Question about Garmin zumo 550 GPS Receiver
Garmin zumo 550 switching on and off
8 month old unit started up and then powered off. It continued for hours.
On reading some tips here I removed the battery for some minutes. On re inserting the battery, the unit worked correctly.
  • Anonymous May 12, 2008
    I had the same problem - no power. After removing the battery and re-inserting it solved the problem. Thank you!
Keep your finger in the right bottom corner when you start up the unit. it will show a warning if you want to reset! push on "YES". it will reboot the unit. (please note that you have to remove your little memory card).
Hope it works... it did mine! SU
Posted on Jun 10, 2008
HI I have Zumo 550 when I first switch it it comes up with can't maps press OK you press OK then starts to work but starts at 1am on the clock and in night time mode after awhile it goes to the right time...
If your zumo 400 or 500 series will not power on, or performs strangely after powering up, follow the steps (described on the Garmin website) below to perform a soft reset:
  1. Connect the zumo to a power source such as a computer or AC outlet
  2. Hold the zoom (+) and ON buttons at the same time for five seconds
  3. If this does not restore power, remove the battery for five seconds
  4. Place the battery back in the zumo
The zumo will now power on. Because the battery may deplete while the zumo is locked up, it is ideal to leave the zumo connected to power to allow it time to charge.
Once the battery has charged, follow the steps on the Garmin site to update the operating software in the zumo. (just copy this link to get there https://buy.garmin.com/support/searchSupport/case.faces?caseId={8576ba20-e948-11dc-d6fc-000000000000} )
Good luck,
Michael
Feb 01, 2011 | Garmin zumo 550 GPS Receiver
Zumo 550 randomly shuts down, sometimes won't power up again.
Commonly happened when playing MP3's using an early version of the firmware. Install the Garmin updater and install the latest firmware and patches.
My original unit did the same thing.
Jul 13, 2009 | Garmin zumo 550 GPS Receiver
Garmin Zumo 550 Freezes
If the unit freezes with something on the screen, then the book that came with the unit tells you to push the power button and the + sign button at the same time and this should fix the problem. Good Luck.
Jun 30, 2009 | Garmin zumo 550 GPS Receiver
GPS is not getting power on the motorcyclen mount.
If you're sure the power cord is getting power, then the mount has likely failed. Mine has failed 3 times. Replacing the mount will fix the problem as it did on mine. If the unit is less than 1 year from purchase, Garmin will warranty replace it for free. If not, it'll cost you about $85 plus shipping to put a new one on.
May 09, 2009 | Garmin zumo 550 GPS Receiver
Garmin zumo switch on problem
Use the allen wrench to remove the battery. Let stand for 5 minutes and replace the battery. It should start fine. Mine has done this 3 times since I purchased it.
Jan 05, 2009 | Garmin zumo 550 GPS Receiver
Zumo 550
Make sure that the bike's electrical connection to the GPS unit is actualy not having power once you turn the key off in the bike. This GPS turns on with external power. It is inherent in to its design.
In the case were you cannot have the bike's power source to the GPS turn off with the key, see if you can wire a small in-line switch in series with the GPS unit so that you have an external power switch. This should be easy to do.
The models I have used from Garmin have their own power switch. You should be able to use its power switch to turn it off.
Jerry G.
Jul 19, 2008 | Garmin zumo 550 GPS Receiver
GARMIN ZUMO GPS 550- how to i connect power source to my Harley mc and speakers?
Red lead to the plus and black to the minus of the battery, connecting to the speakers youl'll nead something with an aux input, or a small amplifier, the output signal of the Zumo is just enough to power a head set!
May 26, 2008 | Garmin zumo 550 GPS Receiver
No power
I had exactly the same problem with a 3 month old Zumo 550. Removed battery, waited a few minutes and replaced. System now poers on OK. All data on-board was retained.
Dec 22, 2007 | Garmin zumo 550 GPS Receiver
Zumo 550
my battery failed after less than a year of use. Garmin sent me a new battery and the unit is working fine now. The old battery would not provide ANY power to the unit.
Dec 13, 2007 | Garmin zumo 550 GPS Receiver
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Garmin zumo 550 GPS Receiver Logo
195 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
