My Sansui G-5700 receiver unit still works great... except for the FM radio. It no longer receives FM, nor does it show (on the digital display) any signal strength or FM frequency across the FM band. (The digital display does show a "constant" frequency, however, of about 143 MHz, which slowly decreases over time, but never gets down the the FM frequencies.) AM radio still works, as do all audio functions. Several weeks ago, I left the unit on for about an hour, and the FM receiver started to work again. After a few days of non-use, the FM stopped working altogether. What to do now?
Sincerely,
Ronald W. Frye
San Ramon, CA
e-mail: [email protected]
ph: 1-925-838-4845
SOURCE: great signal, so sound
My XM Boombox is also white and it is a Belkin. The folks at Delphi told me the receiver in the boombox is screwed up which over time also screws up the Delphi receiver. Belkin is sending me a new boombox and Delphi is sending me a new Roady XT.
SOURCE: SIRIUS Sportster "Acquiring Signal"
Let me save you $30.00. A new antenna will not help, nor will cleaning the contacts. I just did both of those and it did not help. I have mine in the freezer right now cooling it down. Sirius told me that I should not leave it in the car because it gets to hot. They told me to buy another unit....
SOURCE: USA - EUrope FM band stations frequency differences
I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
If you have purchased a car stereo from the US you will find that it
will not pick up many European radio stations. This is due to the fact
that US radio frequency steps are different to here in Europe.
You may be able to set the tuner to European stations by following this procedure.
Press and hold down the SRC button to power down the unit completely.
While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
If this does not work try the following proceedure;
Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
If this does not work then the unit is not designed to pick up European frequency steps.
SOURCE: How do I change fm
first goto menu then scroll down set fm frequencythen set it where you want
