-   I had the same problem. I dropped my Powershot SD600 and the lens will only retract halfway. When I try to turn on the camera, it says "lens error, restart camera." I've tried taking out the batteries, but have had no luck. Any ideas?-   ameyers
I just fixed one power shot SD630 with the same problem.
Only if you have enough experience you can handle with this problem.
First you have to take out the entire zoom lens out and after that , you must repositioned the last lens who is for clarity.
Usually this lens are not in the normal position after the camera suffers a shock.
Hey kara M,
Before you take it in for service I would try taking the batteries out for a while and then putting them back in. Often this resets the camera and resolves the issue.
Sincerely,
Allan
Go Ahead. Use Us.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot SD630 Digital
Change the battery pack when new battery pack is inserted. We thought it might be our charger or the...
(More)
Change the battery pack when new battery pack is inserted. We thought it might be our charger or the battery pack is just old. So we bought 6 new batteries and charged them on our firends cannon power shot charger put them in her camera and had no problem. We then put them in our cannon and received the change battery pack display with in minutes on some and instantly on others. Is there a issues with the connectors? The latch mechanism that holds the battery in and the ejector spring are also functioning correctly.
