I want to install the attache - Computers & Internet
  • 106 Answers
Jsut plug it in the usb port and it the windows do not recognise the device than update the driver from driver CD
Posted on Apr 30, 2008
I need help on removing door panel on 2000 Dodge Caravan - window fell in dorr and I can not seem to get the panel off. Any suggestions?
Answer
FRONT DOOR TRIM PANEL
REMOVAL
Using a trim stick (available from parts stores), pry courtesy lamp from door trim.
Disconnect wire connector from courtesy lamp.
If equipped, remove screws attaching door assist handle to inner door panel.
If equipped, remove screw attaching door pull cup to inner door panel.
If equipped, remove screws attaching trim panel to door from below map pocket.
If equipped, remove window crank.
Using a trim stick, remove screw cover from switch panel.
Remove screws attaching switch panel to door trim.
Remove power accessary switch from door trim Front Door Switch Panel
Disconnect power switch from wire connector.
If equipped, using a small, flat bladed pry tool, remove memory seat/mirror switch and disconnect wire connector Memory Seat/Mirror Switch
If equipped, remove screw holding door trim to door panel from behind inside latch release handle.
Disengage clips attaching door trim to door frame around perimeter of panel Front Door Trim Panel
Lift trim panel upward to disengage flange from inner belt molding at top of door.
Tilt top of trim panel away from door to gain access to latch linkage.
Disengage clip attaching linkage rod to inside latch release handle Inside Door Handle Linkage
Separate linkage rod from latch handle.
Remove front door trim panel from vehicle.
INSTALLATION
Hold top of trim panel away from door to gain access to latch linkage.
Place linkage rod in position on latch handle.
Engage clip to hold linkage rod to inside latch release handle.
Place front door trim panel in position on door.
Install trim panel into inner belt molding at top of door.
Install clips to attach door trim to door frame around perimeter of panel.
If equipped, install screw to attach door trim to door panel behind inside latch release handle.
If equipped, connect power switch into wire connector.
Place power accessary switch in position on door trim.
Connect wire connector into memory seat/mirror switch and install switch into trim panel.
Install screws to attach accessary switch panel to door trim.
Install screw cover into switch panel.
If equipped, install window crank.
If equipped, install screws to attach trim panel to door inside map pocket.
If equipped, install screw to attach door pull cup to inner door panel.
If equipped, install screws to attach door assist handle to inner door panel.
Connect wire connector into courtesy lamp.
Install lamp in door trim.
Feb 02, 2012 | 2000 Dodge Caravan
Tip
Hardware installation is different from the installation of software. I will...
Hardware installation is different from the installation of software. I will give you a tips that will help you ever in your life. Always remember that first you should install its software or driver and then attach the hardware or if the software or driver installation require attachment of the device then you should attach the device or hardware with computer during installation. After the installation you should reboot your PC once a time. Kindly, follow my instructions, you will get succeed in installation of any hardware.<br /> <br /> <br /> Good Luck
on Feb 14, 2011 | Computers & Internet
Windshield wiper moter went out i need to change it out. how do i change it?
  1. Disconnect the negative battery cable.
  2. Remove both wiper arm and blade assemblies.
  3. Remove the cowl grille attaching screws and lift the cowl grille slightly.
  4. Disconnect the washer nozzle hose and remove the cowl grille assembly.
  5. Remove the wiper linkage clip from the motor output arm.
  6. Disconnect the wiper motor's wiring connector.
  7. Remove the wiper motor's three attaching screws and remove the motor. To install:
  8. Install the motor and attach the three attaching screws. Tighten to 60-85 inch lbs.
  9. Connect wiper motor's wiring connector.
  10. Install wiper linkage clip to the motor's output arm.
  11. Connect the washer nozzle hose and install the cowl assembly and attaching screws.
  12. Install both wiper arm assemblies.
  13. Connect the negative battery cable.
Installing the wiper arm connecting clip.
Feb 25, 2011 | 1992 Ford F250
How i can stall hp printer d2460 driver
Please Always remember that first you should install its software and then attach the hardware or if the software require attach the device with computer during installation, then you should attach. If you follow my instruction, you will get succeed in installation of any hardware and also in this case.
First insert the CD in CD Rom and install the software and after installation or during installation where the Computer Require attach the printer and it will work 100% guaranteed.
Good Luck
Feb 13, 2011 | HP Office Equipment & Supplies
I am looking for a diagram of the bumper assembly for a 2004 Chrysler town & country.
Hope this helps, it it does please leave feedback and vote Thank You and Good Luck
  1. Release hood latch and open hood.
  2. Remove the headlamp assemblies.
  3. Hoist vehicle and support with safety stands.
  4. Remove the five push pin fasteners attaching bottom of fascia/air dam to radiator closure panel.
  5. Remove front wheels.
  6. Remove front wheelhouse splash shields fasteners as necessary to gain access to bolts attaching front fascia to fender.
Fig. 1 133387737
Fig. 2 133387738
  1. Remove the two bolts and two nuts attaching fascia to the front fenders (Fig. 1) and (Fig. 2).
  2. Disconnect fog lamp wire connectors, if necessary.
  3. Lower vehicle.
  4. Remove two bolts attaching the upper grille support to the headlamp mounting panel at each side of the grille.
  5. Remove bumper fascia from vehicle.
INSTALLATION
  1. Position front bumper fascia on vehicle (Fig. 1) and (Fig. 2).
  2. Install the two bolts attaching fascia to headlamp mounting panel at each side of grille.
  4. Install the two bolts and two nuts attaching fascia to the front fenders. The fascia should be flush to fender.
  5. Install front wheelhouse splash shields fasteners.
  6. Install front wheels.
  7. Connect fog lamp wire connectors, if necessary.
  8. Install the five push pin fasteners attaching bottom of fascia to radiator closure panel.
  9. Lower the vehicle.
  10. Install the headlamp assemblies.
Jan 02, 2011 | Chrysler Town & Country Cars & Trucks
How do I remove the side sliding door from a 1998 Ford Windstar?
To prevent damage to the vehicle, two people should perform this procedure.
  1. Remove the interior trim panel.
  2. Remove the bolt attaching the lower guide bracket and roller.
  3. Remove the bolt attaching upper guide bracket and roller.
  4. Remove the guide bracket and roller from the door.
  5. Remove the hinge from the door.
  6. Remove the door from the vehicle.
To install:
  1. Position the door on the vehicle.
  2. Install the hinge from the door.
  3. Install the guide bracket and roller on the door.
  4. Install the bolt attaching upper guide bracket and roller.
  5. Install the bolt attaching the lower guide bracket and roller.
  6. Tighten bolts to 89-124 inch lbs. (10-14 Nm).
  7. Install the interior trim panel.
Oct 22, 2010 | Ford Windstar Cars & Trucks
How to install HP LaserJet P2015dn Printer ?
>> First of all install its software without attach printer
>> After installing it, attach printer or attach if software required during installation.
>> After attaching the printer it will detect its driver automatically.
>> When installation will complete you should must a reboot and then you can use it.
<<< Good Luck >>>
May 19, 2010 | HP LaserJet P2015dn Printer
1990 cutlass ceira how do you replace drivers door side mirror
Outside Mirrors REMOVAL & INSTALLATION Standard
  1. Remove the door trim panel and detach the inner panel water deflector. With the glass in the down position, pull out the front portion of the glass run weatherstrip. Fig. 1: Unfasten the attaching nuts from the mirror base studs, then remove the mirror 8c45877.gif
  1. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler, then rotate retainer rearward.
  2. Remove the noise control patch to gain access to the screw at the belt, then remove the screw.
  3. Remove the filler attaching screws at the top front of the window frame, then remove the mirror and filler from the door.
  4. Remove the attaching nuts from the mirror base studs, then remove the mirror. To install:
  5. Be sure that the mirror gasket is aligned.
  6. Replace the mirror and filler on the door. Install the filler attaching screws at the top front of the window frame. Attach the nuts to the mirror studs and tighten.
  7. Install the screw at the belt, then insert the noise control patch.
  8. Insert the retainer, then install the attaching bolts and screws to the front glass run channel lower retainer to filler.
  9. Replace the front portion of the glass run weatherstrip, insert the inner panel water deflector, then reinstall the door trim panel.
Manual Remote
  1. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  2. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  3. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  4. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  5. Remove the filler attaching screws at the top front of the window frame.
  6. Remove the mirror base with mirror and cable assembly from the door.
  7. Remove the mirror to filler attaching nuts and remove the mirror and cable from filler. To install:
  8. Be sure cable is routed around front glass run channel retainer and installed to clip.
  9. Install and connect the cable to the filler.
  10. Attach the filler nuts to the mirror, then tighten to 72 inch lbs. (8 Nm).
  11. Install the mirror base with the mirror and cable assembly to the door.
  12. Insert the filler attaching screws to the top of the window frame, then install the screw to the belt.
  13. Secure the noise control patch.
  14. Attach the bolts and screws to the front of the glass run channel lower retainer and filler.
  15. Install the glass run weatherstrip.
  16. Attach the inner panel water deflector, door trim panel and mirror remote control escutcheon.
Electric Remote
  2. Remove the mirror remote control escutcheons and door trim panel. Detach the inner panel water deflector and the electrical connector for the mirror. NOTE: Right side remote mirror may require detaching part of the instrument panel.
  3. With the glass in the down position, pull out the front portion of the glass run weatherstrip.
  4. Remove the attaching bolts and screws from the front glass run channel lower retainer to filler and rotate retainer rearward.
  5. Remove the noise control patch to gain access to the 0.3 in. (7mm) screw at the belt and remove the screw.
  6. Remove the filler attaching screws at the top front of the window frame.
  7. Remove the mirror base with mirror and electric connector from the door.
  8. Remove the mirror to filler attaching nuts and remove the mirror and electric wire from filler.
  9. To install, reverse Steps 1 through 6. Be sure electric wire is routed around front glass run channel retainer and installed to the clip. Tighten the nuts to 72 inch lbs. (8 Nm).
  10. Connect the negative battery cable, then reset the clock, radio and any other accessories if required.
Aug 25, 2009 | 1990 Oldsmobile Cutlass Ciera
Sandisk u3 cruzer micro usb device 16gb is not getting installed
My dear! first install software only without attaching USB when your USB required the software or driver then attach it or if your software does not required USB attach during installation, you have to attach it after the installing software. May it require reboot your system. Now your USB sandisk u3 cruzer micro device will work.
thank you
Jul 30, 2009 | Computers & Internet
How to install to my pc
First of all install its software then your PC recommend to attach the cam, so you should attach the cam. After attach the cam it will automatically check its driver. Your A4tech CD should be in CD Rom. Now in a minute your installation will be complete.
Thank You
Jul 30, 2009 | A4tech PK5
Computers & Internet Logo
19 people viewed this question
David Payne
David Payne
