Question about Linksys Wireless-G WRT54G Router
Can not get on the internet - Linksys Wireless-G WRT54G Router
  • 77 Answers
What do you mean cannot get on the internet? when you are plugged into the router does this mean you cannot see any web pages? are you able to pull an IP address from the router? Check if your able to ping Gateway (router) and get a reply back. To do this go to your start command then run and type CMD and hit enter... a dos like window will come up then type the command ipconfig and hit enter again... look for the "default gateway" ex) 192.168.0.1 and then try to ping it! do this by typing ping 192.168.0.1 you should get something like this.
S:\>ping 163.254.16.1
Pinging 163.254.16.1 with 32 bytes of data:
Reply from 163.254.16.1: bytes=32 time<1ms TTL=255
if you do then that means your getting a reply back from the router and the connection between the 2 are fine. If the router is unable to obtain an ip address from your vendor.. there could be multiple reasons why. Does your provider do mac filtering? also you can try upgrading the firmware on the unit by going to linksys.com and searching for the latest firmware.. let me know how your tests go.
Posted on Apr 30, 2008
Hy, I am not able to access Internet on changhong though everything is fitted properly. My internet is also working cool. So dere is a problem with the tv. How should I overcome it?
Reset Internet Explorer settings
You can reset Internet Explorer settings to what they were when Internet Explorer was first installed on your PC. This can be useful for troubleshooting problems that may be caused by settings changed after installation. Note that resetting Internet Explorer isn't reversible, and all previous settings are lost after reset.
  1. Close all Internet Explorer windows. Select the Tools button, and then select Internet options.
  2. Select the Advanced tab, and then select Reset.
  3. In the Reset Internet Explorer Settings dialog box, select Reset.
  4. When Internet Explorer finishes applying default settings, select Close, and then select OK. Restart your PC to apply changes.
Jun 03, 2017 | Internet Computers & Internet
Tip
For All XP user Don't Use IE 7.0 & higher version
Applicable for all window XP (all edition, all PCs and Laptops)
If you are getting trouble after the updates of internet explorer..
Then I would suggest you to Roll Back it to the original Internet Explorer (i.e Internet Explorer version 6.0)
Which come up with Installation of Win Xp with Service Pack 2.
Bad Effect due to IE 7.0 or higher version:
Screen hang up, internet freezes abruptly, prominent windows crashes anytime.
So to stop these problems, better to run with lower and safe version of IE:
To remove Internet Explorer 7 from your PC use the following methods
Method 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
Step 1: Use "Add or Remove Programs" to uninstall Internet Explorer 7
a. Click Start, and then click Run.
b In the Open box, type appwiz.cpl, and then click OK.
c. In the list of programs, click Windows Internet Explorer 7, and then click Remove.
d. Follow the wizard instructions to uninstall Internet Explorer 7. Also remove if any updates under this entry found.
If you cannot uninstall Internet Explorer 7 by using this method, try Method 2.
Method 2: Use Spuninst.exe to uninstall Internet Explorer 7
Run Spuninst.exe to uninstall Internet Explorer 7
b. In the Open box, type %windir%\ie7\spuninst\spuninst.exe, and then click OK.
c. Follow the wizard instructions to uninstall Internet Explorer 7.
After you uninstall Internet Explorer 7, double-click the Internet Explorer icon to verify that Internet Explorer 6 is restored.
This will bring up you to run Internet explorer as it come up with the installation kit, which is safe and reliable.
Have Nice Surfing!!
Ellin
on Oct 14, 2008 | Microsoft Windows XP Home Edition
I have problems with my internet
Wow, could you be a little more vague? Hard to help you with such a broad problem.
Computer Internet problems?
TV Internet problems?
ISP Internet problems?
WIFI Internet problems?
Cell Phone Internet problems?
Connectivity Internet problems?
Router Internet problems?
Well I think you get the point. And this is not close to a complete list. Sorry!
Feb 12, 2015 | Computers & Internet
Closed internet explorer at runing
When you reset Internet Explorer to its default settings, all changes that were made to Internet Explorer after it was installed are removed. However, this action does not delete your favorites or feeds. To reset Internet Explorer to its default settings, follow these steps:
To reset Internet Explorer automatically, follow these steps:
  1. Click this button:
    fixitbutton1.jpgReset Internet Explorer settings
    Microsoft Fix it 50195
  2. In the File Download dialog box, click Run, and then follow the steps in the wizard.
  3. In the Reset Internet Explorer Settings dialog box, click Reset.
    Click to select the Delete personal settings check box if you would also like to remove browsing history, search providers, Accelerators, home pages, Tracking Protection, and ActiveX Filtering data.
  4. When Internet Explorer finishes applying default settings, click Close, and then click Close again.
  5. Close Internet Explorer, and then restart it.
Let me reset Internet Explorer myself
To use the Reset Internet Explorer Settings feature from Control Panel, follow these steps:
  1. Close all Internet Explorer and Windows Explorer windows.
  2. Click Start Collapse this imageExpand this image vistastartbutton.jpg , and then click Control Panel.
  3. In Control Panel, open Internet Options.
  4. Click the Advanced tab, and then click Reset.
  5. In the Reset Internet Explorer Settings dialog box, click Reset.
  6. When Internet Explorer finishes restoring the default settings, click Close, and then click OK two times.
  7. Close Internet Explorer, and then reopen it. The changes take effect the next time that you open Internet Explore
Mar 15, 2014 | Microsoft Computers & Internet
Set homepage
Using Internet Options You can change your Internet Explorer settings by using Internet Options. You can specify the first Web page you see when you start the browser, delete temporary Internet files stored on your computer, use Content Advisor to block access to objectionable material, and specify how colors and fonts are displayed on Web pages. You can also set your security level and specify which programs to use for e-mail and reading Internet newsgroups.
For information about using Internet Explorer, click the Help menu in Internet Explorer.
Open shortcutcold.gifInternet Options in Control Panel.
note.gif Notes
  • To open Internet Options, click Start, click Control Panel, and then double-click Internet Options.
  • Internet Options allows you to change the settings of Internet Explorer, but it cannot be used to change the settings of other Web browsers
Jan 14, 2014 | Computers & Internet
Set default browser
Windows 7 and Internet Explorer 9
1. Open Internet Options. From the Start menu, go to Control Panel, then click Network and Internet.
2. Once in Internet Options, click on the Programs tab, then select Set your default programs.
3. In the Programs bar to the left, select Internet Explorer, then click Set this program as default.
Windows 7, Windows Vista and Windows XP with Internet Explorer 7 or 8
1. Open Internet Options. Click the Start button, then click Control Panel, click Network and Internet, and then click Internet Options
2. Select the Program tab. In the Internet Options window, click the Programs tab, then next to where it says "Internet Explorer is not currently the default web browser," click "Make default"
For screenshots, please follow the link.
Make Internet Explorer Your Default Internet Browser
Jun 19, 2013 | Evernote
Compaqnx6120 my laptop locked,I want to unlock it ,please help me
Well of course the internet is not working if the laptop is locked. In fact, if the laptop is locked nothing is working, right?
So, why is the laptop locked? When you turn it on, what is it doing and what is it asking you to do?
And what is this Internet Security you mention??
The only Internet Security I know of is a Virus or Infection that calls itself Internet Security.
Don't get me wrong, Internet Security is vital, but it is process and not a product per say. There are things that end with Internet Security such as Norton Internet Security, McAfee Internet Security, Kapersky Internet Security, etc. The only product that calls itself "Internet Security" is a virus known as the Internet Security virus.
Is that what is popping up on your screen and blocking you from doing anything?
May 16, 2012 | HP Compaq nc6120 Notebook
Internet explorer closes down after 45 secs, no warning just shuts down, firefox also shuts down. Only on laptop and after microsoft updates had been added. Restored to time prior to updates but problem...
Try Resetting Internet Explorer to its default settings. This removes all changes made to Internet Explorer since it was installed, but does not eliminate your bookmarks or feed. To do this, follow these steps:
1. Close all Internet Explorer and Windows Explorer in Windows.
2. Click Start, And then click Internet Explorer.
3. In Internet Explorer, click the Tools menu and then click Internet Options.
4. Click the Advanced tab and then click Reset.
5. In the readjustment of Internet Explorer Settings dialog box, click Reset.
6. When Internet Explorer finishes restoring the default settings, click Close, and then click OK twice.
7. Close Internet Explorer and then reopen it.
If resetting Internet Explorer to its default settings does not fix the problem, uninstall Internet Explorer 8 and then reinstall it. Also run AdAware, scanned for viruses, disable 3rd party, disable microsoft firewall, and check for BHO's.
Jan 19, 2010 | Microsoft Computers & Internet
How do you fix internet explorer
Sir/ Madam-
Normally this happens when customer Ie files are corrupted or Temp files are causing the problem..
Go to Control Panel\Network and Internet\internet option
Please try below steps it should fix the issue--:
Clear cached data in Internet Explorer 7 loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by corruption in the temporary Internet files or in other cached information that is used by Internet Explorer 7, you must clear cached data. To do this, follow these steps:
  1. Open Internet Explorer 7.
  2. Click Tools, and then click Delete Browsing History.
  3. In Delete Browsing History, click Delete All.
  4. Click to select the Also delete files and settings stored by add-ons check box, and then click OK
Reset security settings for Internet Explorer 7 loadTOCNode(2, 'moreinformation'); If you configure security settings to be too restrictive, you may prevent Internet Explorer 7 from displaying certain Web sites. To determine whether an issue is caused by overly restrictive security settings, revert to default security settings. To do this, follow these steps:
  2. Click Tools, and then click Internet Options.
  3. Click the Security tab.
  4. Click Reset all zones to default level, and then click OK
Reset Internet Explorer 7 settings loadTOCNode(2, 'moreinformation'); To determine whether a performance issue or an error message is caused by configuration settings, reset Internet Explorer 7 to its default configuration. This was its state when Windows Vista was originally installed. To do this, follow these steps:
  3. Click the Advanced tab.
  4. Under Reset Internet Explorer Settings, click ResetSir/ Madam-
Mar 25, 2009 | Microsoft Windows XP Home Edition
Linksys Wireless-G WRT54G Router Logo
205 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
