Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
37pf3720f philips plasma
Hi, I read your post regarding the red light on this set flashing 4 times. I have this set and it does the same thing. I did unplug the 1m03 connector after plugging the set up just after the relays clicked, but it makes no difference, the unit continues to flash the red light 4 times. I"m unsure where to check for the 24v to the inverter that you refered to. I"m not a tv tech, but am capable of replacing parts. any suggestions on what to look at next? thanks craig
  • 1 more comment
  • cdsn99 Apr 30, 2008
    corrected model number, 37pf7320a
  • cdsn99 May 01, 2008
    Hi , thanks for the reply, is there any possibility fo replacing a part on that ssb you are refering to? I google searched the part number you refered to and the board is over 700 dollars, more than i can replace the set for. I was hoping to be able to replace a bad resistor, capacitor, regulator , IC, etc. If I have to spend 700 dollars on a part, its just not worth it. Any suggestions?
    Thanks again
    Craig
  • Anonymous May 06, 2008
    I cannot believe what I am reading here . This is not real tech advice , Be carefull in what you believe .
    Scholar:
  • 72 Answers
Error 4 means an I2C4 communication error detected by the Viper BGA (Ball Grid Array). Basically it means you have a bad signal board . On a LCD the SSB controls everything it detected an error and shut itself down. Easiest thing to do is Order a replacement SSB. 310432842641 this is the 12NC number for the SSB or u can look it up online by model. Just good luck on finding a replacement cheap !! The removal of the cable was too see if the SSB was the error and it was.
Posted on Apr 30, 2008
  • James Peters
    James Peters May 01, 2008
    Hate to tell ya Look at the bottom of the SSB the 2 big BGA 's this is what needs to be replaced Wish it was easier but its not. U might look around on ebay or other auction sites for a damaged Tv. For that model (37PF7320) u can use a SSB from a 32 to a 50 SSB. The only thing u will have to do is change Diversity code for panel and Option Bytes (U can use these model boards 7220,7320, 9630, 5320
  • James Peters
    James Peters May 07, 2008
    Well GUEST if u have any idea what it might be why don't u submit a resolution to this problem or any of the other questions that i have try and help others out with. But if u think u can do a better job. prove it.
I have a philips 42" plasma t.v.model
hello sir Dave!!!
welcome to fixya..
Lets find out if that problem is worth to repair or not..I need some info regarding your TV such as how many flash of LED lights in front?..It will help to diagnose where the fault came from..
Please reply to this tread to post the info I need..
Thanks for using fixya..
regards,
Chester
Feb 24, 2012 | Philips Magnavox 42MF521D/37 Television
Philips 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help thanks
philips2_bing.gif 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help
Apr 26, 2010 | Philips Televison & Video
Philips flat screen 42" flashing red light 7 times it stops for 5 seconds and 7 more flashes if i unplug and plug it a few time it will come on
my 42 inch phillips, i turn it on green light comes on for 10 sec then red light comes on and flashes 4 times then stops for 5 sec then repeats.
Apr 20, 2010 | Philips 42PF9631D 42 in. Plasma Television
Philips 42PF9631D 42 in. Plasma Television TV wont turn on..I get the initial green power light, but it quickly goes to a flashing red light (flashes a series of 4 times). Philips tech support is a joke....
Philip have alot power problems with their tv.Check power board for puff up parts like Capacitors,or rust in cracks or soldering.Changes parts or the whole power board.
Jan 08, 2010 | Philips 42PF9631D 42 in. Plasma Television
42" philips plasma, black screen and flashing red light
This fix was posted on similar problem, worthy of repeating: Replaced 3300mf 10V capacitors at PS. Both had bulged slightly. Upsized to 25V as the previous solution poster had suggested 16V but I could not locate 16V so used 25V and TV is back to normal!
Nov 29, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
7 red flashing lights, won't power up..
Check the power board for capacitors with the tops bulged up. They are 3300uf 10v. There are either 2 or 4 of them depending on your set.
Jun 01, 2009 | Philips 42PF9631D 42 in. Plasma Television
Set dosen't power on/off.
Replace the small signal board 310432842611.
Oct 02, 2008 | Philips 42PF9630A 42 in. Plasma Television
Phillips Plasma Error
Firmware update via USB stick downloaded from Philips.
44hink
May 19, 2008 | Philips 42PF9630A 42 in. Plasma Television
The reciever box light flashes red
Same issue here in NZ with a set.  Fixed (twice) before.  Same problem for the thirs time in 4 years. Solution  - get a Sony.
Feb 11, 2008 | Philips FTR-9964 Tuner/Receiver for Plasma
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
203 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
