Question about Vacuums
DIRT DEVIL MODEL 08245 BRUSE HAS NO TORQUE, HOW DO I OPEN UNIT TO GET TO TURBO UNIT
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 310 Answers
Http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=559803
Generic problem for all Vacuums
Posted by GENEFIXIT on Apr 30, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
Most of the turbo units are a snap together or they have hidden screws to un-screw to open the top and the bottom of the turbo unit, please check with you owner’s manual under trouble shooting and they will instruct you on how to dis-assemble the unit, and also please check with your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.royalvacuums.com
Customer Service
For help with a model that is not working, if you want to check an order, if you need help finding a part or service center or have any other comment, complaint or question that is not a technical question about this web site use the link above. You can also call our Customer Service department between 8AM and 7PM EST Monday through Friday at (800) 321-1134.
Don – The Vac Man
Posted on Apr 30, 2008
Dust Devil UD40180 repair manuel
Mate I just googled Dust Devil UD40180 repair manual and found this link, I hope it helps... If not then you google Dust Devil UD40180 repair manual It might give you some ideas...CHEERS
http://www.ereplacementparts.com/dirt-devil-ud40180-ultra-vision-turbo-bagless-upright-vacuum-parts-c-36976_37103_37186.html
Mar 12, 2016 | Dirt Devil Ultra Vision Turbo Bagless...
My dirt devil has no main suction
You need to go a bit deeper in the unit to get what is clogged. it is most likely clogged on the inside of the unit. Take off the back and remove the inner workings following the path of the suction. Not hard to do just sucks.
Jan 24, 2013 | Dirt Devil Vision Turbo W/Bonus Upright...
Where is the belt on the dirt devil vision turbo cant find it
the belt is to the left of the brush. You need to revome the plastic covering (4 screws) to see it.
Oct 27, 2009 | Dirt Devil Vision Turbo W/Bonus Upright...
Missing belt
Thanks for the info **** now stick it up your ***!
Nov 19, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Dirt devil ultra vision turbo - how to change filter
remove the dirt cup, the top part should turn a little bit and then separate ( look were the clear plastic meets the colored top you might see a little picture of a lock and a open lock turn the lid towards the unlocked position , the filter should be in there
Sep 17, 2008 | Dirt Devil Vacuums
Filter clogs with every use
What should I do when the dirt Devil Vacuum clener doesn't **** up dirt ?
Sep 10, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
DIRT DEVIL MADEL 08245 BRUSE DOSEN'T ROTATE
I had the same problem and fixed it to where it would work OK, althought not 100%. 1. Disconnect the hose that goes to the roller brush area. 2. Press the button right below the power switch while sliding the handle what ever direction it will go to release it from the body of the vac. 3. Remove 3 screws from the handle halves. 4. Remove 2 screws from a keyed black plastic piece that hold the handle halves together. 5. Carefully separate the handles halves from the clear plastic piece in the center that allows you to view the brush and belt. 6. If the belt is broken or missing, replace it and reassemble, if the belt is OK, remove the roller and test if the bearings spin freely. 7. If they don't, then remove the clip or clips of each end that hold the bearing(s) in place. (Work in a controlled environment so that when the little clip goes flying you'll be able to locate it without moving the refridgerator.) 8. Clean the back side of the bearing of hair, dust and dirt. (used compressed air if you have it) 9. Reassemble the bearing(s) you removed and cleaned on each end of the roller. I used a spritz of teflon dry lube spray on each when I put them back together. 10. Disassemble the air motor bearing from the shaft on the end that does not have the belt gear. Be careful not to lose the flat thrust bearing/washer at the bottom of the bearing housing. Clean, lube and reassemble. 11. Since I felt I couldn't remove the belt gear from the shaft (to get at the bearing), without damaging it, I worked at cutting the hairs and threads wound around the shaft. I used a single edge razor blade to painstakingly cut and remove what I could, then lubed and reassembled air motor. 12. I then reassembled everything and tried it. IT WORKED. The still sluggish bearing on the gear end of the air motor wasn't enough to stop the motor from turning the brush at an acceptable speed and torque.
Apr 30, 2008 | Vacuums
Vacuums Logo
124 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
