Question about Acer Aspire 5100 Notebook
PCI slot 03 error in acer laptop model 5100, how to fix this problem?
  • 77 Answers
Sounds like a mainboard issue to me.. might need to get it replaced
Posted on Apr 30, 2008
When starting the laptop acer 5100 it tyries to start and it shows the following Bus 06, device 02 ,function 00 error resource conflict pci in slot 03 bus 06 device 04 function...
If it just started doing this all of a sudden, then it is a good bet that *********** board is fried. If you just installed some memory or a communications card or new drive, then take it out and see if it still does it. If not, check the installation instructions to make sure it was put in right.
Sep 08, 2010 | Acer Aspire 5100 Notebook
I have an Acer Aspire 5100 with Vista Home Premium on it...when starting the laptop acer 5100 it tries to start beeps...and it shows the following page of errors Bus 06, device 02 ,function 00 error...
It might be possible some kinda a BIOS corruption. Let us try this first. ASA computer starts keep on tapping F2, it will enter the BIOS setup utility, then press F9 and then F10, save the seeting and restart the computer. It should resolve the issue. But if the issue still persists, then update the BIOS. Visit the webiste mentioned below:
http://support.acer.com/drivers_download.aspx
Select the model and update the BIOS.
May 07, 2010 | Acer Aspire 5100 Notebook
Resorce error pci in slot 03
It appears there is a problem or faulty slot 3 PCI connector. Move the PCI card from slot 3 to a different slot. If this fault follows to the other PCI slot then the PCI card could be faulty.
Aug 07, 2009 | Acer Aspire 5100 Notebook
My laptop wil not boot. Not even in safemode . It has wndows xp that i had recently put on there.. its been doing this for a min but it would come on after a few tries.. This is exactly what happens when i...
Hello Karen
Try removing and resetting your memory modules.
Blow some air in the slots to remove any dirt trapped in there.
They are locate don the back of your laptop.
The instructions are in the manual under how to change or upgrade memory modules.
Please don;t forget to rate this answer if it helps
Jul 22, 2009 | Acer Aspire 5100 Notebook
Aspire 5100 resource conflict - pci slot 3
Yuor RAM memory conflicts with each other check RAM memory fix same frequency memory into laptop.
Thanks for using fixya.
Jul 20, 2009 | Acer Aspire 5100 Notebook
Pci slot error
I have the same problem with an Aspire 5100.
I can eliminate any problems with the software, as the problem exist with the hard drive renoved.
It appears after the 'Acer' splash screen and fails as part of the POST.
After reading through various posts I suspect the broadcom wirless card or LAN has failed at board level.
I will try removing them and try again.
Will post back with results.
Jun 10, 2009 | Acer Aspire 5100 Notebook
Acer aspire laptop wont boot
y dont u dispose it off if it is a problem computer, i guess it is a generic problem of laptop need to replace motherboard or so. avail warrent if it has...
Nov 25, 2008 | Acer Aspire 5100-5033 Notebook
Laptop will not fully start
This could be a device failure. However, try flashing the bios. Do this by going to Acer's support site and creating a bootable disc with the bios or updated bios, if there is any, on it. Then run this in your machine. You will have to use a different computer to do this, apparently. If this doesn't fix the problem, then you will need to take it in and have a tech run down the device that failed.
Jun 26, 2008 | Acer Aspire 5100 Notebook
Acer Aspire 5100 Notebook Logo
165 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
