Question about Krups Caffe Bistro 867 Espresso & Coffee Maker
Mineral/calcium buildup When I make a pot of coffee it takes over an hour for the water to drip into the pot. From the start of the coffee making it sounds like the end of the cycle but there is only minimal dripping into the pot. I have tried running pots of vinegar and water through but it doesn't seem to solve the problem. Is there any way to take apart so we can see if the water chamber (long tube) is clogged? Thanks Marianne Miehle
  • 833 Answers
I'm curious about the performance of the heater on this pot. Your output temp should be about 180 degrees F. Allow some of the water to run through the system and into a large mug. Measure the temp. If it is low, your problem may be the thermostat.
Posted on Jun 16, 2008
I have an older model cuisinart 12 cup coffee maker. This am the water will only slow drip through the filter. There is lots of gurgling but not much coffee. Can u help me figure out what's wrong?
Calcium buildup. Follow your coffee maker's manual cleaning procedures to dissolve the hardness buildup.
If you can't find your manual, try mixing 1-2 cup of white vinegar in an 8-oz to 12-oz pot of water and pour it into the water receptor. Run the coffee maker until about 1/2 the water has passed through the machine then turn it off and let it stand for awhile (say an hour). Then turn it back on and let it finish. This should dissolve the hardness buildup in the machine and restore the flow. If not repeat. If you use a paper filter during the process, you should capture all sorts of hardness particles.
After it's flowing good again, run with one or two pots of water to rinse.
Oct 23, 2016 | Cuisinart Coffee Makers & Espresso...
Checking to see if the water line is clogged or broken on my cuisinart dcc1200 coffee maker. The water doesn't come out of the showerhead. Help!!
Most likely clogged with a calcium buildup. Run a solution of water and vinegar through the machine to dissolve the hardness buildup. Stop about 1/2 the way through and let it set for an hour. Turn back on and let it finish. Remember to run a pot of clean water through after to wash out the vinegar. (You may have to run more than one clean cycle if it's really clogged).
Aug 31, 2016 | Cuisinart Coffee Makers & Espresso...
My Mr. Coffee is taking over an hour to brew a pot of coffee
Run a half a pot of vinegar through it then 2 or 3 pots of water. It's from lime and calcium deposits.
Nov 05, 2015 | Mr. Coffee 12-Cup Programmable Coffeemaker
Cuisinart dgb-650
In an empty machine,(no coffee, no filter), pour in a 50-50 mixture of water and white vinegar. Allow the machine to start brewing and when a cup or so has run through, stop the brewing process and let it sit for an hour or two. This should dissolve some of calcium buildup in the machine and allow it to complete a full cycle. May have to do this a couple of times to fully clean out the mineral buildup. After cleaning, run a pot of clear water through to rinse out the remaining vinegar.
Dec 03, 2017 | Cuisinart Coffee Makers & Espresso...
How do i clean my bunn air pot coffee brewer?
Run a pot of half water and half vinegar through the coffee pot and you may need to repeat this process a couple times to get all the calcium buildup cleaned out of the pot. Hope this helps.
Jun 21, 2010 | Bunn Automatic Coffee Brewer CWTF15 1
Brewing time is too long 20 min for 6cups
You have an obstruction in the feed line to the heating element. I found coffee grounds before the check valve. I had to take the bottom off it which I am sure the manufacture wouldn't approve of but I was at my wits end and ready to toss it. I just brewed a full pot 10 minutes!!!
Aug 18, 2009 | Cuisinart DCC-1200 Coffee Maker
Takes forever to make a pot of coffee
Decalcify the water holder. Run some CLR and water thru the brew cycle.
Mar 05, 2009 | Krups Caffe Bistro 867 Espresso & Coffee...
Won't make full pot
Okay, try this, make sure that everything is cool first, then take a turkey baster full of hot water and vinegar and shoot it backwards through the coffee maker...where the water falls on to the grinds. After that, try running either a commercial coffee pot cleaner or just again, vinegar through the brew cycle with no coffee in there. Try it two or three times, there may be calcium buildup in the filter and pump. You could also try that CLR cleaner, but make sure you rinse the pot out really good, and run a few cycles of just water before you drink anything from it.
Hope this makes sense and helps you out!
Jan 12, 2009 | GE Coffee Makers & Espresso Machines
Cuisinart grind and brew
This happens when the machine needs cleaned. Fill coffee maker with white vineger instead of water. Turn grind off, make sure empty pot is in place. Brew a pot of hot vineger. Repeat. Brew a pot of hot water. Repeat. This process removes mineral buildups inside machine. If you have access to filtered water, start using that to brew your coffee. I do and probably do this process 1 per 6 weeks.
Oct 07, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
TAKE 45 MIN TO MAKE A POT OF COFFEE
you said you clean it you use vinegar or decalcifier vinegar remove calcium in piece it might block the orifise if you use decalcifier it melt the calcium 1part solution to 1 part water dont forget to rinse very good that stuff is nasty cheers
Jan 23, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Open Questions:
See all Krups Caffe Bistro 867 Espresso & Coffee Maker Questions
Krups Caffe Bistro 867 Espresso & Coffee Maker Logo
145 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Billy Mac
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
