Question about Brother XL-3510 Mechanical Sewing Machine
Needle guide has come off - Brother XL-3510 Mechanical Sewing Machine
  • macksmommy Sep 22, 2008
    My needle guide came off too. I can't figure out how the pin is supposed to hold it on. ???
I believe I had a similar problem. I called brothers and he solved it for me.I could not get the needle clamp to stay on.There is a little allen screw in the block right above the clamp screw. I loosened that,put it on the needle bar, put the guide back on,then tightened the allen screw.So much for the problem I have had for months. He said if the guide did not want to see in I could put a touch of glue on it. I think it going to be alright without.
Posted on Jan 30, 2009
Tip
Sewing Machine Needle Guide (Schmetz)
Want to know what sewing machine needle to use? Here's a handy guide.
http://www.schmetzneedles.com/learning/pdf/schmetz-needle-chart.pdf
Change your needles frequently. If you are experiencing problems with your stitch, the first thing to do is change out the needle. Needles get damaged and worn over time and are frequently the cause of stitching problems. Needles are the least expensive repair cost on your machine, so don't spare the expense!!!
on May 20, 2015 | Sewing Machines
Frequently, while I am sewing, the needle hits something below the guide plate and gets stuck. I have to remove the guide plate and then the needle will release. What is the problem with my machine?
If the needle gets stuck with no thread, The needle is hitting something. Could be needle not up all the way or something needs adjusting. If it gets stuck with thread. It is probably an upper thread tension or threading issue.
Apr 05, 2014 | Juki DDL-8300
Twisted wire guide for the thread above the needle
Slide it onto the needle clamp from the bottom before you attach the needle clamp to the needle bar.
Mar 14, 2014 | Brother XL-5130 Mechanical Sewing Machine
I broke a needle and tried to replace both needles. Now I can't get my machine to chain. I have rethreaded it, and replaced the needles, closely following the manual and threading guide but still
it's possible that when the needle broke it could have caused the
machine to jump time and would need to be serviced to see if it
needs adjustment.
Mar 08, 2013 | Sewing Machines
Brother Pe770 thread does not stay in the guide, before it would click in and now it faals out
It is exactly that needle guide hook.locate the needle guide and you should see a small hook that resembles a wire, it sometimes gets relocated to the bottom of the needle guide, its needs to be moved to the middle so it will hold the thread. look at your sewing machie for placement of hook if not go to trouble shooting by brother . Do not try to repair yourself because you may damage the hook at your own risk, hope I could help ---MR fixit
Sep 14, 2012 | Brother PE770 Computerized Sewing Machine
I have a similar problem with my 7510.
As a rule of thumb, the flat side of the needle always goes towards the opposite side of the last thread guide. So on your machine, since the last thread guide is in the front of the needle bar, the flat side of your needle goes toward the rear. The needle threads front to back.and needle clamp is tight position is must
Aug 03, 2009 | PfaFF Creative 7570
Changing the needle
Loosen both screws and wiggle the needles out. change the new needle As a rule of thumb, the flat side of the needle always goes towards the opposite side of the last thread guide. So on your machine, since the last thread guide is in the front of the needle bar, the flat side of your needle goes toward the rear. The needle threads front to back.
Jul 29, 2009 | Singer 2250 Tradition
Necchi 4757 - need to know which way the needle goes, and is treaded... from to back or left side to right? I recently bought a used one and it had no needle in it. I also need help with proper threading....
Insert the needle with the flat side to the back. Thread the machine from the spool, left to the guide on top/rear, over the top towards the front, around the tensioner and up, around the take-up lever from right to left, down throught th semi-hidden guide, through the needle clamp guide and thread the needle through the front to the back.
Jul 10, 2009 | Necchi 4575 Mechanical Sewing Machine
Threading & Use of Needle Threder
Threading as per image....make sure presser foot is up so top thread will properly engage in tension unit, make sure your thread is inserted in small guide on needle arm too. Your user guide should have a clear graphic of this process which is essentially the same for all machines.
As for the needle threader, once thru the last guide on the needle arm, raise needle to highest position, lower the needle threader so that the tiny hook engages the eye of the needle and place thread horizontally from L to R along the plastic arm so the tiny hook can grab thread, release threader and a small loop will form in needle, pull it clear and you are away !
If the tiny hook has been bent, a little judicious and gentle bending to re-align may be necessary, use a jewellers screwdriver or similar and please be very gentle
Feb 07, 2008 | Janome Jem Gold 660 Sewing Machine
Brother XL-3510 Mechanical Sewing Machine Logo
85 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
