Question about InFocus LP70+ Multimedia Projector
Infocus LP70+ Color Wheel Chirping
Less than 180 Hours on this projector. Picture is fine on all sources, yet it flickers.
With the top cover up and all internals exposed, I can distinctly hear a low mumbling chirping from the color wheel motor. The picture is wonderful, but every time the wheel chirps (every few seconds) there is a few bright white scan lines appearing in the picture for a split second.
Does anyone have a service guide for this projector? Has anyone experienced the same problem and had it resolved? My instinct tells me either the color wheel motor is bad or a varying current supply to it. I need the service guide to troubleshoot.
  • ghayward May 02, 2008
    I have exactly the same problem with my LP70+. (Excellent description Joekidya).
  • Anonymous Mar 22, 2009
    me too
Increase refresh rate
Posted on Jul 25, 2008
Hi, I have a Infocus Projector, Model # LP70, serial # begins with ACAN. The projector only has 951 hours on the bulb. The unit powers on and I get the Infocus startup screen. as soon as I turn on a video...
I think it is the time to remove the cover and check for air filters blocked with dust.
When this happens, air doesn't flow freely through the projector and result in overheating, which leads to automatic shutdown.
Sep 22, 2011 | InFocus LP70+ Multimedia Projector
Message reads failure to srike lamp. bulb is less
that ones are total ****... seems like lamp is broken .. my advice would be get a new projector(not LP70) other that get a new lamp...
Mar 02, 2010 | InFocus LP70+ Multimedia Projector
Infocus LP70 powers itself down after 30 seconds or so.
HI,,
ITS PROBLEM WITH URS PROJECTION CIRCUIT WHICH HAS BAD CAPACITORS..
JUST REPLACE THE CAPACITORS..
TNKS
RABBANEES
Nov 12, 2009 | InFocus LP 70 Multimedia Projector
InFocus LP70 projector is running hot
clean the dust out of it with canned air. the dust keeps in the heat that the projector is trying to expell. it also shortens the life of the lamp.
Sep 21, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70
Have you tried another lamp? Sometimes thats your problem, but I've seen a several occasions that the a defective power supply causes this symptom. Do you see an image flicker before the projector shutsdown? I do have some spare parts for this projector.
I'm on Ebay - gtitubro if you want to contact me through there.
Sep 17, 2009 | InFocus LP70+ Multimedia Projector
Lp70 flickers and color wheel chirps at the same time. It's worse with more white in the image. Colored screen shots or dark movies have limited flickering. No issues prior to hookup to computer (Infocus...
it's chirping because it's trying to keep in sync with the dmd chip. for the refresh rate, go into the menu and first reset the settings to factory default. if this doesn't clear it up, try matching the signal.
Jun 09, 2009 | InFocus LP70+ Multimedia Projector
InFocus LP70 color problem
try resetting the settings to factory default through the menu. if there's still a problem, take the cover off. if you look from the back of the machine, inside on the bottom left, you'll see the main board attached by a large white plug. use something thin and non-metalic to push the bottom of the board towards the plug to tighten it. now do the same to the other side of the plug. this should solve it. if it doesn't, you need to replace the main board.
May 11, 2009 | InFocus LP70+ Multimedia Projector
Cannot see computer displyed on output of infocus screen shot
Many laptop computers do not automatically turn on their external
video port when a projector is connected. On many laptops, the activation function key is labeled with an icon or the text CRT/LCD.
Try the Function Key with the Icon of a monitor to enable the external video port.
If that does work, look at the settings on the projector using the buttons on the top.
Check the "Default Source"
Default Source toggles among Computer 1 analog, Computer 1 digital, Computer 2, and Video. This determines which source the
projector checks first for active video during power-up. Highlight
Default Source and click the left or right mouse button to toggle
among the options.
Jan 12, 2009 | InFocus LP70+ Multimedia Projector
PAL support
Yes the LP70 and the LP70+ both operate perfectly with a PAL source. Also the will operate just fine using 220vac 50hz too.
Cheers
May 31, 2008 | InFocus LP 70 Multimedia Projector
InFocus LP70+ Multimedia Projector Logo
462 people viewed this question
Top InFocus Office Equipment & Supplies Experts
jasbo
jasbo
Are you an InFocus Office Equipment and Supply Expert? Answer questions, earn points and help others
