Universal Remote control BD-512
I have a remote control but it gives no clues as to its make it just says universal remote control on the bottom part and BD-512 at the top the top two buttons on the left are tv/vcr and memo and then a red power button.
Can you help me to get some info on it so that I can use it.
Thanks David C Denison
Brighouse
West yorks
England
  • 5 more comments
  • Anonymous Jul 16, 2008
    the remote came with what brands it was compatable with ,but no codes where supplied with it.i`m lookin for the code for a hitachi tv.
  • Anonymous Jul 18, 2008
    NEED INSRUCTIONS AND CODE FOR TOSHIBA TV
  • Caroline T
    Caroline T Aug 18, 2008
    Hi FIXYA team,
    I have also just bought the BD-512 Universal Remote control, and have tried the 'auto seach' facility that is described in the manual that came with the remote as there is no code listed for my TV, which is a FINLANDIA CD 51LZ 6/F. When I do the auto search, my TV suddenly turns OFF, but then I can't do anything else...i.e. turn it back on again unless I do it manually (but the remote still does nothing else after that initial switch off in autp search). So it looks like the remote does find a code, but doesn't store it.
    Can anyone help, my original remote has been broken by my little boy and I can't afford to buy a new one at 14.99.
    Yours Faithfully
    Miss. Caroline Thom
  • Anonymous Nov 25, 2008
    I NEED MANUAL FOR THE BD-512 PLEASE HELP
  • packagingima Jan 26, 2009
    I have a BD-512 Universal Remote Control however I have lost the instructions on how to match it to the TV, can anyone help?
  • Anonymous Mar 31, 2009
    need for bush tv batt ran out and lost code and book
  • hazelos1 May 13, 2009
    i lost the instructions and cant tune my t.v in. please help
    President:
  • 2,712 Answers
You can find the remote control codes for difrent brands of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your brand is not listed, and you are still not able to get the unit to respond, try the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you reach the end of all the codes for this device type.
  1. PRESS the button for the device you want to program, (TV, VCR, CABLE, etc.), then RELEASE.
  2. PRESS and HOLD the SETUP button until the red LED flashes twice, then RELEASE.
  3. ENTER 9-9-1 (two blinks on the remote)
  4. ALTERNATE slowly between the POWER key and the DEVICE (TV, VCR, CABLE, etc.) button until your device turns off. (On VCR, LD, and CD players use PLAY instead of POWER)
    Make sure that the remote is pointed at your device during the search, You may have to press this sequences of buttons up to 100 times to search the entire library of codes.
  5. When your device turns OFF, PRESS the SETUP button and RELEASE it to lock in the code for your device.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the following steps.
  1. PRESS and HOLD the SETUP button until the red LED flashes twice.
  2. PRESS 9 - 7 - 5, the red LED will flash twice.
  3. PRESS the DEVICE key where you wish to learn the function. The next 3 steps must be completed within 10 seconds.
  4. PRESS the button that will receive the learned function, the LED will flash rapidly.
  5. PRESS the button on the original remote to be learned.
Now you can repeat steps 3 through 5 to learn other functions onto other keys or press and hold SETUP until the Cinema's red light flashes twice to lock in your new feature. (If the red light does not blink twice, stop and repeat steps through 6).
To test the new feature, press and release the device key in which the new feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
If it hasn’t, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on May 02, 2008
If you want to download the origional manual go to www.remotecentral.com and enter the following filename bd512-manual.zip This worked for me as it has a full list of all models and codes and is easy to set up once you have the correct code.Hope this helps somebody.
regards,
Patrick Bourke
Posted on Feb 02, 2009
    Scholar:
  • 79 Answers
Hello David,
I found this message board where they are discussing a remote with the same model as yours. Maybe you can use the codes they are providing there?
Hope this helps
Thanks for reading!
    Problem Solver:
Its all sorted now...the remote did find the code when it switched it off, so now I press TV1 or TV2 on the remote as soon as it picks up a code and switches off and this usually stores the code straight away. !!! Hurray !!!
Now my little boy keeps getting hold of the remote control and messing the code thing up so I have to keep resetting it, but I guess thats just life !!! At least I can get it to work now.
Thanks for everyones brilliant advice. Much appreciated.
Bye for now.
Caroline xx
Posted on Nov 10, 2008
I have got bd-512 universal remot how can i set it with my tv sanyo
Posted on Nov 09, 2008
What is universal remote code for bd-2000 on rcrno4gr remote
Remote code for HP BD-2000 Blu-ray player - AT&T Community
https://forums.att.com/.../Remote.../Remote-code...BD-2000.../467...
AT&TDec 2, 2012 - I have an HP BD-2000 Blu-ray player that I recently lost the remotecontrol for. I do not see HP as a manufacturer on the DVD list when I try.
Universal Remote Control Codes List - TV SAT DVR ...
removeandreplace.com/2013/11/10/universal-remote-control-codes-list/
Nov 10, 2013 - We compiled this universal remote programming code list to make it ..... Looking for a code for a orion vcr I have a 5 digit universal remote by rca -rcrn04gr and I ... remote control code (s) for a samsung blu ray dvd player bd-fm51 /ZA ... Please, could someone to give me the code for DENON AVR-X2000.
Programming the RCA RCRN04GR Universal Remote
voxrightnow.custhelp.com/.../programming-the-rca-rcrn04gr-universal-r...
Jul 28, 2010 - Program your Remote. To use this universal remote with your home entertainment system, first you need to program it to control your devices.
[PDF]Rcrn04gr - Universal Remote Control Codes
Jan 19, 2016 | HP bd-2000 blu-ray player with 1080p...
Tuning tv using universal remote control bd 512
Check this link to download the user manual to this remote control. It has all details.
bd 512 instruction manual edited
Feb 06, 2014 | Philips Televison & Video
Am try to instal for long time but i dont know how can you help me please Universal control remote BD512
Download the user manual for the Mitsubishi BD-512 at http://files.remotecentral.com/view/454-630-1/mitsubishi_bd-512.html
Let me know if you have any problems or additional questions. Thanks.
Aug 17, 2011 | Televison & Video
I've BD 512 universal remote control,and i need code for Durabrand DVB-T CG5660-M digital set top box.Please help!!!
i need code for a durabrand dvb- digital set top box me remote is a bd-512 universal remote control
Jan 14, 2011 | Audio Players & Recorders
WHAT IS THE CODE FOE A BEKO TV ON A BD-512?
There is no such thing as a 'universal' remote; even the 'learning' remotes do not learn from every original. There may not be any code for all the devices you own. I suggest always checking the remote manufacturer's website for codes on all equipment you wish to control before buying any remote.
If you need an original remote, try remotes.com
Feb 15, 2010 | Beko 142746 TV
I HAVE A BD-512 UNIVERSAL REMOTE CONTROL AND I WAS WONDERING IF
find your answer ---
http://www.remotecentral.com/cgi-bin/mboard/rc-remote/thread.cgi?5550,5
Nov 12, 2008 | One For All URC4220 Remote Control
Bd 512 universal remote control i need instructions and code to tune into video
Your manual is available free from the following address:
RC Files: Miscellaneous - Universal Remote Control Manuals Search (1)
Glad to help, please remember to rate this solution if you found it useful,
erch.
Mar 19, 2008 | Televison & Video
Remote control code needed
i have a connect- it bd512 universal remote control i need a code to programme in to my tv it is a baier please help!!!!!!!!!!
Mar 11, 2008 | Televison & Video
Remotecontrol code
One of these codes should work:
013, 031, 044, 074,119,120,121,122,123,162,167,170,182,195,205
Hope that helps!
Jan 08, 2008 | Jensen JER-422 Universal Remote Control
Remote control codes for freeview and dvd recorder
According to the booklet you have to enter the code 119 for a Goodmans TV, however it does not work with my Goodmans portable TV and even quick search / autoscan doesn't find the TV.
Nov 25, 2007 | Jensen JER-422 Universal Remote Control
Televison & Video Logo
14,598 people viewed this question
Top Televison & Video Experts
