Question about Refrigerators
Ive got a refrigerator ,about 9 cf . therm is good but compressor wont go .i hear the click of therm protector . could the starter be out ? or would it be the compressor ??
  • 828 Answers
Generally it is the compressor. The thermo disk overload protector is cutting off the circuit due to excess current draw.
Posted on Apr 30, 2008
Part 2 when it tries to start i hear a click coming from the overload-start capacitor side of compressor. fan is working.
check the capacitor overload protector and starting relay if they are all good, if one of them is found not functioning replace it. with new accessory installed , plug in the unit. if still you hear a click and compressor don't start , replace it . before you start anything on the unit be sure you know what you're doing. if in doubt call the experts.thanks,
Mar 02, 2016 | Magic Chef Refrigerator. 10.0 cu. ft....
The starter on the compressor burned up and also where you plug it into the compressor .do i have to replace the whole compressor? it a Frigidaire side by side model number FRS6LR5E83. i bought a new...
New compressor, very expensive repair, unless it is under the 5 year system warrantee. If it is out of warrantee then junk it. Buy a Whirlpool or Kitchen Aid refrigerator, and buy a wall mount 2000 joule or higher surge protector to help prevent this from happening again. Lowes has the "Prime" brand surge protectors for 12.00 to 20.00. Good Luck, Appliance Specialists
Dec 09, 2010 | Frigidaire 26.0 Cu. Ft. Side-by-Side...
Blowing air but not cold, I hear a click noise every few minutes.
the clicking you hear is probably the overload protector for the compressor.if it is you need either a new start relay or a new compressor,you need a technician to determine which it is
Jan 25, 2010 | GE Hotpoint Top-Freezer Refrigerator
Refrigerator not cooling, do not hear compressor
clicking sound is motor protector cuting out compressor drawing to much current replace compressor.
Oct 21, 2009 | Refrigerators
Not cooling
If it's clicking on and off like you say, replace the compressor start relay device and overload protector. These are located directly on the side of the compressor, usually contained within a dark plastic cover.
Aug 10, 2009 | Amana ABB1927DE Bottom Freezer...
Compressor not running
If your hearing a soft buzz and then a click every so often you may have a start relay out on the compressor. If you are not hearing anything from the compressor are then there is an overload protector with the relay that may have went out.
May 16, 2008 | Whirlpool ED5THAXMS Side by Side...
Compressor on whirlpool side by side
STOP! DO NOT RUN UNTIL YOU GET PROPER PART!
I hope you have not ruined the compressor by now. Your original problem was that your compressor start relay assembly was bad. The click noise you were hearing was the overload protector preventing damage to the compressor. When you bypassed this relay and overload protector you may have burned the windings of your compressor. You would need a compressor tester or you will need to put a good relay overload assembly on to see if the compressor is usable now. If the compressor is destroyed the repair bill could run from about $350.00 to $700.00 depending on model and technicians labor charge.
I hope I have helped, supertechks
Mar 06, 2008 | Jenn-Air JCD2389G Side by Side...
Overload Protector
i guess you can ohm it out witha meter( exact specs idont know) can you hear it clicking on/off??, generally i remove it from compressor and if its faulty it shake and sound busted. might be bad compreesot that coaused that (which should be covered under 5 yr manu. warr) adnthat comes with new overload protector
Mar 01, 2008 | Kenmore 52642 / 52644 / 52649 Side by Side...
Refrigerator
You didn't mention it, but I'll bet there's a "humm" followed by a "click" noise coming from the back of the fridge. Even if you don't hear the noise, the starter on the compressor has failed. One of two things cause this... 1.) A mechanically failed starter. 2.) A seized compressor. If it's the starter only, you are in good shape. If it's #2 and the unit is less than 5 years old, it'll be a warranty claim. If the unit is less than 5 years old... do not attempt the repair yourself. Because, if you do and find the compressor locked up, you have voided your warranty and they will not repair for free. If it's over 5? Install a starter. We need the FULL model number off of your fridge to provide steps on this. It's located on a data tag affixed to the inner fresh food section lining. Most likely near the top on the right. Please post back with these numbers if you require further assistance.
Aug 11, 2007 | Kenmore 44109 / 44102 Side by Side...
Refrigerators Logo
121 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
