Question about Sanyo MM-8300
Sanyo 8300 my phone went thru a wash cycle in the on possition.how do i retrieve numbers from phonebook????
    Problem Solver:
  • 9 Answers
First, you need to remove the battery and any flash cards, then you need to dry the phone (NOT WITH A HAIRDRIER!). To dry the phone, you should bury it in a bowl full of those moisture-absorbant "do not eat" packs that come with shoes or other purchases. However, these are often not available. Instead, use plain white rice (dry) to bury your phone in a bowl. Leave it for 1-2 weeks (the longer the better, up to a month) and one last thing, if it was removed from soapy water, as odd as it sounds, it should be fully rinsed in clean cold tap water. If it still won't work after all that, you could try a data-retrival place (if you can pay for it!). Hope this helps, WolfIan.
Posted on Jul 08, 2008
How do you put numbers into phonebook inan aspera f36.
To delete a number from the Phonebook
1. Press the Phonebook button to open the list.
2. Use the Up and Down arrow buttons to scroll thru the list to find the wanted number.
3. You now have 2 choices:
a) Edit the entry so that you create a new entry - Press the Menu/Select button then select Edit and enter the new information.
b) Delete the entry - Press the Menu/Select button then select Delete, wait for the phone to ask for confirmation, then select Yes
To create a new entry in the Phonebook - Press the Phonebook button to open the list, press the Menu/Select button then select Create New then enter the information.
Here is a link to the User Guide for your phone.
https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/D1760om.pdf
Aug 15, 2017 | Cell Phones
My contacts and my recent caller IDs are unavailable , Why?
Try to reset. Maybe it doesn't restore your recent calls or phonebook but at least get them to functioning.
May 10, 2015 | Uniden DECT 6.0 Cordless Phone
Tracfone went through the washing machine
Hello, Call cust. Service
1 (800) 867-7183
Nov 09, 2013 | tracfone.com
I have no idea what standby looks like; but I can't access the phonebook; I see the symbol, but nothing happens when i press it; I have successfully linked my cell and downloaded the phonebook from cell;...
A qualified person will have to remove the back (and circuit boards if necessary) to get to push buttons. Check for bits of plastic or something stuck between push button and circuit board. Check for corrosion on circuit board or missing /misaligned switch pieces.
Oct 29, 2013 | Uniden D3588-2 Corded / Cordless DECT 6.0...
My samsung s3600 was not switching on completely i followed a custom code from internet and it worked but in the bargain i lost all my phonebook contacts how can i recover these invaluable contact numbers.
If the code you have applied is a master reset code then there will be no way to retrieve your numbers, unless they were saved on the sim, check that the phonebook is set to 'View SIM Contacts' by Address book > Menu key > More > Settings > Memory in use > View contacts from...
It is often set to only look on the phone as default.
Feb 03, 2011 | Samsung S3600 Cell Phone
RAZR V3 CELL PHONE
take the phone to a mobile service center and have them professionally fix n service the phone.....the flexcable needs to be replaced along with having the board tested.
Sep 10, 2008 | Motorola Mobility RAZR V3
Sanyo MM-8300: ALL the keypads are frozen and won't work. Any solutions?
One thing you could test for is a thermal-fault in the phone's circuitry. To do this, you put your phone in the fridge over-night then, turn it on the next day and try the keypads while it's still cold from the fridge. If that doesn't help and you're brave enough to venture into the inner-workings of your phone to attempt repair/cleaning, you can read my post here- keys won't work on sanyo mm 8300 phone.
Hope this helps, TechnoWolfy.
Apr 20, 2008 | Sanyo MM-8300
To unlock code no. of sanyo mm-8300
call *2 - sometimes the rep will help you over the phone and other times they will tell you to take it in to the store to have it reset.
Mar 14, 2008 | Sanyo MM-8300
Sanyo spc 3200 cell phone. setting for unavailable or blocked calls
In the settings menu you can go to "security" then "others" then "limit use" then "Incoming calls" then "phonebook only". This will allow your phone to receive only calls from numbers in your phonebook.
Nov 13, 2007 | Sanyo SCP-3100 Cellular Phone
Help! My phone went through the washing machine
Hope? almost none. But try the instructions on the following thread- http://www.fixya.com/problems-solutions/t102703,p401560/Nokia-6230.aspx Good luck!
May 03, 2006 | Sanyo RL-4920
Cell Phones Logo
73 people viewed this question
Top Sanyo Cell Phones Experts
Computer Repairing
Computer Repairing
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
270rexton
270rexton
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
