Question about Sony Handycam DCR-HC40E Mini DV Digital Camcorder
Sony DCR-HC40E Tape Holder Mechanism load failure
I have a Sony DCR-HC40E for a few years now, recently I tried to load a tape into the camcorder but the mechanism seems to open but will not load into the camcorder.
So, now even without the tape in the holder is out in the eject mode.
I've considered all options, making sure its fully charged, taking the battery out and putting it back in but with no luck.
Does anyone know if this is something I could fix or is this a mechanism issue?
Regards,
Naeem
  • hiama May 30, 2008
    please I have this camera I need video soft ware please give as i dont have any cd
  • Anonymous May 02, 2009
    the tape loading mechanism is in the "eject" position and will not retract. I have had this problem in the past and it eventually started working again, but this time it does not seem to want to fix itself.
  • 10,594 Answers
Your camera needs Mechanism replacement.
Software CD is available on charge basis.
Posted on Jul 27, 2008
When I put my tape in the camcorder and close the metal door, the tape does not go down. but when empty, the tape holder do go down.
Hi, My Sony DCR-HC32 handycam's tape mechanism is giving me some problem. It ejects and the tape deck opens up properly but after putting a tape and closing it, the tape deck does not go in. I tried with or without tape but it doesn't go in. It is still open.
Can you please suggest how it could be fixed?
Thanks,
Pramod
Nov 26, 2010 | Sony Handycam DCR-HC32 Mini DV Digital...
DCR-HC40E camcorder error C:31:30 message. can you help?
reset the camcorder. (open the tape deck and you'll see a small hole that says reset on it) press and hold the button inside the hole for 3 secs. then also clean the tape head(the metal thing that reads the tape. with a q tip.
Sep 06, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony model camcorder DCR-HC40E
well if you were to burn them via windows vista, I'm sure you could do that directly from your computer, if not I'd just talk to a real person (custumer service line, a shop etc.)
Apr 18, 2010 | Sony Handycam DCR-HC40 Mini DV Digital...
Sony CCD TR31 - tape holder will not lower into camcorder
Does the tape have blocking tabs that prevent recording? May be telling you that you can't use that particular tape.
If not take it in for professional repair. I think Sony is in Mississauga.
Andrew in Mississauga :>)
May 16, 2017 | Panasonic PV-GS2 Mini DV Digital Camcorder
When i try to use my camcorder there's a flashing light with the eject symbol and it wont record or let me use the video
Flashing eject sign error appears when camcorder got problem in its mechanism, please put another tape and check.
Remove battery from camcorder for couple of minutes, put battery back and try.
Also observe does tape reels turns reverse and forward when tape loaded in mechanism.
If problem still exist, qualified camera tech will fix it because it is not user level repair.
Oct 13, 2009 | Sony Handycam DCR-TRV330 Digital Camcorder
DCR-HC42 will not load Mini DV
Have you all tried using a new battery? It happened to me before where I would try and load the tape and the motor just hung and wouldn't allow the tape to fully go in. I tried to recharge the battery to see if that was the problem and even left it plugged in but camcorder appeared to still be weak. I think went to Wolf's camera and asked if I may if a bigger batter would feel weird with my current camcorder (I just said that so I could see if I could borrow a new battery and see if it would fix the problem). When I installed the new battery, it loaded the tape with no problems.
Try it and tell me if it solves the problem.
Nov 22, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Cassette tape will not load
I am sorry, No simple solution available for this problem. Your camera required new DV Mechanism.
Apr 07, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
DCR TRV320
That is the "LOAD" error code.
However, to service the C:31 code, Sony recommends you do the following:
  1. Turn off the camcorder.
  2. Remove the battery or disconnect the AC power adapter for 60 seconds.
  3. Insert the battery or reconnect the AC adapter.
  4. Turn on the camcorder.
  5. If the error message appears, service may be required.
If your camcorder still shows the same error code, then you'll have to send in your camcorder for service.
Oct 25, 2007 | Sony Handycam DCR-TRV320 Digital Camcorder
Sony dcr-trv6 unable to load tape in deck
This is a common problem. The code indicates that the sensor for the supply reel has indicated lack of motion. If you have a cleaning tape, try it first because if the head drum hesitates, reel error codes often appear. If this doesn't help you are in for a service situation. There are other electronic failures that can cause false codes and operations in many cases. These usually involve cable connection failure. You still need a qualified servicer. Good luck, magic seadog
Aug 10, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Tape holder of camcorder isnt closing
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Jul 19, 2007 | Sony Handycam DCR-HC42E Mini DV Digital...
Sony Handycam DCR-HC40E Mini DV Digital Camcorder Logo
294 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
