Question about Video Game Consoles & Games
It sorta fell on the street as i was exiting a taxi, the ground was wet...the psp charges but the green power light flashes on for a nano=second when you turn it on but overall the psp doesnt turn on
  • 107 Answers
The first thing you can try is replacing the battry, it seems when dropped the battry tends to short out. If that does not do it then it is time for repairs. Here is a list that I have found when I needed to get repairs.
http://www.fixmyplaystation.com/psp_repair.html
http://www.pdasmart.com/psprepair.htm
http://techrestore.com/xcart/home.
http://www.modchipman.com/sony-psp-repair-service-repair-your-broken-psp-p-1545.html
Posted on May 02, 2008
My psp worked for two years and all of a sudden it just doesn't want to turn on. I tried to to turn it on but the green light flashes for a nano second and nothing happens I need help any suggestions??
like all rechargeable ion batteries in electronic devices, they can be worn out and need to be replaced. the ion cells die within the battery overtime and cant take charge anymore so the battery starts to become useless. but since PSP is out dated because PSP3 came out not too long ago, you will have a harder time finding a replacement for the battery. but Amazon.com will certainly have them because they hold more products than any store available. thats where i do shopping alot. and they are very cheap priced. but then you will probably need someone to replace the battery for you.
Apr 16, 2013 | Video Game Consoles & Games
My psp 1006 is not working, the power green flash light comes for 3 second on and off the screen stays black.
Let's start with the obvious first. It the psp properly charged? if yes, then contiue reading. Try taking out the battery and putting it back in. You may also take out the battery all together and just run it off the AC power adapter. if the unit runs fine just using the AC adapter, it means that your battery is busted. If the unit still does not work, your Memory Card may be the culprit. Try removing the memory to confirm if it is indeed causing the problem. Replace if needed.
I hope everything works out. All the best to you.
Jul 12, 2011 | Sony PlayStation Portable (PSP) Slim...
My PSP will not turn on unless it is plugged into the outlet. When I try to turn it on by itself the power light flickers green for two seconds and then disappears. Also, the battery is fully charged. When...
replace the battery as it may be out of CYCLES even tho it says its fully charged if the battry is new your going to need a new element inside usually this consist of a new logic board under the battery pack.
good luck
Apr 27, 2010 | Sony PlayStation Portable (PSP) Slim...
PSP charged all night and will not power on
You're not being clear.
You say "I get nothing"
Do you get a green light? Or no green light?
What if you plug it in? Do you get a green light if it's plugged in with no battery inside?
If you get a green light with the battery in but nothing on the screen, your PSP is bricked.
If the PSP works while plugged in but not with the battery it's either having motherboard problems or the three prongs on the back of the PSP are not making good contact with the battery.
Mar 16, 2010 | Sony PlayStation Portable (PSP) Console
Psp fell ,turn psp on.green light turns on.screen stays off
Hi first i will say sorry for that. I will recommend that you see a certified technician to fix it up, there are a few things i guess are wrong with your psp... the system of psp are fragile and should be handled with care because i think one or more parts are broken and need replacement. Cheers
Dec 23, 2009 | Sony PlayStation Portable (PSP) Console
I have an updating version problem
sorry but your psp is bricked u need to buy a pandora battery and a magic memory stick to fix your psp.
Jun 28, 2009 | Sony PlayStation Portable (PSP) Slim...
My psp green light gets on but any thing did not come on screen
well side by what? side by side .. ok so first of all maybe it was the internet connection......or power failure..its bricked....call sony 100$ bucksl;.....or your like me
http://forums.afterdawn.com/thread_view.cfm/688507 go here and look at the fifth comment down!! do all that he says get all the files you need 1.5 ofw and 4.01 ofw
http://www.consolediscussions.com/forum/f17/all-cfw-and-ofw-download-links-t7104/
and then when you run psp pandora deluxe you simply select the drive your psp is like [h] or [d] and chose the one and then chose the Ofw files you download and then chose desperato cemeterio v6 [4.01 m332] then hit format and prepare card Set the DC v6 to the left trigger and elf to Square.. and then chose more options and chose install support tools for pandora, install support tools for XMB copy 4.01 1.50 addon. then u start the psp holding square [elf menu] and then chose to run pandora installer and then chose battery options and then pandorize battery then exit out and turn off psp and the turn on while holding left trigger and then chose 4.01 ofw or 4.01 m33[ which lets ou play psp games for free snes playstation one and much more
Jun 27, 2009 | Sony PlayStation Portable (PSP) Slim...
Psp power problem
have you tried charging it
Dec 24, 2007 | Sony ACY-BR81/OB
Video Game Consoles & Games Logo
53 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
