Question about Belkin (F5D7633UK4A) Wireless Router
Main PC can't connect but others can!
Hi, I have the Belkin F5D7663-4 modem router, which I've been running for a while with a home network of 2 PCs and a laptop accessing the internet wirelessly. I recently installed a Firewire port card in the main PC next to the router and when I rebooted it wanted to reinstall the adapter (also Belkin).
I reinstalled it but despite all being well on the router, I can't connect. When I click the Belkin icon and connect, I put in my key and it turns blue for a couple of seconds as if connecting then goes red again. At suggestion of Belkin I've connected an Ethernet cable today (no change, in fact, PC hasn't noticed this) and tried to access the long number that Belkin suggest in the handbook without http etc. Won't connect (although my IE does keep trying to put an http at the front). So I can't even get in to see if my key is wrong!
The other desktop and this laptop have continued to connect no problem so clearly not the router.
Help!
Could it be the adaptor?
Wrong key?
McAfee?
All suggestions appreciated!
  • SammyP70 May 08, 2008
    Thanks, I'll have a go!
  • SammyP70 Jun 02, 2008
    Sadly, this didn't work. Just get address not valid or cannot find the webpage. The blue Belkin icon flashes constantly from blue to red so it's trying to connect but something is stopping it. I think the PC hasn't registered that I've connected it to the router via an Ethernet cable. Any suggestions anyone?
    Problem Solver:
  • 17 Answers
I had this model of router quite some time ago. I had some bad experiences where when I tried to login to it I was unable to, the web based management interface would not respond (as you have described) . Resetting the device would resolve this I would recommend trying that. Unplug it, wait a few minuets and plug it back in. Then try again to access the management interface. 192.168.1.1 or 192.168.0.1 or whatever via a web browser.
Posted on May 01, 2008
My belkin router will not recognize the LAN connection of three PC. It will accept my laptop using the same Ethernet cables. I have recycled the router and reset my network. Still no connection. We had a...
Did you try direct wiring the other pcs to see if they will connect separately? If they won't then check the network settings on each pc that won't connect. Make sure that the gateway address is the same ip address as the router is.
Did it work before the outage, all of them at once? If so go to the Command Prompt (RUN, type in cmd, enter and a small window will pop up), and where the cursor is blinking type in - ipconfig - (some win versions use winipcfg) , hit ENTER. That will tell you what address are set to. It should say 192.168.xxx.xxx.
Type in - ipconfig /release - ENTER. That will reset the addresses which should now all be zeros.
Now type in - ipconfig /renew - (make sure you have the blank space between the g and the /). This should give you the 192.168.xxx.xxx address for IP if your network settings are set correctly under Network Connections- Properties-TCP/IP
Sometimes under outages you need to reset both the modem, the router and the pcs to acquire the new addresses.
Feb 22, 2011 | Belkin Computers & Internet
Setup belkin wireless network
1.Connect a Cat5 cable into the Ethernet port on the back of your cable or DSL modem. Plug the other end of the cable into the "Connect to Modem Internet/WAN" port on the back of the Belkin Router.
2.Connect a Cat5 cable into the "Ethernet" port on the back of any desktop or stationary computers and then plug the other end of the cable into one of the LAN ports on the back of the Belkin Router. Start with port one and work your way up with subsequent computer connections.
3.Turn the Belkin Router on by plugging the router into a power outlet. Allow 30 seconds for the router to fully boot up. All computers tethered to the modem via a Cat5 cable have access to the Internet.
4.Open the Wi-Fi Wizard on your laptop and turn on the Wi-Fi antenna. Once turned on, the Wizard finds all network connections in your area. Connect to your network to establish an Internet connection. Complete this step for each computer not tethered to the Belkin Router with a Cat5 cable.
Thanks for using Fixya
Proton
Oct 04, 2010 | Computers & Internet
Belkin N1 wireless network not working
It might be an idea to upgrade the firmware which can be downloaded from manufacturers' website
Mar 20, 2009 | Belkin N1 Vision Wireless Router
Problem with Mac and Belkin router
I have a Mac Pro and a Belkin F5D 7230-4 Router. The Mac links to the WiFi but will not go on to the internet. The Router works fine with a wired PC and other wireless PCs. I have updated the Belkin with the latest Firmware but it does not help. I have tried powering down the Router and Modem
Gmac
Feb 18, 2009 | Belkin (F5D5231-4) Router
File Sharing
Here’s a very short summary of how to create a home network:
1) Create a named Workgroup (computer network name).
In Windows, the defaults are MSHOME or WORKGROUP, but you can choose your own
2) Add computers to the named Workgroup
3) Enable file and/or printer sharing.
Here are some resources to help you:
1. Windows XP has a wizard to walk you through it - see tutorial here
2. For Vista, try this link for a detailed overview: http://technet.microsoft.com/en-us/library/bb727037.aspx
These links might help too:
http://www.dummies.com/how-to/content/how-to-create-a-pc-network-workgroup.html
http://www.dummies.com/how-to/content/connect-to-and-share-files-with-other-pcs-on-your-.html
3. When it comes to sharing folders, there are two main ways to do this. You can either 1) right click the folder and enable sharing through the shortcut menu., or 2) add the file/folder to ‘Shared Documents’ (for XP) or ‘Public Folder’ (for Vista).
Hope this helps, but please come back to Fixya if you have any difficulties. Good luck!
Jan 25, 2009 | Belkin (F5D8231-4) Wireless Router...
Trying to set up wireless from desktop (Main ethernet computer) to Laptop @ home. Have cable modem (comcast) connected to desktop (main ethernet plugged computer)Belkin Wireless Router G ethernet is hooked...
Check that the wireless drivers are installed properly on both your laptop and desktop. THe certificate error is because your laptop does not "trust" your computer. Under network conections click add a connection ec, and when you try to conect, microsoft should ask you weva to trust the connections from computer to computer that should do it :D
Sep 07, 2008 | Belkin Computers & Internet
Belkin N Modem Router If main PC which is ethernet wired to the modem router is swtiched off, laptops cannot access the internet. Does this mean that the PC to which the modem router is connected has to...
it will as long as the modem/router is connected to a phone line, instead of the pc, the only cable connected to the pc should be a ethernet cable; or you have the pc networking set that it connects via another pc instead of through a gateway, re run the wireless network wizard.
Sep 05, 2008 | Belkin Computers & Internet
Setup asistant will not work with Belkin wireless router & computer
Try the manual method.connect router to pc with ethernet cable
1.logon to 192.168.0.1
2.Connection type ; PPPOE
3.type in your username@ISp and pass
4.Save settings
5.Configure wireless setting(SSID,Wep)
Configure pc with the same SSID and WEP
uplug the ethernet cable and check if your are able t connect wireless
if you still have issue use this guide
Cheers !!!
Feb 23, 2008 | Belkin (F5D7230-4) Router (587009)
Change user at remote PC then cannot connect
the other user wireless access permission migtht not be activated, enable the user wirless access
Dec 11, 2007 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Belkin (F5D7633UK4A) Wireless Router Logo
99 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
