Cisco Pix 501 UDP Port Redirecting
I need to forward UDP ports 5198 & 5199 on my Pix 501 using the web based interface. Can anyone point me in the right direction?
  • 1 more comment
  • dcrmss May 01, 2008
    Thanks for the link, but I've already been there. They don't list my router. They only have 4 listed for Cisco. I guess that's what I get for buying such a secure router.
  • jeannie 7 May 18, 2008
    I use m.torrent for my downloads, but it says the port is not forwarded .. I can I configure my 3com wireless router. Portforwarding isnt any help
  • Anonymous Jul 19, 2008
    how to forward the port
    Problem Solver:
  • 5 Answers
PortForwarding.com should help you with this problem.
Posted on May 01, 2008
Go into the GUI and pull up the command line tool
I am presuming that you named your interfaces inside and outside. ( It's like that by default )
In the box put in the following information one line at a time
Replace the XXX.XXX.XXX.XXX with the IP address of the system you want them forwarded to.
static (inside,outside) udp interface 5199 XXX.XXX.XXX.XXX 5199 netmask 255.255.255.255 0 0
static (inside,outside) udp interface 5198 XXX.XXX.XXX.XXX 5198 netmask 255.255.255.255 0 0
access-list 100 permit udp any host XXX.XXX.XXX.XXX eq 5198
access-list 100 permit udp any host XXX.XXX.XXX.XXX eq 5199
You should be good to go.
Posted on Oct 15, 2008
Port forwarding not working on router cisco 861w. ROUTER nat DHCP IS WORKING. I have used this command to add portforwarding: ip nat inside source static tcp 192.168.0.222 80 interface FastEthernet4...
make sure you enable both tcp and udp port fowarding . worst case comes to worse reset it back to factory settings. or upgrade the firmware (i couldnt port foward until i upgraded my firmware on my wrt model)
Mar 17, 2011 | Cisco 861 Router
How do i make nat open
You have two options:
1. You can open port using router's web interface. Check what ports used your software, what protocol TCP/UDP then go to web interface's virtual server and add new user's rule. Then you have to save and reboot router. Every time your PC IP changed (static IP recommended) or program you using changed port number you have to do web interface operation again.
2. Download and install Router Commander (fully compatible with your router) and that's all. The software will forward ports automatically.
Dec 21, 2010 | D-Link DSL-G604T Wireless Router
I wanna open port for my DVR dvr is :- ip 192.168.1.88 cmd port 9201 video port 9202 and my router is fortigate60 i hope any one can give me full solution best regards
You will need the router login info, then using a browser go to:
https://192.168.1.99
That will bring you into the settings area of the router. Then do one of two things, find Port Forwarding, and forward the public 9201 & 9202 to the DVR at 192.168.1.88 port 9201 and 9202. Make sure to do this for both UDP and TCP.
Another and easier option, is to go to your DMZ setting. Just turn DMZ on and set it to 192.168.1.88.
Doing it with the DMZ will take care of any ports that need forwarding, they will point to the 88 machine (your DVR).
EJ
From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears.
From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears. From the management computer browse to https://192.168.1.99. The FortiGate web-based manager appears.
Jan 26, 2010 | Fortinet, Inc. FortiGate 60: FortiGate Pro...
How to forward port on telkom mega 100wr router
1. You can open port using router's web interface. Check what ports used your software, what protocol TCP/UDP/BOTH then go to web interface's virtual server and add new user's rule. Then you have to save and reboot router. Every time your PC IP changed (static IP recommended) or program you using changed port number you have to do web interface operation again.
Nov 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
On my echolink progtam it says to use port 5198 or 5199, how do I do it?
access your router with following link.
http://192.168.1.1
or
http://192.168.0.1
For belkin router http://192.168.15.1
type user nams as "admin" and password as "admin" or blank or "password"
Then go to NAT and prot forwarding .
Select your port and open TCP and UDP protocol.
Then save settings and restart router.
Let me know if you need more assistanse.
Thanks.
then go to NAT
Aug 31, 2009 | Computers & Internet
How to reset password of pix 506e
You only need a PC and a serial terminal. First of all you need to know the PIX software version you run. After that you must go to Cisco web page and get from there the utility for the password recovery corresponding to your version of software.
After that you must connect to the PIX console port. Press ESC key after the PIX is booting and a special prompt it will appear (monitor>). Issue the "interface" command to specify which interface to be active. Inside interface it will be the default one. Then use the command "address" to go with the IP address of the above interface. After that, you will need also an TFTP server where you must upload the software utility specified in the beginning of the solution (the one downloaded fron Cisco). After the "address" command, issue an "server" command to put the IP address of the TFTP server. Than, use the command "file example.bin", where the example.bin is the file downloaded from Cisco. Maybe you will need also to specify the gateway of your network. This you can accomplish by using the "gateway" command. Finally, use the "tftp" command to start the download.
The default Telnet password after this process is "cisco."Go into configuration mode and issue the passwd your_password command to change your Telnet password.
Best regards,
T
Apr 24, 2009 | Cisco Computers & Internet
How do i open my ports?
Login to the routers web interface, go to the port forwarding page and insert the information required
Mar 31, 2009 | NetGear WNDR3300 - RangeMax Dual Band...
How to connect to my PIX 501 and use Windows Remote Desktop?
Here's a real simple problem to your remote access problems.
Go to: http://www.logmein.com
Sign up for a free acct, download/install their free software on your Server.
Now go over to your laptop, login to your new logmein acct.
In the next page, you'll see your Server listed. Click on it - follow instructions to connect.
This will tunnel through whatever stuff you have on your network!
Trust me - esp. in your scenario, this is *by far* the *simplest remote connect you'll ever perform! And it just .... works! Everytime.
gurutim
Mar 16, 2009 | Cisco PIX 501 Firewall
Port forwading
http://portforward.com/
this site may be of some assistance
Jun 19, 2008 | Computers & Internet
Computers & Internet Logo
661 people viewed this question
David Payne
David Payne
