 or 309..........Hope that was helpful Thanks for using Fixya.com.............enjoy your evening!
May 30, 2009 | RCA 3-Device Universal Remote
Timer record on vcr/dvd attached to digital convtr box
You have to set the vcr to channel 3 or 4 (whatever the converter box is set to broadcast on). The signal to record has to come through the converter box. Since the VCR only has a analog tuner, it cannot pick up any digital channels on it's own.
Mar 29, 2009 | Sansui VRDVD5000 DVD Recorder/VCR
Can we tape digital feed on a VCR and play it on an HD-ready tv?
You should be able to accomplish this. Run the antenna to your converter box. Run the video and audio outputs of the digital converter box to the inputs on your vcr. Your vcr should then be able to record the program (select line-in as the channel when setting up the recording). Hook your vcr audio and video output to your tv.
It's best to use a converter box that has an event timer - this allows the converter box to turn on at a specified time and channel. Otherwise you will need to manually set the channel you wish to record on the converterbox, and leave it turned on.
Mar 10, 2009 | Mitsubishi HS-U560 VHS VCR
No set-up menu from insignia ns-dxa1 converter box
Set your television to channel 3. Then power on your Insignia unit and run the auto-search function as described in the user manual found here - http://www.insignia-products.com/skins/skin_1/Topics/Documents/07-576_NS-DXA1_WEB.pdf
Dec 29, 2008 | Insignia Digital-to-Analog Converter for...
Insignia NS-DXA1 - Digital to Analog converter box
I have had my converter box 5 days now. I hooked it up to the TV and set it up. No Problem. Except there are no instructions on how to set up the VCR/DVD player with it, which we use more than we do watching TV. Everything worked fine until on the second day we had it I read I could program the remote to turn the TV on and off. I followed the instructions and the TV went off. When I turned it back on, my remote went berserk. If I try to change a channel it will quickly flip through all the channels until I turn the converter box off. Same with the volume, it goes up and down, up and down until I shut off the box. The remote does not work unless you are about 1 foot away from the box. And the remote has never turned the TV on or off except that first time I programed it.
May 19, 2008 | Insignia Digital-to-Analog Converter for...
ZENEITH DTT900 ANALOG TO DIGITAL CONVERTER BOX CONNECTIONS
Can't go through the VCR in the normal way. The DTV box must be tuned to the channel you want to record and left there. Cannot tell VCR to tape one channel and watch another nor tape multiple timed and multiple channel shows unless the DTV is tuned to that specific channel. This makes most VSR functions useless.
May 13, 2008 | Televison & Video
Memorex MVD4544 VCR will not record
Take the unit back to the store and exchange it for an other unit of the same. The likelyhood of two units not working is very slim, and good luck with your new unit.
Jan 26, 2008 | Televison & Video
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
