Question about RIM BlackBerry Pearl 8100
Ssumbuster Xtreme scrubbing unit cataolog #S700E Have had it for four months. recharged once . worked fine. HAve not dropped it or put in water except to scrub a wet tile shower floor. Began slowing down. Put it on to recharge before it drained out of charge. Instead it completeley discharged. Checked connection and plug and outlet. Outlets are in order but unit will not recharge. WHAT TO DO??? THANKS, MAMIE
Called black and decker direct on their 800 number. thank you.
Posted on May 09, 2008
My unit has never worked properly as it is dripping water and ruining my wall and my filters. The business that installed my unit is giving me the run around and ignoring my requests to fix my unit once...
It's short of gas. That's why it's forming ice over the coil and cutoff by coil sensor and then blower only would run. At that time ice become starts defrosting resulting to this water drop. Call repairman to find the return pressure by gauge. 60psi must be @98 degree ambient temp.If less that it's short of gas.
Complaint with customer care of the manufacturer.
Jan 20, 2011 | Goodman Heating & Cooling
Ds was dropped into some water.. still works, but the battery will not recharge.unit is about 10 months old
Hello Mr Meyer_p , Mr . Midwest-Tek
When The Battery Droped In The Water
it Become's a battery " With a Decharge "
Try This Way To Fix Your Battery Without Buy Another
__________________________________
Pick up a nintendo 64 charge
Cut The Cable from here
Put it on
Then Put The Cutted Cable On The Battery
Do It , 3 , 4 times
It's Done
Aug 27, 2010 | Nintendo DS Lite
Why does battery die so fast
use till battery is dead, then put a full charge one it, if it has water ports, check to see if at proper level, if still bad, take to have tested, look in phone book(batteries) if it test ok, charger is bad
May 19, 2010 | Powr Flite PAS20DX Canister Vacuum
I'm getting an awful smell from my fridge. I've totaly cleaned it out there is no food left in it and scrubbed it with bleach and it still stinks. It smells up the house when I open it. I'm not sure what...
Take a gallon of amonina and put it in four or five large bowls and put them on the shelves and close the unit and leave it closed for 48 hours. Do not chill it..... I have done this and it works well....f761dad.gif
Dec 01, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
All of the spark igniters were going at once. The gas was off...
hi.gud day...tnx for question.im gerbee here in the phillipines, the problem of the the unit is have an dirt or water,& oil coz why the unit is not stoping cliking sound.the best thing to is clean the area were the problem it is,first unplug the unit & turn in off the gas line for the safety..get the vacium & bottle of thinner...first remove all the knobs of the control valve(make sure to remember how to remove the knobs coz if turn back as how you remove it). then drops some thinner located on valve switches(knobs position) 5-10ml,,,then put the vaccium in the place were u drop the thinner to suction the thinner,oil & some dirt.try 2 times for good result...after this if is not work n nid to call an expert tecnician to dismantle & clean the micro swicth one by one(no nid to replace the parts)
Sep 06, 2009 | GE 30 in. JGP328 Gas Cooktop
GE Adora Side by Side Refrigerator Ice maker
You may ahve a problem with your freezer temp. Check your setting. Turn down a few notches to see if problem goes away. Also Pull out your fridge and vacuum out your coils underneath unit. Plug coil causes freezer temp to rise. Rus
Jul 04, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Won't recharge, won't reset
soak unit it rubbing alcohol if dropped in water(water has deposits when dry that short stuuf out alcohol cleans and leaves no residue)let soak for a few hours(make sure battery is out)then shake out excess alcohol and let dry for a day in warm dry area.clean contacts on battery with alcohol ans qtips and reinstall battery then try to charge-same thing happened to me tried this and worked fine hopefully didnt short chips!!!!!Best of Luck to you!!!use 90% rubbing alcohol!!!let me know if worked!!!
Jun 30, 2009 | Sony Walkman NW-A808 MP3 Player
Alkalines won't work in my 360 controller.
there are units designed to run on rechargeable batteries and some that run on alkaline batteries
the difference is the current draw required
alkaline batteries have a high discharge rate available but for short duration while the others have a smaller discharge rate but over a longer period of time
you should only use the type of batteries recommended for the unit
Apr 12, 2017 | Nyko Charge Station 360 For Xbox 360
Rechargeable Camping Lantern
you need to coldsolder the pc board.
Apr 09, 2008 | Dryers
Cd player
First of all, you aren't going to like this solution because it's the truth. If you rate me poorly, it's because you don't understand the truth. The optical pickup is bad and needs to be replaced. Anything made by Xtreme sound is poorly built. Yes, you're lucky to have even gotten four months use out of it. I've seen some that only last for two months and they die. Fortunately, that's why you didn't pay that much for it. I would suggest getting a Pioneer in the future.
Jul 15, 2006 | Xtreme Sound WMS336 CD Player
RIM BlackBerry  Pearl  8100 Logo
50 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
