Question about Kenwood KDC-W3534A CD Player
Security Code for Protect mode
Kenwood KDC-MP438U. I work for a trucking company and have recently installed this model stereo. I had to do some work behind the dash, so I disconnected the stereo, and now that I have re-installed it has went into "Protect" mode. How do I remove the Protect mode. THX
  • 6 more comments
  • northphilly1 Jul 30, 2008
    protec when i changed battery
    t mode
  • NashuaCD Aug 23, 2008
    Same Problem. Battery went bad and now my Kenwood KDC-MP438U is locked and I need the factory lock code. Help!!!!
    My battery went bad and now my Kenwood KDC=MP438U stereo is locked. I need the factory lock code to use my 5 week old stereo. Help!
    NashuaCD@aol.com
  • rainbowspark Aug 28, 2008
    cd player has come up with the code protect and we've only just bought the car what do i need to unlock it please.
  • marshmell105 Sep 14, 2008
    i just got a new kenwood kdc-mp435u radio and installed it in my car and the portect went on how do i get that off ??
  • pkkettner Sep 14, 2008
    in protect mode
  • ALJORDAN19 Dec 02, 2008
    I OWN A AUTO SALVAGE YARD,,,AND WOULD LIKE TO INSTALL THIS KENWOOD ,,,BUT THE PROTECT CODE KEEPS BLOCKING ME,,CAN I GET AROUND THIS
  • Anonymous Mar 18, 2014
    Kdc-400u kenwood stereo in protect mode
Turn on the car so the radio is flashing "Protect." Look on the front / removable face of the stereo. On it you will find a small round hole - that's a reset button. Find a small paper clip, unfold the clip and stick it gently into the hole. The "Protect" will stop flashing, and Kenwood will be displayed. Unfortunately all your settings/presets will be gone, but at least the stereo is working again!
Posted on Nov 04, 2011
  • 2 more comments
  • Franco Salesia
    Franco Salesia Jul 31, 2012
    thx Rob Perry, it realy woks, keep up the great job !!
  • LLORI MARIE DAHLEWIS Nov 28, 2012
    THANK YOU- QUICK AND PAINLESS glad I saw your solution first. Thanks
  • ahmed Aug 24, 2013
    i have tryed many times but still protect sign
  • MOHD ZABALAWE
    MOHD ZABALAWE Nov 11, 2013
    i have the same problim and i dont have reset hole the button inside the hole is for removing the CD.
How do i unlock the protect mode on the kenwood kdc-mp239
Posted on Sep 24, 2008
  • Parvezalam May 15, 2012
    How to do protect mode
Solution protect mode kenwood dvd receiver
Posted on May 24, 2008
Press the reset button, bottom left hand corner :)
Posted on Mar 05, 2011
Unplug and replug the fuse in the back of stereo
Posted on Sep 14, 2008
    New Friend:
Will all this work on the kenwood model kdc-bt555u
Posted on Dec 15, 2013
  • Paris Hayden
    Paris Hayden Dec 15, 2013
    as i pressed the reset button sounds like the cd player is running
2 Suggested Answers
SOURCE: Protect mode Kenwood KDC MP438U in dash reciever
Anytime there is a short circuit or your battery down low enough you will recieve this signal. If you press the little "reset button" using a small pin or screwdriver your unit should reboot without the "PROTECT" signal. If seeing this "PROTECT" sign is a result of jumping your car, this will fix it. If the signal persists, then there is still a short circuit and you need to check your connection with the battery. Most likely it is touching the chasis or some othere metal.
Posted on Mar 29, 2009
I have a kenwood KDC-MP438U stereo. Ipod error.
Hi If anything the stereo was probably designed and tested using a certain version of the Iphones software, now that version 4 has been released the way the IPhone communicates may have changed.
As a result the stereo is no longer able to talk to the phone and vice versa. your probably best off contacting Kenwood direct to see if they are aware of this problem and if there is anything that can be done about it.
Jun 24, 2010 | Kenwood KDC-MP438U Car CD/ MP3 Player
On my kenwood kdc mp438u i tried everything it said to do but it keep saying protect
Could be a short circuit on your speaker output, try disconnecting all 4 speaker wires and then power up. Otherwise its the audio amplifier circuit that needs to be replaced ( audio IC )
Sep 27, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Call constantly cuts in
you must of traped a wire when you have fitted the head unit to the car when you have pushed it into the dash or the call wire is going to earth on something behind the radio in the dash hope you fine it hope ive help you let me now how you get on
May 29, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Kenwood KDC-MP438U reciever installed. No sound in any mode.
if its a newer truck it will most likely have a factory amp u either have to utilize or bypass
Apr 21, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
I need the Kenwood KDC-MP438U user manual
The Kenwood crack code is KCAR. Give that a try.
Apr 18, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
I need a kenwood wiring diagram
I have found your owners manual your can click here or copy and paste the link into your browser.
http://inform3.kenwoodusa.com/manuals%5Ckdcx492.pdf
Hope this helps.
Richard
Mar 10, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
I just bought a Kenwood KDC-MP438U I installed all the wires right, power is to the deck because it accepts a cd. the deck face doesn't light up. I called in at Kenwood and they had me test it directly to...
Check your Ground Wire inside the Truck and Check the Illumination Wire. I Think on Kenwood the Illumination Wire goes with the Power Wire. If they still will not work, You might want to get a Wiring Harness from Schoche.com Please Rate My Response! Thanks!
Jan 30, 2009 | Kenwood KDC-MP438U Car CD/ MP3 Player
Jun 27, 2008 | Car Audio & Video
Kenwood KDC-W3534A CD Player Logo
7,359 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
