Question about Frigidaire GLTR1670A Front Load Washer
Front load washing machine magnet repair (frigidaire.)
Where does the magnet fit in the drawer if it has fallen out?
    Genius:
  • 1,028 Answers
Bottom right corner should be a spot if will fit into
Posted on May 01, 2008
DRAWER OPEN MAGNET ON GLTF2940ES1 ?
Pull the drawer out and find it with a paperclip.
Nov 16, 2013 | Frigidaire GLTF2940ES Front Load Washer
Where does the magnet go on a model number ltf2940es
Good Morning Annie, thank you for your post!
Generally speaking, the magnet is located in the dispenser drawer. Double check the drawer and if it is closed, remove the drawer and examine the placement of the magnet and reinstall. If the magnet is missing or defective, the magnet probably needs replacing. However, if the magnet is in good condition and in place, an experienced technician may need to examine the reed switch or main control board.
Nov 12, 2013 | Frigidaire ATF6000ES Front Load Washer
Pulled out detergent compartment and magnet fell out. where does it go machine wont run.
Welcome to FixYa.
The dispenser drawer on many Electrolux/Frigidaire built machines do require a magnet on the right hand side of it to activate the reed switch inside the console located there. It should fit in the bottom of the drawer, if you flip it upside down you should see it's intended location.
Let me know how you make out and I'll help further in any manner I can. Good luck.
Regards,
Macmarkus :)
Mar 04, 2011 | Frigidaire GLTF2940ES Front Load Washer
Our magnet fell out, where does it go
If you are talking about a small, rectangular magnet, about a 1/16" think or so, it goes in the detergent dispenser drawer. Looking at the front of the drawer, right side, a little behind the front. This magnet triggers a ( or should if its not falied) a magnetic reed switch which allows the washer to operate only if the drawer is closed.
If you take the drawer out, and remove the front, you will see where it goes.
Apr 26, 2010 | Frigidaire GLTF2940ES Front Load Washer
Ddo error code on frigidaire front washer
Hi
Thanks for using FixYa. Error DDo means dispenser drawer open. There is a little magnet attached to the right hand side of the detergent drawer which activates a reed switch to "tell" the machine that the drawer is closed. That magnet might have moved from it's place and that's why you are getting error ddo. magnet is part key number 51. Pull the drawer out and check on the handle part for a magnet. When the drawer is closed the magnet activates a switch in the console that tells the control the detergent drawer is closed. Please check this link for details(part #51)--
Frigidaire exploded parts catalog
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 14, 2009 | Frigidaire GLTF2940ES Front Load Washer
My washer is giving error code e10 and im not sure what to do my washer is a frigidaire front load
I have an error code chart that came with mine and it says a few different things for E10. 1st says water not entering washer. 2nd says water leaks. 3rd soap dispenser drawer is open. In another post there was something about a magnet needed in the drawer too. But I would suggest checking your hoses and making sure you have water and the drawer is completly closed.
Jan 18, 2009 | Frigidaire ATF6000ES Front Load Washer
Front end washer lights come on but doesn't fill.
it fell out of the dispenser, hold the dispenser facing away from you on the left side there is a small slot, place the magnet in vertically so the long side of the magnet is on the right when looking from the front with the drawer closed good luck
Dec 10, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gltf2940e front loading washer - dispenser drawer magnet replacement
When you are looking at the drawer, the magnet stands upright on the far right side just inside the outer front casing about halfway down. There is a small plastic clip that holds it in place. You don't need to take anything apart to reinsert the magnet, just open the drawer, but it may be easier to see the location if you pull the drawer all the way out of the hole.
Nov 02, 2008 | Frigidaire GLTF2940E Front Load Washer
Error code ddo
the dispenser drawer has a magnet in it that has to line up with a sensor. if you can put the drawer back in that will solve the problem. if the magnet isn't lost.
Oct 28, 2008 | Frigidaire GLTF2940ES Front Load Washer
Ddo error - I have the magnet, where does it go?
if u open the drawer dispenser magnet goes on the right hand botton side good luck
Dec 22, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire GLTR1670A Front Load Washer Logo
99 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
