Question about Kitchen Ranges
Kenmore elite convection oven - fan keeps running long after cooking is done
Fan keeps running long after cooking is done. i htink it is to cool down the oven? but oit goes for a long time after and i wanted to know if this was normal or if there is a way to shorten it.
Kenmore Elite 30" Built-in Wall Oven Model 91149043200
  • Luines Arroyo
    Luines Arroyo May 04, 2009
    The same problem as above on over the stove oven.
jsrock516
  • 5911 Answers
SOURCE: GE Wall Oven - error code F1
According to GE, the F1 fault code indicates a problem with the Electronic Range Control (ERC) Board. If the fault cannot be cleared, they recommend replacing the ERC and the touchpad. Has your repair guy tried any of these ideas? Post back with your comments, please.
Posted on Jan 17, 2008
SOURCE: Kenmore Elite Electric Convection Oven Not Working
The control panel of Kenmore oven doesn't work. I bought it just one month ago. What should I do?
Posted on Sep 14, 2008
Krazytech
  • 725 Answers
SOURCE: oven locked
F93 - Maximum oven door lock time exceeded
Door lock is jamed . or faulty let me know
Posted on Dec 25, 2008
skrbin
  • 121 Answers
SOURCE: Elite 790.9912 cooking with convection, oven poped and smoke out
heater is broken,must call service
Posted on Feb 17, 2009
SOURCE: kenmore elite oven lock
None of above worked for me. But, gave me a clue. I pressed the Stop/Clear button for apprx 10 sceonds. the "door locked" flashed for 5 seconds and then cleared and the door unlocked. Panel worked fine after that.
Posted on May 25, 2009
Why does my convection microwave ovens fan keep running long after it has finished cooking
There are 2 reasons :
01.Because the high temp. used to cooking must chill down.
02.To exhaust the remains of steam that could lead to premature rust of the oven
Dec 05, 2017 | Microwave Ovens
Convection fan runs from start up , but when temp ia achieved , fan stops working and shows con on the display
Search Results
    Frustrated with new Samsung stove! - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWe purchased a smooth top, convection Samsung range , with delivery on ... I seem to have the same problem with my new samsung range FER700WX. ... That ovenwould not reach temperature and if it did, it would not keep the temperature. ..... 3) as the oven restart the convection fan or fans blow such hot air the food in ...
    Convection 101: A Guide to Cooking With Fans - Oven ...
    ovens.reviewed.com/.../convection-cooking-101-a-guide-to-cooking-ba...
    Apr 4, 2015 - Problem is, it uses a ton of water. 6.2 ..... Convection ovens use a fanand an extra heating element to correct ... it's best to reduce oven temperature first, before adjusting cook time. ... range or wall oven, there's simply no reason not to ponyup. ... From futuristic to freaky, these fixtures run the entire spectrum.
    New Bosch range convection fan not moving? - Home Forums
    ths.gardenweb.com > Home Forums > Appliances
    Oct 8, 2007 - On my range (the slide-in version) the cooling fan runs even when in ... I was the one with the Bosch fan problem and if there is a problem with ... Mine does stop turning when I open the door and starts again when I ... convection roast feature, and once the oven reached temperature, ... Sign Up to Comment.
    Troubleshooting Gas Range and Oven Problems ' Back ...
    blog.etundra.com > Tundra's Tech Talk
Jan 17, 2016 | Kitchen Ranges
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
Will a plain fan convection/microwave ROAST/BAKE as well as a "true" convection that has an extra heating element and fan convection/microwave
Most likely the Kenmore is actually made by Sharp. Most of the combination microwave/convection ovens are. I have one with a "Wolf" name on it, and it roasts/bakes very well.
Apr 07, 2015 | Kenmore Kitchen Ranges
Replace thermostat on kenmore elite
Possibly none of these videos are exactly like your oven but it should give you enough information to get the job done.
Note that some of the videos are not for ovens.
Replace thermostat on kenmore elite oven YouTube
KENMORE ELITE Walloven Parts Model 79048033800
Oct 16, 2014 | Kenmore Elite 30 In. Electric Self-clean...
Kenmore model 721 850 the cooling fan doesn't run all the time
This could be due to a intermittent micro switch, or a faulty cooling fan. This is critical in keeping the magnetron cool when cooking.
Apr 04, 2012 | Kenmore Microwave Ovens
I have a imperial convection oven that I just purschase and operated fore 4 days, and the fan stoped working any idei what would cause this?
You don't say what model. Some Imperial ovens have a cool-down switch that lets the fan run with the doors open but not in cook mode. That is a starting point.
Mar 27, 2012 | Imperial Ovens
We have just purchased a Kenwood microwave/combination oven and are concerned there may be a problem. When the food has finished cooking and the microwave beeps it seems there is a fan or something still...
In most modern combination microwave ovens, if not all, there is a fan that comes on after use to cool the magnetron and cavity down. This is quite normal but if you still have doubts, contact Kenwood's web site and send them a question.
Hope this halps to put your mind at rest.
Nov 27, 2010 | Microwave Ovens
Model TE2B garland does the fan run to move
The fan runs to circulate the heat inside the oven for more even and faster cooking...That is how a convection oven works :)
Jan 14, 2010 | Garland Convection Oven - MCO-NAT Gas
Convection oven fan keep shutting on and off
You do not list a model number, so I can not confirm this, but I suspect what you are hearing is not the convection fan, but a cooling fan, designed to come on at a certain temp to keep the control area from getting too hot.
Oct 18, 2009 | Kitchen Ranges
Kitchen Ranges Logo
698 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
