Question about Vacuums
DIRT DEVIL MADEL 08245 BRUSE DOSEN'T ROTATE
I had the same problem and fixed it to where it would work OK, althought not 100%. 1. Disconnect the hose that goes to the roller brush area. 2. Press the button right below the power switch while sliding the handle what ever direction it will go to release it from the body of the vac. 3. Remove 3 screws from the handle halves. 4. Remove 2 screws from a keyed black plastic piece that hold the handle halves together. 5. Carefully separate the handles halves from the clear plastic piece in the center that allows you to view the brush and belt. 6. If the belt is broken or missing, replace it and reassemble, if the belt is OK, remove the roller and test if the bearings spin freely. 7. If they don't, then remove the clip or clips of each end that hold the bearing(s) in place. (Work in a controlled environment so that when the little clip goes flying you'll be able to locate it without moving the refridgerator.) 8. Clean the back side of the bearing of hair, dust and dirt. (used compressed air if you have it) 9. Reassemble the bearing(s) you removed and cleaned on each end of the roller. I used a spritz of teflon dry lube spray on each when I put them back together. 10. Disassemble the air motor bearing from the shaft on the end that does not have the belt gear. Be careful not to lose the flat thrust bearing/washer at the bottom of the bearing housing. Clean, lube and reassemble. 11. Since I felt I couldn't remove the belt gear from the shaft (to get at the bearing), without damaging it, I worked at cutting the hairs and threads wound around the shaft. I used a single edge razor blade to painstakingly cut and remove what I could, then lubed and reassembled air motor. 12. I then reassembled everything and tried it. IT WORKED. The still sluggish bearing on the gear end of the air motor wasn't enough to stop the motor from turning the brush at an acceptable speed and torque.
Posted on Nov 30, 2008
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559809
Generic problem for all Vacuums
Posted by GENEFIXIT on Apr 30, 2008
DIRT DEVIL MODEL 08245
BRUSE HAS NO TORQUE, HOW DO I OPEN UNIT TO GET TO TURBO UNIT
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
As per the brush does not rotate you may have a broken belt and it would need a new one. Also make sure the brushroll is clean and spins freely and free from thread, hair and other types of things that get wrapped around the brushroll. The recommended belt change id every 4 to 6 months if you have a flat belt.
Most of the turbo units are a snap together or they have hidden screws to un-screw to open the top and the bottom of the turbo unit, please check with you owner’s manual under trouble shooting and they will instruct you on how to dis-assemble the unit, and also please check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
Don – The Vac Man
Go Ahead. Use Us.
Posted on Apr 30, 2008
Are bags needed for a dirt devil hand held dust buster?
Dirt Devil Parts
dirtdevil.com/parts/
Dirt DevilNo promo code required. ... most popular: Bags: Belts: Filters: Cleaning Solutions: Filters, F1-F85: Filters, Adapters: Filters, ... vacuum cleaner: Attachments & Tools: Brushrolls, Hand Vacs: Brushrolls, Uprights ... Handheld Steam Cleaners.
Type G (10 Pack) - 3010348001 - Dirt Devil
dirtdevil.com/parts/details/3010348001/type-g-10-pack/
Dirt DevilGenuine Type G bags. Fits all hand vac models equipped with the paper bag adapter. Includes ... The Handheld Vacuum That Picks Up Where Others Leave Off ...
Ultra Corded Bagged Handheld Vacuum - Dirt Devil
Jan 01, 2016 | Dirt Devil Vacuums
How do you fix a dirt devil express vacuum that want rotate?
I would check the belt to make sure its not broke or damaged
Jul 25, 2015 | Dirt Devil Vacuums
How do you change the belt of the m5088520?
Hi There,
Here's step by step instructions for you on how to replace the belt on your Dirt Devil M088520 Featherlite.
Flip cleaner to expose nozzle base. Base should lay flat and face up. To remove nozzle guard, use Phillips
screwdriver to remove the two screws. Arrows (Diagram 1) show location of screws.
Lift nozzle guard off. Slide belt off motor shaft
(Diagram 2).
Lift and remove brushroll (Diagram 3). Dispose of old belt.
TO REPLACE BELT
1. Place belt on motor shaft, then slip brushroll through belt. Place belt in area of brushroll without bristles (Diagram 4).
2. With belt in place, pull and slide brushroll into nozzle (Diagram 3) making sure that the brushroll end caps are in the correct
orientation (Diagram 3a inset)
IMPORTANT: Rotate brushroll manually to make sure belt is not twisted.
3. Reattach nozzle guard. Secure by locating the 3 tabs in the base slots and replace the screws (Diagram 1).
I really hope that this was helpful to you. If you'd like to download the manual for your vacuum cleaner where I got this information, please see the link below where you may download. If you found this helpful, please be so kind and rate my repair helpful, or leave feedback for me. This is really appreciated by Fixya users.
Thanks so much.
Dirt Devil M088520 Featherlite Vacuum Cleaner
Owners Manual
Chris Jones
GoVacuum.com
May 07, 2010 | Dirt Devil M088520 Featherlite Bagged...
I need a new belt for my Dirt Devil RoomMate. Where can I get one? Advise
Your Dirt Devil M084000 uses Dirt Devil Style 7 Belt - 2 Pack. Part # 3400615001 according to the parts manual for this vacuum cleaner, as well as the Dirt Devil website.
Here's a link to the belts online at our store;
http://www.govacuum.com/ddp126.html
I hope this helps you! Please rate the review as helpful if this helped you find the belts.
Thanks,
Chris
Mar 20, 2010 | Dirt Devil M084000 RoomMate Upright Vacuum
The brush doesn't rotate on the turbo tool. the belt on it isn't broken it just seems really stiff to turn by hand as well
The belt doesn't have to be broken to be bad. Even if it is stretched or worn it will not turn the brush roll properly. Here is the belt you need and the manual which has instructions:
Dirt Devil Vision Turbo Belts
Download the Manual (PDF)
Dec 21, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Hose gone on Dirt Devil DD2821 need replacement
http://www.espares.co.uk/part/vacuum-cleaners/dirt-devil/dd2821/p/1086/112/0/970655/478317/universal-flexible-clean-.html
This is the only hose "Dirt Devil" has listed for your model number.
Dec 12, 2009 | Dirt Devil Vacuums
Change belt on dirt devil vacuum
It largely depends on the model you have. However, you can get any Dirt Devil replacement belt here:
Dirt Devil Belts
Oct 22, 2009 | Dirt Devil Vacuums
DIRT DEVIL MODEL 08245 BRUSE HAS NO TORQUE, HOW DO I OPEN UNIT TO GET TO TURBO UNIT
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559803
Customer Service
Don – The Vac Man
Apr 30, 2008 | Vacuums
Vacuums Logo
458 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
