Question about Dell 2300MP Multimedia Projector
Dell 2300MP Unit starts up successfully to Dell "logo" display. Message below states "out of range". No image is projected.
  • PCforJC Jul 09, 2008
    I have dell 1800 projector. It has worked fine on my xp laptop. I got a new laptop with vista and it worked on that however when i went back to my xp laptop it will not work on vga (Only with svideo). Is it possible that vista messed up something in the projector so it cannot read XP. The refresh rate on both laptops are the same 60 mgh. Sometimes to notice comes up on the projector "Out of range"
    Thanks Pierre
Resync button,i think,but seems too easy...
Posted on May 09, 2008
How do i reverse the upside down screen
You turn the unit upside down.
http://support.dell.com/support/edocs/acc/2300MP/en/usage.htm
Go to the menu.
Go to management.
Go to Projection Mode.
Front Projection-Desktop: If you want it to project right side up off a table.
Front Projection-Ceiling Mount: If you're hanging it off a ceiling.
Jun 24, 2011 | Dell 2300MP Multimedia Projector
Dell 2300 MP Verticle lines distorted image
light engine or bulb is gettingbad ok how many hours on bulb fans clean ect thx nick
Feb 11, 2008 | Dell 2300MP Multimedia Projector
Set inspiron 6000 to factory settings, how do i do it?
To Restore Windows XP
  • 1
    Back up all of your data. Typical items to consider when backing up are: email, address book, personal documents, pictures, videos, music, favorites and desktop items. (For more information on how to back up your private data see the link below.)
  • 2
    Remove all external peripheral devices, including USB-connected devices.
  • 3
    Turn on the computer. If the computer is already on, reboot it.
  • 4
    Press and hold the "Ctrl" and "F11" keys simultaneously when the Dell splash screen appears. The "Dell PC Restore by Symantec" window will appear. Click "Restore."
  • 5
    Click "Confirm" at the warning message stating that all data will be lost. A "Progress" window will appear. Once the installation process has finished the message, "The system recovery process was successful" will appear.
  • 6
    Click "Finish."
  • To Restore Windows Vista
  • 1
  • 2
  • 3
  • 4
    Press the "F8" key when the computer starts. If you see the Windows logo then you were not successful in entering the "Advanced Boot Menu." You will have to try again. If you are successful then you will see the "Advanced Boot Menu."
  • 5
    Select the "Repair Your Computer" option and press the "Enter" key.
  • 6
    Select the language you would prefer and click the "Next" button.
  • 7
    Log in and press "OK." You do have to have administrative access to perform this action. Only administrators are able to restore the computer to factory settings.
  • 8
    Click "Dell Factory Image Restore." The "Dell Factory Image Restore" window will appear. Click "Next."
  • 9
    Click the check box that states, "Yes, reformat hard drive and restore system to factory condition." Click the "Next" button.
  • 10
    Click "Finish," when the restore has finished.
  • Good Luck please rate 4 thumbs up and please leave a testimonial
    Oct 18, 2010 | Dell Inspiron 6000 Notebook
    I have 5 Dell 4310 WX projecors and I would like to display my logo when they start-up. Can this be done with the projector only or is a laptop necessary for this to happen?
    I believe the Dell logo is hard-coded for the Startup, but you can change the Wallpaper form the Dell logo, to an image of your choice:
    From the Setup Menu, or Others Menu, you can go into:
    SCREEN SETTINGS—Select and press checkmark to activate screen settings. The screen
    settings menu consists of the following options:
    CAPTURE SCREEN—Select and press checkmark to capture the screen display, the following message appears on the screen.
    NOTE: To capture a full image, ensure the input signal that is connected to the projector is 1280 x 800 resolution.
    SCREEN—Select Dell to use the Dell logo as wallpaper. Select Captured to set the captured image as wallpaper.
    RESET—Select and press to delete the captured picture and set back to the default setting.
    More information available on the Manual here: http://support.dell.com/support/edocs/acc/4310WX/en/ug/pdf/4310WX_en.pdf
    Jan 14, 2010 | Compaq Presario M2000 Notebook
    Can't get computer images to project
    Hi, I have found out that you must have the laptop set to an external monitor, in the control panel, display area, click on 2, then you must have the projector turned on before you start the laptop so it can recognize that the projector is there. Also make certain that you allow the unit to cool off by turning the lamp off, leaving the fan on and open the door where the projection lens is located.
    Jun 29, 2008 | Lightware VP 800 Plus Multimedia Projector
    Dell 2300MP shows no connection after 15 min of work
    that's a clear indication that you have a major heating issue inside the box..the internals are apparently overheating, as it will work after cooling down, right?
    Mar 07, 2008 | Dell 2300MP Multimedia Projector
    2300MP has a white vertical bar to the right
    not a happy situation. sounds like video drivers are kaput, or the system files are corrupted. Other possible is the actual hardware is compromised.
    Feb 03, 2008 | Dell 2300MP Multimedia Projector
    Dell 2300mp projector
    I have this same projector and am pushing 4500hr on my current bulb. its starting to get a little dim being that the bulb is only rated for 2000hrs. There are brightness setting is the setup of the projector. There are also 4 display modes. game and PC being the brightest. You can change those with the remote. These are the only factors that should effect the brightness. I would say that you might have gotten a bad bulb. try putting the bulb from the "bright" projector into the "new" one and see if that makes a diffrence. also im looking for parts and bulbs for this model projector. If you would like to get rid of anything please let me know. Hope this helps and good luck.
    Dec 22, 2007 | Dell 2300MP Multimedia Projector
    Poor image being displayed
    Hi guys
    You will be looking at either repairing or replacing the Mainboard where all the colour processing is done.
    Sep 27, 2007 | Dell 2300MP Multimedia Projector
    Media player movie picture won't display
    Yes, I have the same problem with a Dell Inspiron 700m laptop. I have never been able to show videos using two seemingly compatible devices. This is not a projector issue however, as my projector displays video DVD fine from this PC, only videos inserted into PowerPoint will not play. Using another computer it works fine. Imagine that, Dell selling two highly practical devices that are not compatible.
    Nov 10, 2006 | Dell 2300MP Multimedia Projector
    Dell 2300MP Multimedia Projector Logo
    459 people viewed this question
    Top Dell Office Equipment & Supplies Experts
    jasbo
    jasbo
    Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
