Sony Handycam DCR-DVD92 DVD Camcorder Logo
Anonymous Posted on Aug 14, 2010
I keep getting eror message cr-13. I took battery out and restarted problem still exists.
  • Anonymous Aug 15, 2010
    Gbooze,
    I followed the step and problem still exists. Ant other thoughts?? Just so you know I also removed the battery as well and re-installed as per the owners manual.
Anonymous
Level 3:
  • Master 713 Answers
  • Posted on Aug 14, 2010
Anonymous
Master
Level 3:
Answers
713
Questions
0
Helped
186339
Points
2287
The problem you are facing with your camcorder is actually a disc error;
Simply remove the disc and reinsert it back after 5mins.
Problem solved.
Take care..
E000580-0000 solution of this eror when machine show this on display then what i can do to start the machine properly
Appears to be a problem with the finishing tray attached to your copier - disconnect the tray from the copier (pull it away and unplug it), restart and see if you still get the message. You will need to have a tech fix the problem with your finisher tray, but you might be able to make use of the machine without it until then.
My 1990 Honda Civic battery keeps draining the alternator is running well between 13 and 14 when the battery got low it started to lose power while I was driving I replace battery in it was already down to...
Not sure I follow your story.
Have you checked the output of the alternator while it is on the engine, and is it between 13 and 14 volts ? Does the battery lose power while the engine is running or after you turn the engine off ?
Is the alternator output normal but not reaching the battery ?
[Job 13] printer-state-message="Destination printer does not exist!"
Most likely the USB port has to be configured , it will auto default to port #1 it will not see the printer..
I keep getting a message that the battery needs to be replaced. Where is it?
It is on the motherboard. Take the power cord off the unit and panel to access it. On the board is a small round battery which is about half an inch in diameter and silver (chrome plated) somewhere on the board. Usually a CR 2032. It is what powers the memory of the CPU. Cost is around $2.50
Hi, I have a 2004 Vulcan Nomad 1500 L5 FI. I'm having issues starting the bike after I've been out riding for a while. It always took 2 or 3 revolutions (?) to start, but last season it sometimes took 4...
Hi
I would check the connection between the battery and the starter motor although its quite feasable that your starter is worn and is loading up, which makes it slow to turn and require more power from the battery.
Maybe you can remove the starter motor for testing?
My phone keeps automatically restarting, it wont get past the greeting message, without turning off and restarting. I took out the battery many times, yet it still does it. How do i get it to stop?
well they could have gave you a messed up phone. the best thing to do is to take it back to them and tell them what is going on, most likely they would give you a new phone
2answers
I keep getting a battery depleted message
I don't know but that would be wierd if this was Paula Meadows from McAlester
2002 Honda CR-V Battery Light needs to be reset
Get a code tool from the parts store. You can reset system with that.
1helpful
3answers
Cyber-shot DSC-W35 format error c:13:01
Software for Memory error correction is available on charge basis to get data/ pictures.
Top Sony Video Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
