Question about RIM BlackBerry Pearl 8100
Need to "turn on radio"
I am trying to get my email to work and I guess that my radio has been turned off. The problem is that I can't figure out how to turn the dumb thing back on. HELP!
  • 1 more comment
  • Anonymous Aug 29, 2008
    Is it a common thing on these BlackBerry Pearls that the radio shut off? I tried everything else to get the dam radio back on. It's not working.
  • Anonymous Jan 30, 2009
    i cant text are receive messages and my radio is turned off and i cant get it back on
  • Anonymous Feb 24, 2009
    how would I go about getting the radio on my laptop turned back on
  • 44 Answers
Menu key is to left of trackball, select with trackball, scroll to manage connections icon, select with trackball, will give you an option to turn on phone.
Posted on May 03, 2008
Go to Manage Connections. At the top, it will say "Turn All Connections On". Select "Mobile Network" not bluetooth unless you are using it currently. The phone should start working.
Posted on Mar 19, 2009
2 Suggested Answers
brambleator
  • 97 Answers
SOURCE: Can't "turn radio on"
if the radio has been turned off, there should be an icon saying 'turn wireless on'.
typically it will be towards the bottom of the handheld.
if that doesnt work, try a powercycle. remove the battery and reinstert it. try going into options>mobile network> network selection (change from automatic to manual) and select your network....
Posted on Apr 30, 2008
How to turn off coby CSMP160 alarm
did you try unplugging it or taking the batteries out
or if is solar cover it
Jun 25, 2012 | Coby CSMP160 Digital Speaker System for...
My 1998 Chrysler Town and Country LXi mini-van radio does not work. Have an "Err" code displaying on radio when I try to use the CD player. Also when I turn on the radio there is a click sound...
Chances are there is a problem with the radio itself, and it needs to be replaced. You can find used radio suppliers on ebay, and most will answer simple questions via email to help you.
The clicking you hear near the fuse panel is probably an external amplifier on the system, my 2003 Durango has one as well. Normally you wouldn't hear the click because the stereo would be playing.
There should be a tiny model identifier on the face of the radio near the clock (RAZ, RBD, etc) which will help in figuring out the problem.
Dec 04, 2010 | 1998 Chrysler Town & Country
Electric(dash)
Did you check ALL the fuses? Is there anything else not working in the car (i.e. dome lights, cig lighter...)? Sometimes GM has TWO fuses to the radio...
Dec 29, 2009 | 1999 Oldsmobile Alero
My battery died on me the other day and now the radio won't work.
The Accord radio does indeed require a code. Have you tried just putting the code in. If you do not know the code do not attempt to guess, as after a few attempts you will lock the radio for good. I need to know the error message exactly as you see it if inserting the code does not work.
Oct 16, 2009 | 2003 Honda Accord
Dell Latitude D510 - Turn on Radio for WiFi
This can be found in a couple of areas. Under Computer Management, make sure Wireless Zero Configuration is set to enabled. Also under Network Connections, make sure that the network adapter is showing as enabled, and is not disabled. This can be done by right clicking on the network connection and clicking enable.
This issue sounds like you may need to explain to her that the network cabling needs to be changed around so that the router recognizes the cable modem, and than she should be set.
Sincerely,
Ryan Deschaine
Systems Administrator
Boxen Solutions LLC
http://www.boxensolutions.com
Email address: ryan@boxensolutions.com
Office number: 262.254.0064
Mobile number: 262.834-5844
Fax: 414.918.8432
AOL: BoxenRyan
Twitter: BoxenRyan
W172 N9175 Shady Lane
Suite 418
Menomonee Falls, WI 53051
Sep 22, 2009 | Dell Latitude D510 Notebook
How do I change the time on the stock radio?
I am not really sure what it looks like, I am kinda guessing here. Turn the radio off, and press the set button, hopefully the clock flashes. Either turn the knob for the tuner, or press the button that usually tunes the radio.
Sep 07, 2009 | 1999 GMC Jimmy
Radio keeps turning off
I had this problem last year ... very annoying to say the least.
It turned out to be my battery, it's was saying charged but was not.
I know it sounds far fetched but try switching with someone elses battery, or grab a new one in the store to try for a minute. You may also be able to try using your phone while it is plugged in. If the battery is not too far gone this will work to prove the battery is the issue.
It worked for me and I have heard of others having the same success by switching batteries. The girl that figured this out for me told me these batteries are not meant to be charge for long periods of time, and that plugging the phone in as you go to bed is what was harming mine. This I can't back up, but she was on the money with my other problem so she may be right?
Good luck
Sep 18, 2008 | RIM Blackberry 7100i
actually the above solution is wrong.
to turn the wireless radio back on
1. go to "manage connections"
2. check the box that says "mobile connection"
This just happened to me and now my wireless radio is back on. Good luck!
Apr 30, 2008 | RIM BlackBerry Pearl 8100
Backup battery not working
Check to make sure the battery connections are clean - free of rust/corrosion/gunk...and that the battery firmly "snaps" into it's connector/holder. BTW, if you have a user manual for the clock, I have the same model but lost my manual and can't figure out how to set the time... you can email my with instructions at donebythefish@gmail.com - I'd appreciate it!
Dec 11, 2007 | RCA RP3710 Clock Radio
RIM BlackBerry  Pearl  8100 Logo
1,726 people viewed this question
Top RIM Computers & Internet Experts
Computer Repairing
Computer Repairing
David
Martin Murray
Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
