Sony black trintron 21
Keep loosing colour and comes back after a while
  • tnein May 01, 2008
    Thanks for the reply. The colour goes off when I am viewing TV programmes. The signal is fine and this problem has only recently started.After a while the colour picture comes back and again after say 10 or 15 minutes it reverts to B&W.
    Novelist:
    Scholar:
  • 148 Answers
What inputs are you viewing. Color can often be lost when viewing the S-Video input if there is a bad cable.
Also you can loose color when viewing a broadcast signal if the reception is weak.
Color can also be lost if the tuner in the television is being over driven by a signal that is too strong, try using an RF attenuator from radio shack.
Posted on May 01, 2008
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
Sony trintron is on stanbymode
count the blinks on the power light--most will have a error code where the power light blinks a specific number of times---does not point to a specific part but indicates what area problem is in.
Jun 11, 2012 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony trintron Tv KV-HA21P50, its alot of green color, whats is the problem.
Hello
Loose soder points in the video output board of your Sony Trinitoron is the problem. Solder loose on the green output transistor will show this kind of fault with this type of CRT based sets. Just open your TV, and locate the video output board. It can be located at the picture tube base itsef. This board is pluged diretly to the back of the picture tube. Just pull it out straight backward, without making any sideways shake. You may have ot apply some backward pressure to detach it out. Just look for any loose solderings at the solder terminal of this board.
It is very difficult to detect the loose soldering by ***** eye, as it will be microscopic in nature. It is a best practice, to resolder most of the solder terminals of that board, by app;ying a little more solder, whout making any solder bridge in between adjecent solder terminals. This will solve the colour problem to your TV.
I've attached a picture of a tV with back opened. You can see the Video Output Board pluged on to the back of the picture tube. Just resolder all the picture tube base socket terminals solderings also. OK
gopakumarg43_35.jpgHere the main board has been pulled out and placed vertifally at service position. The CRT board [video output board] can be located as you open the TV.
Aug 30, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My sony trintron 21" the bottom half is black i
solution
step 1 : Now at first test your fly back transformer
step 2 : A.C. transformer out put voltage test
step 3: Vertical yoke coil adjust
Jul 30, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
My sony trintron 21" bottom
RE-SOLDER VERTICAL SECTION & CHECK IT.ALSO CHECK PIN CUSHION SECTION.
Jul 29, 2011 | Sony FD Trinitron WEGA KV-21CL10 21" TV
HI I HAVE SONY TRINTRON TV I NEED TO RESET THE TV
I already seem this on that model and it was a short diode D503 part # BY228GP.
Apr 22, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
When initially turned on TV will alternat between picutre & black
When the tv goes to a black screen does the sound remain on? Also,if you listen carefully can you hear any arcing noises in the back of the tv?
Aug 03, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony Trintron Model # KV-27S22 Flashing screen
Hello
I got it fixed today at the TV repair shop down the street.
Thanks
Nov 11, 2008 | Sony HT-DDW840 System
I want to replace my fbt
Your required FBT is available in Part Store. Check it out.
Sep 19, 2008 | Sony Televison & Video
Sony Trintron KV-32FX20U
This is a problem with the "AKB" circuit. There is a problem with the video signal. Are you comfortable changing parts inside the set? If so, please update this. I'll look up the specific parts for this model and post them.
Dan
Mar 18, 2008 | Sony KV-32FX20U 32" TV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
