Question about RCA F19430 19" TV
Won't turn on
The TV would not turn on or make any kind of noise so i took the back cover off and noticed the fuse was blown so i replace the fuse and still nothing what should i look for next.
Il ne s'allume pas et il y a un regulateur dont je peux pas voir son numero
Posted on Aug 15, 2008
After a power outage, the tv wont turn back on. was hoping there is a fuse that may have blown.
Hi Michael,
Yes there is a fuse in your TV too and sometimes you do escape with a blown fuse after a power outage. Please open if you can the back cover of your TV, locate the fuse. If you do not see any damaged or blown parts, replace the fuse with the same rating. If the works, enjoy watching. If the fuse blows again, the power board needs to be repaired or replaced.
Good luck.
Apr 04, 2016 | Sanyo Televison & Video
Clicking noise coming from the fuse box "under the dash" when I turn on the heat, now car won't start.
that item is called a relay switch. it toggles on and off depending on which electrical component it is connecting. if it's blown, they are cheap and easy to replace like a fuse, but you'll need to look at the fuse box chart (usually on the underside of the lid) to determine which one and where it's located. You can't look inside the relay to determine if blown, but you can replace them one at a time to test...
Also, if you're experienced in electrical, a paper clip can be used when the relay is out, to connect the circuit that you need. use tools and or gloves when attempting this method.
Jan 17, 2018 | 2003 Ford Taurus
I have aVizio VX42L HDTV10A. was watching a show when we heard a loud pop.Then all went dark. Would not turn back on. I took off the back cover and found the ceramic fuse was blown on the board # DPS-283AP...
This means you have a dead short, It is probably a Diode in the power supply area, but without testing board you don't know. If you know basic electronics, i would say check all diodes in power supply and look hard for something burnt and replace that also. Or just replace power board, check shopjimmy.com
Dec 08, 2010 | Vizio VX42L 42 in. LCD TV
TV will not turn on. The fuse is blown. Need to
hello,
replace the fuse with the rating of 2.5A,
you can also check the iron head of the fuse.
Good luck...
May 25, 2010 | Televison & Video
Screen blank
Sounds like a cap or fuse has blown in the set, you will need to take the back cover of and have a look, check on the power board for any blown caps, you will notice them straight away if one has poped, also check any fuses that may have blown they will also need to be replaced.
Feb 18, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
125 v 4 amp fuse keeps blowing
if you plugged a 125 volt tv in to a 220 volt outlet you more than likely fried alof of the componets in the tv. Putting a bigger fuse in there is only going to increase the risk of it catching on fire so i would not recomend that. you might replace the power supply and cross your fingers and hope that nothing else cooked when the 220 volts hit it
Mar 14, 2009 | Televison & Video
My sharp LC-20AV4U tv did not turn on when i plugged it in
The fuse is blowning because most likely when you plugged it it, it took a power surge. And the power surge blow a proection diode. As long as you opened it up... in the power section you will see a bunch of diodes. Get a multi meter and check these diodes out. Besides the diodes... you will see a transformer.... if you are looking at the unit with the fuse to the left... then look to the right of the transformer... you will see a transistor on a metal heat sink... that could have blown also.. if that did... then you should also check the diodes just on the other side of the heatsink too.
Good luck
Dec 16, 2008 | Sharp LC-20AV4U Television
Blown fuse on panasonic tv
Maybe the horizontal output IC are on short circuit.
Nov 04, 2008 | Panasonic PV-DM2799 27 in. TV/VCR/DVD...
No picture
Have you tried checking the fuses this is a solution i posted a little while ago!!! I was watching tv there was a popping noise and screen went blank. My husbands very practical and we took the back off the tv ,we tested the fuses with a fuse tester and one had blown we took the fuse too Maplin our nearest electrical wholesaler who found us new fuses £1.29 for a pack of 10. We replaced the blown fuse now everything works as it should. Hope this helps we saved about £275 by doing it ourselves but do make sure you feel competent enough to have a go its not that hard but do make sure you unplugg the tv from the electric before you attempt taking off the back and checking the fuses and be careful as tvs can store a electric ok
Feb 24, 2008 | LG RU-42PX10 42 in. HD-Ready Plasma...
RCA F19430 19" TV Logo
117 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
