Error code C:\Windows\system32\spool\DRIVERS\W32X86\3\LXCFtime.dll
  • 472 Answers
This is part of the Lexmark printer drivers.
Try to uninstall the drivers then reinstall them.
If you don't use the LExmark printer anymore, then just uninstall.
That should correct the problem.
Posted on Apr 30, 2008
Error in c:\windows\system32\spool\drivers\w32x86\3\lxcitime.dll missing entry:rundllentry
It is related to a Lexmark Printer. Try reinstalling the driver for the printer and see if it works.
Hope this helps!
Sep 08, 2010 | Computers & Internet
When I start my computer I get a error: Error in
Based on the folders (spool/drivers) that sounds like the error is coming from a printer driver. Try uninstalling the last printer you installed and see if that resolves the issue.
If not, you can go into the Start Menu, under Accessories and System Tools and find the find the System Restore. When you installed the printer it should have created a Restore Point. Do a restore to that Restore Point, and it will take your systems registry and drivers back to the way they were before you did the driver update.
Once you have gotten rid of the error, by uninstalling ro restoring, then you may want to check the web site of the printer's manufacturer to see if there may be a new or corrected driver for the printer, and install that one rather than the one you used before.
Regards.
Jul 08, 2010 | Computers & Internet
RunDLLEntry@16
LXCGtime.dll is a module installed with the spooling drivers for Lexmark printers. This is required for your printer to work properly and should not be disabled. You may need to re-install the Lexmark printer driver hope this helps
Mar 25, 2010 | HP Pavilion dv6000z Notebook
Error Code: 2753 " Fatal Error or error MSI.dot4msi"
CAUSE:
Certain HP services (and associated DLL files) were somehow partially/improperly installed. (Possibly, from a previous failed install?)
The Windows services (files) were:
Pml Driver HPZ12 (C:\Windows\System32\HPZipm12.dll)
Net Driver HPZ12 (C:\Windows\System32\HPZinw12.dll)
The existence of these 2 files in the System32 directory was causing this error in my situation. Somehow, the installation script was not identifying that these files were already installed (or improperly installed) and failing to properly set them to be installed again.
SOLUTION:
Steps:
1) Check to make sure that the 2 Windows services above are not running (or not installed).
2) Rename/delete the 2 associated service DLL files (this will only be possible once the services are stopped)
3) Run the installation again.
solution 2>
complete uninstall printer software from computer.
run uninstall L1 L2 L3 L4(if not an hp computer).
run same uninstall l1l2l3l4 from 7z..folder or hp folder from temp if availalbe.
then clean from add remove programs/program and features.
then clean from cleanup utility all hp pritner related entries.
then clean temp folder. clean recycle bin.
delete c:\program files\hp and hewlett packard folders (if not an hp computer). on hp computer delete digital imaging bin folders.
delete following folders from following locations-
C:\windows\System32\Spool\Printers and deleted entries inside it
C:\windows\System32\Spool\drivers\w32x86\*.* deleted entries inside it
C:\windows\twain_32.
cleanup from regsitry--
plz make back up for registry first.
>> hklm/system/current control set/control/print/environment/windowsNT(x86/64)/drivers + processors delete all pritner entries from there.
>> hklm/system/current control set/enum/usb/vid_000,vid_003 delete.
>> hklm/system/current control set/enum/usbprint delete pritner entries.
>> hklm/system/current control set/control/print/monitors/hp standard tcp/ip ports/ports.
>> hklm/system/current control set/control/print/monitors/standard tcp/ip ports/ports.
>> delete same ports from printers and faxes/pritners pritner properties ports
>> hklm/system/current control set/control/print/monitors/hpz..
>> hklm/system/current control set/control/print/providers/lan man settings.
>> hklm/SYSTEM/CURRENTCONTROLSET/CONTROL/PRINt/PRINTERS
>> hkey_Current_User\Software\Hewlett-Packard
>> hKey_Local_Machine\Software\Hewlett-Packard
>> HKEY_USERS\.DEFAULT\Software\Hewlett-Packard
>> hkey_current_user\software\hewlett packard delete if not hp computer.
>> hkey_curent_configuration/system/current control set/control/print/pritners.
then go to msconfig
make it selective startup disable all microsoft services except hp services. hide all microsoft services. disable all startup tab apply restart.
after restart install cue version 12 officejet pro 8500 or 6500.
then run msiexec.exe /unregister then msiexec.exe /regserver cmd commands.
then install software from downloaded version of original pritner install only basic drivers first and imaging devices only and use solution center 12. cue 12.
issue resolved.
Jun 19, 2009 | HP LaserJet 3055 All-In-One Printer
Can not print at all. Tried command prompt, test page, status of printer is online also checked printer port and restarting both printer and computer,etc; I'm still unable to print. printer does not...
Not that it is a help for your problem but the file name should be PSW_RE.DLL - a dot belongs before the '.DLL'
If you haven't tried it yet, delete the printer from the 'Printers and Faxes' folder in the Control Panel, make sure the printer is connected and turned on, then reboot the computer.
This will force Windows to reinstall drivers for it and should return functions.
Aug 20, 2008 | Lexmark X1240 All-In-One InkJet Printer
The port the modem is attached to could not be opened; Opening the modem device failed with error 000005aa
Sounds like a hardware problem
First > try changing the modem port (default is com3, try changing it to com4 or com5 whichever is free)
Try querying the modem again
Second > Contact your modem manufacturer
May 26, 2008 | Conexant chipset 56K V.92 PCI Data/Fax...
TWAIN error
Here is an actual e-mail from a Canon tech regarding this problem:
Thank you for your recent enquiry regarding your Canon product
Please accept my apologies for the delay in contacting you regarding the
problems you have been experiencing with your CanoScan D646U.
I shall firstly answer your query regarding the TWAIN drivers. There are four
main TWAIN files that are pre-installed with Windows, TWAIN.DLL, TWAIN_32.DLL,
TWUNK_16.EXE and TWUNK_32.EXE. These are included with the scanner drivers to
ensure that a compatible version of the files are installed, otherwise the
scanner will not work. During installation these files are checked for and, if
a later version is already installed, the versions from the disk will not be
installed. I can assure you that the scanner driver will work OK with version
1.7 of the TWAIN drivers.
For the scanner to communicate correctly the Still Image Services needs to be
running in the background. To check this please open the Control Panel and look
under Services in Admin Tools. Please check to ensure that the Still Image
Service is running correctly.
If all this is OK, I would recommend removing the driver in the following way.
With the scanner still connected go to Device Manager. Under Imaging Devices
right click on the CanoScan D660U and select uninstall. After this please
disconnect your scanners USB lead and remove the rest of the driver using the
DELDRV utility. Before reinstalling the driver you must restart your PC and
then reconnect the scanner.
If there are still problems please check that the driver has installed
correctly. The following files should be shown in the driver section when you
look at the scanner properties in Device Manager.
C:\WINNT\SYSTEM32\D064UCPL.DLL
C:\WINNT\SYSTEM32\D064UFW.DLL
C:\WINNT\SYSTEM32\D064UFW.INI
C:\WINNT\SYSTEM32\D064UFW.PLG
C:\WINNT\SYSTEM32\D064UUD.DLL
C:\WINNT\SYSTEM32\DRIVERS\USBSCAN.SYS
C:\WINNT\SYSTEM32\SPOOL\DRIVERS\COLOR\CNS60N.ICC
C:\WINNT\SYSTEM32\SPOOL\DRIVERS\COLOR\CNZ005.ICC
C:\WINNT\SYSTEM32\UCS32P.DLL
C:\WINNT\TWAIN_32\D64U\CANOIT32.EXE
C:\WINNT\TWAIN_32\D64U\CISDS.DS
C:\WINNT\TWAIN_32\D64U\CSUI.CNT
C:\WINNT\TWAIN_32\D64U\CSUI.DLL
C:\WINNT\TWAIN_32\D64U\CSUI.HLP
C:\WINNT\TWAIN_32\D64U\D064UA.DLL
C:\WINNT\TWAIN_32\D64U\D064UUI.DLL
C:\WINNT\TWAIN_32\D64U\IMGENH.DLL
C:\WINNT\TWAIN_32\D64U\IOP.DLL
C:\WINNT\TWAIN_32\D64U\ITLIB32.DLL
C:\WINNT\TWAIN_32\D64U\LTKRNION.DLL
C:\WINNT\TWAIN_32\D64U\README.TXT
C:\WINNT\TWAIN_32\D64U\SCANINTF.DLL
C:\WINNT\TWAIN_32\D64U\SYSERROR.EXE
C:\WINNT\TWAIN_32\D64U\TPM.DLL
All of the files mentioned above that are listed as being in the TWAIN_32\D64U
folder are the exact files that should appear in that folder if you look in
Windows Explorer.
A further cause of the TWAIN error occurring is if there is a conflict with
another TWAIN compliant device, such as a Digital Camera or scanning device
(including Multifunctional devices. If you have such a device installed try
removing its software before reinstalling the scanner driver.
We hope this information is of use to you. However, should you require any
further technical assistance, please do not hesitate to contact us quoting your
Incident number.
To contact us via email, click on the following link:
https://self-service.canon-europe.co...ss.cgi?LANG=en.
Note: Please do not reply to this email using your 'REPLY' tab.
Kind Regards,
Gavin O’Mahony
Product Support Specialist
RCC UK
Oct 27, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
89 people viewed this question
David Payne
David Payne
