JVC AV-32260 timer led flashes
Television will not power up after electrical surge but timer led flashes. Any ideas? TV WILL NOT STAY ON. WHEN YOU TRY TO POWER UP THE RED LIGHT INDICATOR WILL NOT STAY ON. IT FLASHES AND GOES OFF AFTER 1 OR 2 SECONDS.. I'VE RESET THE POWER STRIP I'VE CHECKED ALL CONNECTIONS AND I'VE VACUUMED ALL DUST AROUND THE TV
  • Anonymous Apr 30, 2008
    tv wont show pictures or no sound comes out when it is on
    Novelist:
    Scholar:
  • 148 Answers
When your set first turns on it runs a systems check to see if the boards inside are safe to apply voltage to. also it checks the power supply to see if it is safe to power up.
Either it needs a factory reset which the procedure changes for each model. or it simply has more wrong with it after the surge and requires more to fix it then the cost of a new set.
The best bet is to look on EBAY for a similar set with something like a broken screen. swap out your screen into its chassis.
if you do not feel up to the challenge of doing that you may be looking at repair costs and parts that are more then a new set.
Posted on May 01, 2008
Remote control code for jvc tv
HERE IS SOME CODES FOR THAT TV 557 558 559 560
Jan 11, 2009 | JVC AV-32260 32" TV
Jvc tv av-32d502 timer light is flashing will not turn on
Hello, I am a tv tech. I worked on a JVC AV-32D502 today. Problem: led flashes / no power or picture at all. Same as trobertson52's set. The microprocessor is bad in my machine. trobertson52, if your sets' relay does not click when the power button is depressed you most likely have the same problem or the standby power circuit is at fault. That circuit supplies +5 volts to the micro.
Edtal you have a different problem with your machine. Your machine is going into shutdown. A number of circuits could cause this and would need to be looked at by a technician to determine exactly which circuit is at fault. High voltage transformer (HOT) \ Vertical Circuit \ Power supply are the most likely causes.
barneyinNC
Sep 25, 2008 | JVC AV-27020 TV
Tv JVC AV 22260
have had cases where electrolytic capacitors dry up and cause no start. set should be checked by a technition; get estimate on repair before throwing set.
Sep 21, 2008 | JVC AV-32260 32" TV
Power button flashing, will not turn on or off
Electrolytic cap in low voltage supply
Apr 23, 2008 | JVC AV-32260 32" TV
No picture
try resoldering vertical output ic pins, no vertical deflection will shut off picture. may need ic replacing along with electrolytic cap.
Apr 22, 2008 | JVC AV-32260 32" TV
JVC AV32260G COLOR TV
try resoldering vertical ic pins
Apr 19, 2008 | JVC AV-32260 32" TV
JVC TV AV-32260 power surge now power button flashing
Check for swollen top on power supply capacitor ......check
all caps with ESR meter....all with C900 series location #'s..
also check C523 in horiz drive circuit..............T.
Dec 01, 2007 | JVC AV-32260 32" TV
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
